Home » Eclipse Projects » DSDP - Target Management » Remote Project
Re: Remote Project [message #1551 is a reply to message #1533] |
Wed, 11 October 2006 01:41 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hello Edward,
thanks a lot for your report. What you describe, sounds like 2 distinct
bugs:
1. [efs] new project browse location dialog appears on 2nd try only
2. [efs] cannot create remote php project from new project dialog
Could you make bugzilla entries for these two bugs, including the
description and configuration info you gave? - This will help the
component owner of the EFS integration understand and fix the
problems.
With respect to the dstore, you are able to run this even if you
are not root on the remote machine. Just extract the dstore server
into a directory below your home directory. Then, you can either
execute the dstore server through the RExec server launcher, or
you launch the server manually and connect to the running server.
The latter works even through an SSH tunnel.
For details, see the docs you installed with the RSE, or at
http://dsdp.eclipse.org/help/latest/index.jsp?topic=/org.ecl ipse.rse.doc.user/tasks/tbeginlinux.html
section "To start the server manually", or "SSL and firewalls".
If you find the docs unclear, please also file a bug.
Martin
Edward Mann schrieb:
> First of all thanks for the great plugin to Eclipse. This is awesome. I
> have been waiting for something like this. I use Linux and was using
> FuseSSH to do my remote work.
> My Question.
> When i try and create a new project for RSE i am having problems.
> Here are my steps.
> My RSE connection is setup using sftp and if i am in the Remote System
> Perspective i can view files on the remote system and work with them.
> 1. Create new project. I select PHP Project click next. 2. add my prject
> name and de-select the "Use default location" button and pick RSE 3.
> click the browse button. When i do this even if my connection is the
> remote box i don't get the remote tree view. I select a different
> connection and then back to the connection that i want. I will then get
> the remote system tree view.
> 4. Select the directory that i want to base my project off of. Click ok
> 5. Then i will see rse://my.server.tld/my/remote/path. click finish...
> nothing happens. I don't get an error, or any prompt and the new project
> is not created. Is there something that i am doing wrong? Do i need a
> dstore for this? I am not the admin of the remote system and do not have
> root access. So i can not put the dstore software on that machine.
> My setup.
> Fedora Core 5
> Linux 2.6.17-1.2187_FC5smp
> Eclipse Version: 3.2.1
> Build id: M20060921-0945
> Java from Sun
> Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
> Java HotSpot(TM) Client VM (build 1.5.0_06-b05, mixed mode, sharing)
> RSE Core 1.0.0.v20060928------AXrVWXfeYa
> RSE Dstore Connector Service 1.0.0.v20061006
> RSE Dstore Core 1.0.0.v20061006
> RSE Dstore Files 1.0.0.v20061006
> RSE Dstore Platform Support 1.0.0.v20061006
> RSE Dstore Services 1.0.0.v20061006
> RSE Dstore Shells 1.0.0.v20061006
> RSE Dstore SSL Support 1.0.0.v20061006
> RSE EFS Support 1.0.0.v20061006
> RSE Files Core 1.0.0.v20061006
> RSE Files UI 1.0.0.v20061006
> RSE FTP Files 1.0.0.v20061008
> RSE FTP Services 1.0.0.v20061007
> RSE SSH Connector Service 1.0.0.v20060921
> I have many more than these, if you need an full list, or if i need to
> have a specific plugin install please let me know.
> Again thanks for the great plugin. It is something that has helped me
> get eclipse on more desktops here at the shop.
Martin Oberhuber
Wind River Systems, Inc.
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Re: Remote Project [message #564781 is a reply to message #1533] |
Hello Edward,
bugs:
problems.
Martin
> My Question.
> Here are my steps.
> 5. Then i will see rse://my.server.tld/my/remote/path click finish...
> My setup.
> Fedora Core 5
> Java from Sun
Martin Oberhuber
Current Time: Fri Apr 19 14:42:28 GMT 2024
Powered by FUDForum. Page generated in 0.03201 seconds
