Re: Line Chart displays null values as 0 [message #1219257 is a reply to message #1219256] |
Mon, 02 December 2013 22:55 |
I went to double check and created your chart from scratch in 4.3.1 and it works fine, as well. So, I looked at your chart vs the one I had created and found that when you have grouping enabled, as you do, that the marker is created. Without the grouping enabled, the line ends as expected. You can disable grouping by going to the select data tab and choosing the grouping and sorting button next to the x-axis field. The bug is still valid though because each grouping without an actual value shouldn't have a marker. Could you please update the bug with this info?
Michael
Developer Evangelist, Silanis
FUDForum. Page generated in 0.04643 seconds
