Home » Eclipse Projects » Eclipse 4 » Part on top of a PartSashContainer
Part on top of a PartSashContainer [message #1181871] Mon, 11 November 2013 22:21 Go to next message
Ralf Heydenreich is currently offline Ralf HeydenreichFriend
Hi all,
I've the following configuration in my Application.e4xmi:
+-------- Trimmed Window
  +------ Controls
    +---- Perspective Stack
      +-- Controls
        + Part
        + PartSashContainer
The Part gets rendered always left besides PartSash Container (I think it's of org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer#createWidget, where the composite is created with new FillLayout(SWT.VERTICAL)). How can I achieve that the Part is rendered on top of PartSashContainer?
Thanks in advance,
Ralf.
Re: Part on top of a PartSashContainer [message #1182537 is a reply to message #1181871] Tue, 12 November 2013 08:52 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
On 11.11.13 23:21, Ralf Heydenreich wrote:
> Hi all,
> +------ Controls
> +-- Controls
> + Part
> + PartSashContainer
> it's of
> Thanks in advance,
> Ralf.
Make it look like:
Controls
+ PartSashContainer (vertical)
+ Part
+ PartSashContainer
Tom
Re: Part on top of a PartSashContainer [message #1182781 is a reply to message #1182537] Tue, 12 November 2013 12:08 Go to previous messageGo to next message
This works, but I want to fix the divider. Like this:
|C|O|O|L|B|A|R  |
+---------------+  <-- this divider shouldn't be moveable!
| Application   |
| area          |
I can't use the trimmed toolbar, because I didn't found a possibility to put larger icons on it with text beneath.
How can I get this?
Ralf.
Re: Part on top of a PartSashContainer [message #1182806 is a reply to message #1182781] Tue, 12 November 2013 12:26 Go to previous messageGo to next message
This is not supported by the e4 SWT implementation. You'd have to create
a custom PartSashRenderer.
The JavaFX renderer support this but well they are for FX ;-)
Tom
> |C|O|O|L|B|A|R |
> | Application | | area |
> put larger icons on it with text beneath. How can I get this?
> Ralf.
Re: Part on top of a PartSashContainer [message #1182812 is a reply to message #1181871] Tue, 12 November 2013 12:33 Go to previous messageGo to next message
Andrzej Szczepanski is currently offline Andrzej SzczepanskiFriend
Just add ToolControl instead of ToolBar as contents of your window's Top TrimBar.
You create contents of ToolControl like you do for MPart - with @PostConstruct annotated method in class contribution. That's where you can create yout custom CoolBar widget.
Re: Part on top of a PartSashContainer [message #1182835 is a reply to message #1182812] Tue, 12 November 2013 12:51 Go to previous messageGo to next message
.... but then he has no Toolbar ;-)
Tom
> TrimBar.
Re: Part on top of a PartSashContainer [message #1182855 is a reply to message #1182835] Tue, 12 November 2013 13:10 Go to previous messageGo to next message
Sure, but I thought he gave up on toolbar already anyway. With items being of wrong size or something.
Re: Part on top of a PartSashContainer [message #1183419 is a reply to message #1182812] Tue, 12 November 2013 21:22 Go to previous message
Am 12.11.2013 13:33, schrieb Andrzej Szczepanski:
> TrimBar.
Hi Andrzej,
this was exactly what I'd looked for. Works perfectly. Thanks!
Ralf.
Previous Topic:DI Injection for Handlers
Next Topic:perspective bar
Current Time: Tue Jul 07 16:58:45 GMT 2020
Powered by FUDForum. Page generated in 0.02502 seconds
