Home » Modeling » M2T (model-to-text transformation) » [JET2] Struggling with finding my files during runtime
[JET2] Struggling with finding my files during runtime [message #18112] |
Sun, 27 May 2007 16:08 |
Originally posted by: evaandoli.dodo.com.au
I have JET2 templates that work perfectly when I use the Run JET options
within Eclipse.
When I link it in to my GMF diagram and lauch the runtime Eclipse
environment it doesn't find the files that it tried to load.
I feel the problem might be around the setting of the
("org.eclipse.jet.resource.project.name").
During runtime I have set this to :-
1) the Eclipse Project Name only
2) platform:/<ProejctName>
3) ./
But each time I used the c:load it still doesn't find the files that I feel
it should.
Any clues ?
Below is the code I use to call the JERTransform from within my GMF diagram.
Below that is the Jet load command I'm using
Map<String, String> variables = new HashMap<String, String>();
variables.put("org.eclipse.jet.resource.project.name",resource.getURI().segments()[1]);
IStatus status =
GenerateXMLDictionaryAction.runTransformXMLDiagram(resource, variables,
aProgressMonitor);
<c:load url="{$compoundResourceName}.xml" var="{$compoundResourceName}Var"
type="xml"/>
Re: [JET2] Struggling with finding my files during runtime [message #18121 is a reply to message #18112] |
Mon, 28 May 2007 01:52 |
To add a bit more I logged the variable when running local and within plugin
eclipse launch with my GMF diagram and in both instances the
attribute {org.eclipse.jet.resource.project.name} returns just the Project
name.
Is there something special about c:load at runtime ? or is it something
special about the way eclipse launches its GMF plugin developement run test
Stu
"Stu" <evaandoli@dodo.com.au> wrote in message
news:f3caem$u7i$1@build.eclipse.org...
> within Eclipse.
> 3) ./
> feel it should.
> Any clues ?
> diagram.
> IStatus status =
> aProgressMonitor);
> type="xml"/>
Re: [JET2] Struggling with finding my files during runtime [message #18216 is a reply to message #18154] |
Mon, 28 May 2007 13:43 |
$compoundResourceName in my test case becomes Test1 then Test2
Test1.xml exists in the root of the eclipse project (in the GMF launched
test project as well.
It works ok when I run using the Jet transformation.
But doesn't find it when I run it within a GMF diagram plugin.
From your note below I did the following:-
<c:load
url=" {$org.eclipse.jet.resource.project.name}/{$compoundResourceN ame}.xml "
var="{$compoundResourceName}" urlContext="workspace" />
which one the first pass equates to:
<c:load url="TestPlugins/Test2.xml" var="Test2" urlContext="workspace" />
And I get the following Error BUT only when I run it from within a GMF
plugin.
Unable to load: TestPlugins/Test2.xml
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:f3ejrj$d74$1@build.eclipse.org...
> Stu:
> Looking at your code, I don't think it has anything to do with
> 'org.eclipse.jet.resource.project.name'.
> You mention:
>> var="{$compoundResourceName}Var" type="xml"/>
> What is your calculation for $compoundResourceName ?
> If it includes an URL schema (e.g. http:, file:), then it will be resolved
> directly. However, it there is no such schema (I'm guessing this is the
> case), then c:load will resolve the URL relative to a base URL. By
> default, this is an URL for the root directory of the transformation
> project.
> I am guessing that you are wanting to load from the workspace, and that
> your calculation for compoundResourceName results in a value such as:
> ../project-name/...
> Fortunately, c:load has an optional attribute which uses the the workspace
> root as the baseURL:
> <c:load url="..." urlContext="workspace" .../>
> You can then set compoundResourceName to start with the project name:
> my-project/....
> Paul
Re: [JET2] Struggling with finding my files during runtime [message #18319 is a reply to message #18302] |
Fri, 01 June 2007 11:37 |
Yeah I found theok iStatus as I was trying to use the error dialog :-) Glad
you got it.
Ok information below:-
Seems to be saying feature 'version' is missing.
e Resource$IOWrappedException (id=8067)
cause FeatureNotFoundException (id=8071)
column 294
detailMessage "Feature \'version\' not found."
featureName "version"
line 2
location "platform:/resource/TestPlugins/Test2.xml"
object RuleConductorImpl (id=8092)
stackTrace null
(platform:/resource/TestPlugins/Test2.xml, 2, 294)"
stackTrace null
Stack dump:
Thread [main] (Suspended)
LoadTag.doAction(TagInfo, JET2Context, JET2Writer) line: 87
SafeEmptyRuntimeTag$1.doRun() line: 49
SafeEmptyRuntimeTag$1(SafeCustomRuntimeTag$TagSafeRunnable). run() line: 72
SafeRunner.run(ISafeRunnable) line: 37
Platform.run(ISafeRunnable) line: 850
SafeEmptyRuntimeTag.doStart(JET2Context, JET2Writer) line: 43
_jet_commonloadCompound.generate(JET2Context, JET2Writer) line: 140
TransformContextExtender.execute(String, boolean, JET2Writer) line: 146
IncludeTag.doAction(TagInfo, JET2Context, JET2Writer) line: 79
_jet_1createDataDictionaryCSV.generate(JET2Context, JET2Writer) line: 142
TransformContextExtender.execute(String, JET2Writer) line: 119
FileTag.doAction(TagInfo, JET2Context, JET2Writer) line: 101
_jet_main.generate(JET2Context, JET2Writer) line: 47
JET2Platform$4.run(IJETBundleDescriptor, JET2TemplateLoader,
IProgressMonitor) line: 448
JETBundleManager.run(String, IJETRunnable, IProgressMonitor) line: 330
JET2Platform.runTransform(String, JET2Context, IProgressMonitor) line: 416
JET2Platform.runTransformOnObject(String, Object, Map, IProgressMonitor)
line: 520
GenerateVisualRatingDataDictionaryAction.runTransformVisualD iagram(XMIResourceImpl,Map <String,String>, NullProgressMonitor) line: 16 RuleConductorCreateDataDictionaryAction.run(IAction) line: 63 EditorPluginAction(PluginAction).runWithEvent(Event) line: 253 PluginActionContributionItem(ActionContributionItem).handleW idgetSelection(Event, boolean) line: 545 ActionContributionItem.access$2(ActionContributionItem, Event, boolean)line: 490 ActionContributionItem$6.handleEvent(Event) line: 443 EventTable.sendEvent(Event) line: 66 ToolItem(Widget).sendEvent(Event) line: 938 Display.runDeferredEvents() line: 3673 Display.readAndDispatch() line: 3284 Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2337 Workbench.runUI() line: 2301 Workbench.access$4(Workbench) line: 2176 Workbench$4.run() line: 463 Realm.runWithDefault(Realm, Runnable) line: 289 Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 458 PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149 IDEApplication.start(IApplicationContext) line: 101 EclipseAppHandle.run(Object) line: 146 EclipseAppLauncher.runApplication(Object) line: 106 EclipseAppLauncher.start(Object) line: 76 EclipseStarter.run(Object) line: 356 EclipseStarter.run(String[], Runnable) line: 171 NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: notavailable [native method] NativeMethodAccessorImpl.invoke(Object, Object[]) line: not available DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: not available Method.invoke(Object, Object...) line: not available Main.invokeFramework(String[], URL[]) line: 476 Main.basicRun(String[]) line: 416 Main.run(String[]) line: 1141 Main.main(String[]) line: 1116"Paul Elder" <pelder@ca.ibm.com> wrote in messagenews:f3mn73$i6$1@build.eclipse.org...> Stu:>> I'm having trouble reproducing this. Can you launch this from a debuggerwith a break point in LoadTag.doAction:>> try> {> Object modelRoot = TransformContextExtender.loadModel(modelURL, loaderId,type);> context.setVariable(var, modelRoot);> }> catch (IOException e)> {>>> final String msg = JET2Messages.LoadTag_CouldNotLoad; << Break here> throw new JET2TagException(MessageFormat.format(msg, new Object []{url }), e);> }>> And tell me what the exception is? If you can print a stack trace, evenbetter.>> BTW, in investigating this, I discovered that the IStatus returned byJET2Platform.runTransformOnXXX() was always returning a severity of OK. I'vesubmitted bug 190222 to track this.>> Paul>
Re: [JET2] Struggling with finding my files during runtime [message #18403 is a reply to message #18371] |
Sat, 02 June 2007 04:57 |
Ok I have narrowed it down to:-
1) The error ONLY happens when JET2 is called from a plugin (when using
the launch in the dev environment it works ok).
2) If the format is:-
<root next="sample2.xml">
</root>
then it works
BUT
if I use
<com.ibridge.diagrammodel:RuleConductor next="test2.xml">
</com.ibridge.diagrammodel:RuleConductor>
Then it doesn't.
So it seem likesomething at runtime creates an exception when reading the
I have attached the very simple striped down version of how I narrow this
down.
test1.xml has a next which is used to load test2.xml.
main.jet and dumpTest.jet << loads test1.xml then test2.xml
The PerformJetTest.java is my code called by the extenion point.
Below is the code I call the above java class with from the GMF diagram:-
variables.put("org.eclipse.jet.resource.project.name","TestProjectJET ");
variables.put("loadVar","sample1.xml");
System.out.println("About to call common generate emthod in JET project");
IStatus status =
PerformJetTest.runTransformVisualDiagram(resource,variables,
aProgressMonitor);
System.out.println("Jet Outcome>>"+status.toString());
news:f3pm53$tmc$1@build.eclipse.org...
> Stu:
> Can you tell me a bit more about Test2.xml?
> From you have provided, it appears to be a document created from an EMF
> model.
> JET uses EMF to load XML documents, and when EMF finds a schema reference
> for which it has a know Ecore model for, it loads the document using it.
> Since everything works fine in your one environment, and not in the other,
> I
> think one of the following may be occuring.
> 1) The Ecore model is not registered in one of those environments, but is
> in
> the other
> 2) The ecore model's in the two environments are different.
> Paul
Attachment: test2.xml
(Size: 0.11KB, Downloaded 185 times) -
Attachment: test1.xml
(Size: 0.11KB, Downloaded 212 times) -
Attachment: main.jet
(Size: 0.85KB, Downloaded 213 times) -
Attachment: dumpTest.jet
(Size: 0.50KB, Downloaded 282 times) -
Attachment: PerformJetTest.java
(Size: 0.63KB, Downloaded 253 times)
Re: [JET2] Struggling with finding my files during runtime [message #22494 is a reply to message #20643] |
Mon, 18 June 2007 17:31 |
Paul,
The issue for this seems to be around the ':'
If I use:-
<root:root next="sample2.xml">
</root:root>
I get the error but if I use:-
<rootroot next="sample2.xml">
</rootroot>
Its all fine.
Anywhere I can put a debug and step through it to help with this one ?
Stu
news:f43n8b$s94$1@build.eclipse.org...
> Stu:
> No luck yet, but I'm going through shut-down of both the Europa release
> and some internal development, so I haven't tried too hard.
> I'll keep you posted.
> Paul
> news:f42arr$vc9$1@build.eclipse.org...
>> Thank mate,
>> Did you manage to replicate the issue ?
>> At the moment I'm demo'ing the facility via the dev.environment which
>> works well.
>> Cheers for the support,
>> Stu
>> news:f417ae$cc1$1@build.eclipse.org...
>>> Stu:
>>> I'm going to try and do some experiments and see if I can get you
>>> through this. I'll post again later.
>>> Paul
Re: [JET2] Struggling with finding my files during runtime [message #28067 is a reply to message #18112] |
Tue, 24 July 2007 01:37 |
Paul any answer on this one ?
Getting close to my go live cut off?
If you can think of another soltuion that would be good. I just feel a bit
stuck.
Stu
> within Eclipse.
> 3) ./
> feel it should.
> Any clues ?
> diagram.
> IStatus status =
> aProgressMonitor);
> type="xml"/>
Re: [JET2] Struggling with finding my files during runtime [message #28925 is a reply to message #28067] |
Wed, 25 July 2007 17:57 |
Paul Elder Messages: 849 Registered: July 2009 |
Stu:
I've still don't have a definitive solution, but here are some thoughts:
In a previous post you mention the following stack trace after c:load's
failure:
column 294
line 2
stackTrace null
stackTrace null
This is a common failure when JET's XML loader (which is acutally using an
EMF facility) tries to load an XMI-encoded document and JET has not supplied
EMF with the right file extension to select the correct EMF deserializer.
The generic XML deserializer that JET falls back to cannot load XMI encoded
documents.
Here are the first two lines of an XMI encoded document.
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="xmachine"
nsURI="..." nsPrefix="...">
The message "Feature 'version' not found" is refereing to the attribute
xmi:version. It cannot be found because the generic XML deserializer
silently ignores the xmlns:xmi declaration.
The only way that JET can load an XMI encoded document is to have an
EMF-generated deserializer (i.e. resource factory). The way JET finds that
factory is via the file extension, or, via the 'type' attribute on the
c:load tag (the 'type' attribute overrides the file extension).
You stated that a simplified document (your posted indicated it lacked a
namespace prefix on the original document, but I suspect is also lacked the
xmlns:xmi and xmi:version attributes) could be loaded. This to me is
consistent with the JET's inability to load XMI without the assist of an
appropriate resource factory.
BUT, all is not lost.
First, I assume that the document you are loading was serialized via EMF.
Things to check:
1) In the plug-in that declares the EMF metamodel for your document, verify
that plugin.xml has an entry like:
<extension point="org.eclipse.emf.ecore.extension_parser">
<parser
type=" ... file extension for models ..."
class="... fully qualified name of an XXXResourceFactoryImpl" />
</extension>
2) If you are using a GMF editor to create the document, verify that domain
file extension is set to the same value as in 1, above. If you don't, JET
will not be able to load the resulting XMI output without a 'type' hint on
c:load (of the extension identified in 1).
3) In the c:load tag, explicitly specify the model loader id
"org.eclipse.jet.emf", and, assuming the xml is not the registered extension
in 1, the registered extension:
<c:load
loader="org.eclipse.jet.emf" type="... type from 1 ..." />
If none of this works, I think I will require a test case that I can debug.
The other alternative would be to load your XML documents via some mechanism
other than EMF (an standard XML DocumentBuilder, for example).
Unfortunately, JET doesn't include one of those yet, but there is an example
attached to bug 195847
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=195847).
Paul
news:f83l54$3fr$1@build.eclipse.org...
> bit stuck.
> Stu
>> Hi,
>> within Eclipse.
>> 3) ./
>> feel it should.
>> Any clues ?
>> diagram.
>> IStatus status =
>> aProgressMonitor);
Re: [JET2] Struggling with finding my files during runtime [message #29148 is a reply to message #28925] |
Thu, 26 July 2007 14:31 |
I got the test case narrowed down to:-
If I use:-
</root:root>
</rootroot>
Does that help at all ?
news:f882vi$ecs$1@build.eclipse.org...
> Stu:
> failure:
> column 294
> line 2
> stackTrace null
> stackTrace null
> supplied EMF with the right file extension to select the correct EMF
> deserializer. The generic XML deserializer that JET falls back to cannot
> load XMI encoded documents.
> xmlns:xmi="http://www.omg.org/XMI"
> the xmlns:xmi and xmi:version attributes) could be loaded. This to me is
> Things to check:
> verify that plugin.xml has an entry like:
> <parser
> </extension>
> domain file extension is set to the same value as in 1, above. If you
> don't, JET will not be able to load the resulting XMI output without a
> 'type' hint on c:load (of the extension identified in 1).
> extension in 1, the registered extension:
> <c:load
> debug. The other alternative would be to load your XML documents via some
> mechanism other than EMF (an standard XML DocumentBuilder, for example).
> example attached to bug 195847
> Paul
>> bit stuck.
>> Thanks,
>> Stu
>>> Hi,
>>> options within Eclipse.
>>> 3) ./
>>> feel it should.
>>> Any clues ?
>>> diagram.
>>> IStatus status =
>>> aProgressMonitor);
Re: [JET2] Struggling with finding my files during runtime [message #29186 is a reply to message #29148] |
Thu, 26 July 2007 14:35 |
Sorry Paul - only read message one- Head not on today - I'll look at this
tomorrow and let you know.
Thanks for the detailed response.
Great support,
Stuart
news:f8ab7o$340$1@build.eclipse.org...
> If I use:-
> </root:root>
> </rootroot>
>> Stu:
>> failure:
>> column 294
>> line 2
>> stackTrace null
>> stackTrace null
>> an EMF facility) tries to load an XMI-encoded document and JET has not
>> <?xml version="1.0" encoding="UTF-8"?>
>> that factory is via the file extension, or, via the 'type' attribute on
>> the c:load tag (the 'type' attribute overrides the file extension).
>> Things to check:
>> <parser
>> </extension>
>> <c:load
>> Paul
>>> bit stuck.
>>> Thanks,
>>> Stu
>>>> Hi,
>>>> 3) ./
>>>> feel it should.
>>>> Any clues ?
>>>> diagram.
>>>> IStatus status =
>>>> aProgressMonitor);
<solved> Re: [JET2] Struggling with finding my files during runtime [message #29522 is a reply to message #28925] |
Mon, 30 July 2007 06:59 |
Excellent response my dear friend.
GMF generates the extension point to be the diagram XMI and not the data
XMI.
So implementing the load with the loader and type hints worked.
Thanks a lot of that response very helpful.
I think we are up to 5 beers I owe you know,
Stu
> Stu:
> failure:
> column 294
> line 2
> stackTrace null
> stackTrace null
> Things to check:
> <parser
> </extension>
> <c:load
> Paul
>> bit stuck.
>> Thanks,
>> Stu
>>> Hi,
>>> 3) ./
>>> feel it should.
>>> Any clues ?
>>> diagram.
>>> IStatus status =
>>> aProgressMonitor);
Re: <solved> Re: [JET2] Struggling with finding my files during runtime [message #29580 is a reply to message #29522] |
Mon, 30 July 2007 15:28 |
Stu:
Now, I just have to figure out a reason to get to OZ so I can collect ;-)
Paul
news:f8k27t$t9n$1@build.eclipse.org...
> XMI.
> Stu
>> Stu:
>> failure:
>> column 294
>> line 2
>> stackTrace null
>> stackTrace null
>> Things to check:
>> <parser
>> </extension>
>> <c:load
>> Paul
>>> bit stuck.
>>> Thanks,
>>> Stu
>>>> Hi,
>>>> 3) ./
>>>> feel it should.
>>>> Any clues ?
>>>> diagram.
>>>> IStatus status =
>>>> aProgressMonitor);
Re: <solved> Re: [JET2] Struggling with finding my files during runtime [message #30168 is a reply to message #29580] |
Tue, 31 July 2007 07:31 |
True and the beers not that great :-)
Just as a follow on is there something that should be changed in GMF to help
others with this type of error.
I'm using GMF pretty much as is. So you get two XMI files
(MyFile.vr_diagram and MyFile.vr). One has diagram info the other data
info.
There is an extension point for vr_diagram BUT GMF by default doesn't create
one for the data file (vr in this case).
Thus the c:load JET function does know what to you with the file.
Do this make sense :-)
Just wondering how to stop others getting stumped like I did,
Stuart
news:f8l04f$5jm$1@build.eclipse.org...
> Stu:
> Paul
>> XMI.
>> Stu
>>> Stu:
>>> failure:
>>> column 294
>>> line 2
>>> stackTrace null
>>> stackTrace null
>>> EMF. Things to check:
>>> <parser
>>> </extension>
>>> <c:load
>>> some mechanism other than EMF (an standard XML DocumentBuilder, for
>>> example). Unfortunately, JET doesn't include one of those yet, but there
>>> is an example attached to bug 195847
>>> Paul
>>>> bit stuck.
>>>> Thanks,
>>>> Stu
>>>>> Hi,
>>>>> 3) ./
>>>>> feel it should.
>>>>> Any clues ?
>>>>> diagram.
>>>>> IStatus status =
>>>>> aProgressMonitor);
Current Time: Thu Apr 25 05:27:20 GMT 2024
Powered by FUDForum. Page generated in 0.04890 seconds
