Web Service pure java client [message #190532] |
Wed, 28 March 2007 10:03 |
Originally posted by: ouri.poupko.gmail.com
I would like to use a web service as a client in a simple java
application. I tried using the Web Service Client wizard but it requires a
server like Tomcat to be installed. Can I create a client that does not
rely on any server and can be simply called from a simple java application?
Ouri.
Re: Web Service pure java client [message #190555 is a reply to message #190532] |
Wed, 28 March 2007 15:11 |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Ouri,
I think the server is only required for running the wizard, but you won't need
it for running your application.
Hope this helps
Wolfgang
Ouri wrote:
> a server like Tomcat to be installed. Can I create a client that does
> not rely on any server and can be simply called from a simple java
> application?
> Ouri.
Re: Web Service pure java client [message #190663 is a reply to message #190555] |
Thu, 29 March 2007 07:50 |
Thanks Wolfgang.
I managed to verify this on a computer that is not behind a firewall. This
convinced me that my original client does not work because of firewall
proxy settings.
I read somewhere that the proxy needs to be defined for the JRE that my
client is using. I tried this in two ways:
1- through "control panel" -> Java -> Open -> General -> "network
settings"
2- through eclipse -> run -> environment (adding http.proxyHost and
http.proxyPort)
Both ways did not help.
Does anyone know how to define proxy settings for java applications
running in eclipse?
Ouri.
FUDForum. Page generated in 0.02847 seconds
