Home » Language IDEs » ServerTools (WTP) » Running custom deployment scripts in WTP possible?
Running custom deployment scripts in WTP possible? [message #188582] Sun, 25 February 2007 13:22 Go to next message
Originally posted by: matthias.kaeppler.dfki.de
I really like that WTP automates so much when building and deploying
webapps, but is it possible at all to tell WTP to incorporate user-defined
intermediary steps in its build/deploy-logic?
For example, we need to sign a JAR-file before deploying it in order to
not break custom security policies, but I haven't found a way to do that
before WTP deploys the WAR to the servlet container. I'd rather not have
to do that by hand each time I recompile the project!
Is that possible at all?
Matthias
Re: Running custom deployment scripts in WTP possible? [message #188858 is a reply to message #188582] Thu, 01 March 2007 04:42 Go to previous messageGo to next message
Anyone? This is really important for us, any help/hints appreciated.
Re: Running custom deployment scripts in WTP possible? [message #189603 is a reply to message #188858] Sun, 11 March 2007 17:54 Go to previous messageGo to next message
I'm not an expert here, but I can give you a hint.
You should be able to write an ant script or task to do the jar signing.
Then go to your project's properties and select the "Builder" -item in
the list. There you can add additional steps to the build process. Don't
know how to add your new ant script, but I'm hopeful you'll figure it out.
K<o>
Busy, supporting non technical users at Plan-B for OpenOffice.org -
http://openoffice.screencast-tutorials.com/
Re: Running custom deployment scripts in WTP possible? [message #189714 is a reply to message #188582] Mon, 12 March 2007 13:59 Go to previous message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Matthias,
take a look at the JBoss plugin, file
eclipse\plugins\org.eclipse.jst.server.generic.jboss_1.5.1.v 200609140551\buildfiles\jboss323.xml
This ant script is run when packaging and deploying the files to the server, so
you could simply modify it to include your custom tasks.
For other server types it should work the same way.
Hope this helps
Wolfgang
> user-defined intermediary steps in its build/deploy-logic?
> Matthias
Previous Topic:WSGEN : WSDL URL in axisclient.properties
Next Topic:How to convert a former web project into a utility project?
Current Time: Tue Mar 18 23:54:52 EDT 2025
Powered by FUDForum. Page generated in 0.03181 seconds
