Re: Changing palettes and maintaining there state [message #191451 is a reply to message #191439] |
Wed, 10 August 2005 14:31 |
@see PaletteViewer#saveState(Memento)
"Steve Jones" <steve@istech.demon.co.uk> wrote in message
news:ddd1d1$n8g$1@news.eclipse.org...
> I change my GEF diagram root based on the user selection in the model out
> line view. I also change the tool palette based on this selection.
> My problem is that every time a palette is redisplayed by calling
> PaletteViewer#setPaleteRoot() it is displayed in it's initial state with
> all its draws opened.
> Id like to maintain the palette draw state between selections.
> Any ideas on how to do this?
> Thanks, Steve.
Re: Changing palettes and maintaining there state [message #191576 is a reply to message #191513] |
Wed, 10 August 2005 17:14 |
I can't think of any reason for that performance problem. Hopefully it is
related to something else that is happening when you switch palettes.
news:dddbga$4ju$1@news.eclipse.org...
> I've subclassed PaletteViewer and save & restore the PaletteViewer state
> whenever the palette root changes. It works just as expected, thanks.
> I'm puzzled by the fact that if I change root to a diagram who's palette
> draws are closed it takes quite a bit longer to draw the palette than when
> the draws are open. One is instant, the other takes about a second. Like,
> you can watch it.
> Any Ideas as to why that should be?
> Steve.
Re: Changing palettes and maintaining there state [message #191773 is a reply to message #191743] |
Thu, 11 August 2005 15:27 |
Originally posted by: none.unknown.com
Open a bug report. Mention on there how big your palette is (how many
drawers, groups, etc.).
news:ddf377$pp0$1@news.eclipse.org...
is
> It's the palette animation that I'm seeing. When I redisplay a palette
it's
> reconstructed from scratch, using the initial draw states - that's how the
> palette viewer works.
> I then apply the cached state from my Memento. All the cached changes are
> applied but each is animated as it would be under normal user selection.
> Watching several draws open together under animation looks sick. It would
> not normally happen.
> Is it possible to turn the palette animation off?
> Steve.
state
palette
> >> when the draws are open. One is instant, the other takes about a
second.
> >> Like, you can watch it.
> >> Steve.
> Steve Jones
> I.S.Technology Ltd
Re: Changing palettes and maintaining there state [message #191796 is a reply to message #191743] |
Thu, 11 August 2005 16:43 |
Pratik, how is it that we avoid animation when the palette gets slurped
inside the flyout composite or opened inside the palette view?
> it's
> Steve.
>>> when the draws are open. One is instant, the other takes about a second.
>>> Steve.
> Steve Jones
> I.S.Technology Ltd
Re: Changing palettes and maintaining there state [message #191804 is a reply to message #191796] |
Thu, 11 August 2005 17:05 |
That's what I was thinking. But apparently we don't. I'm thinking we just
don't see this problem because we don't have a lot of items in the palette
and all drawers are usually always open in our examples.
This bug has a patch to disable animation based on the workbench preference:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=82736
We could enhance it to support disabling animation when desired.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:ddfv8i$tul$1@news.eclipse.org...
is
> > it's
the
are
would
> > Steve.
state
palette
second.
> >>> Steve.
> > Steve Jones
> > I.S.Technology Ltd
FUDForum. Page generated in 0.04772 seconds
