Home » Language IDEs » ServerTools (WTP) » wsgen failing on ScenarioType
wsgen failing on ScenarioType [message #187634] Tue, 06 February 2007 21:37 Go to next message
Originally posted by: dtinney.shaw.ca
I'm trying to generate a Web Service Proxy client from a .WSDL file and I
can't get around wsgen failing with a "cannot determine scenario type"
error. Here are the files involved in the configuration:
wsgen.xml
<?xml version="1.0"?>
<project default="main" basedir=".">
<echo message="pulling in property files"/>
<property file ="axisclient.properties"/>
<echo message="${ScenarioType}"/>
<echo message="calling the web services generation ant task: wsgen"/>
<target name="main" >
<wsgen/>
</target>
</project>
!--ScenarioType REQUIRED. Differentiates from "service" scenario. See
axisservice.properties.
ScenarioType=client
!--InitialSelection REQUIRED. Workspace relative URI to the input WSDL or
Java.
!InitialSelection=/dynamicWebProjectName/WebContent/wsdl/myS ervice.wsdl
InitialSelection=/AboutTime.wsdl
and here is the output:
Buildfile: D:\Documents and Settings\Derek Tinney\My Eclipse
Workspaces\Projects\Scratch\wsgen.xml
[echo] pulling in property files
[echo] D:\Documents and Settings\Derek Tinney\My Eclipse
[echo] client
[echo] calling the web services generation ant task: wsgen
main:
[wsgen] Cannot determine scenario type. Please ensure ScenarioType Ant
property is set.
BUILD SUCCESSFUL
Total time: 181 milliseconds
Despite the output message, the build is clearly not successful and the
${ScenarioType} is set in the current context, does anyone have any pointers
for what I can do to remedy this?
Cheers, Derek.
Re: wsgen failing on ScenarioType [message #187731 is a reply to message #187634] Wed, 07 February 2007 13:09 Go to previous messageGo to next message
When I use the ant tasks to create web services or clients I have
initial selection in the properties file set to something like:
InitialSelection=/dynamicWebProjectName/WebContent/wsdl/mySe rvice.wsdl
In your properties file you don't have a project name in the path to
your initial selection. Is there a reason for this? There is a
tutorial about the web services Ant tasks at
http://www.eclipse.org/webtools/jst/components/ws/1.0/tutori als/WebServiceAntTask/WebServiceAntTask.html
that might be helpful
Another way of creating a client client without using these ant files is
to right click on the WSDL and select Web Services > Generate Client.
The Tutorial at
http://www.eclipse.org/webtools/jst/components/ws/1.5/tutori als/WebServiceClient/WebServiceClient.html
shows how to create a Web Service Client from a WSDL.
Hope this helps,
Mark
Derek Tinney wrote:
> wsgen.xml
> <wsgen/>
> </target>
> </project>
> ScenarioType=client
> Java.
> [echo] client
> main:
> property is set.
> BUILD SUCCESSFUL
> Cheers, Derek.
Re: wsgen failing on ScenarioType [message #187864 is a reply to message #187731] Fri, 09 February 2007 03:39 Go to previous messageGo to next message
Thanks, I was working from that article, I updated my Eclipse Web Tools and
got the option you referred to. I was working from the referenced article
but was struggling with adapting that workflow to my situation where I'm
working to an external .NET Web Service that I don't control and can't
deploy.
I"m now contacting that WS but can't authenticate, but that's another post.
Derek.
"Mark Hutchinson" <mahutch@ca.ibm.com> wrote in message
news:eqd4k8$c4o$1@utils.eclipse.org...
> When I use the ant tasks to create web services or clients I have initial
> In your properties file you don't have a project name in the path to your
> initial selection. Is there a reason for this? There is a tutorial about
> to right click on the WSDL and select Web Services > Generate Client. The
> Tutorial at
> Hope this helps,
> Mark
> Derek Tinney wrote:
>> Hi,
>> wsgen.xml
>> <wsgen/>
>> </target>
>> </project>
>> ScenarioType=client
>> Java.
>> [echo] client
>> main:
>> property is set.
>> BUILD SUCCESSFUL
>> pointers for what I can do to remedy this?
>> Cheers, Derek.
Re: wsgen failing on ScenarioType [message #189537 is a reply to message #187731] Fri, 09 March 2007 18:36 Go to previous message
Originally posted by: srinivas.sampige.directv.com
Mark
Have you tried using the CustomizeClientMappings property? The minute I
uncomment it (even with a value of false) the wsgen build fails with an
"argument type mismatch" error. I am running Eclipse3.2.2 with WTP1.5.2
thanks
Srini
> Tutorial at
> Hope this helps,
> Mark
> Derek Tinney wrote:
>> Hi,
>> wsgen.xml
>> <wsgen/>
>> </target>
>> </project>
>> ScenarioType=client
>> Java.
>> [echo] client
>> main:
>> property is set.
>> BUILD SUCCESSFUL
>> Cheers, Derek.
Previous Topic:WTP, Axis and Tomcat
Next Topic:Dependency trees
Current Time: Sun Mar 16 03:46:32 EDT 2025
Powered by FUDForum. Page generated in 0.03352 seconds
