Home » Modeling » TMF (Xtext) » Create an Eclipse product(Setting up a RCP product for a Xtext DSL )
Create an Eclipse product [message #1180990] Mon, 11 November 2013 09:44 Go to next message
Sofia Nom is currently offline Sofia NomFriend
Hello, I'm trying to set up a RCP product for my DSL and I have many problems. First of all, I did the validation with the valid button and after adding all of the plug-ins needed (I didn't have any equinox.internal plug-in),I still have problems. Some of the problems I'm getting are:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-11-11 10:56:59.742
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime.compatibility.registry_3.5.200.v20130514-1256/ was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime.compatibility.registry 2 0 2013-11-11 10:56:59.742
!MESSAGE Missing required capability Require-Capability: osgi.ee; filter="(|(&(osgi.ee=CDC/Foundation)(version=1.0))(&(osgi.ee=JavaSE)(version=1.3)))".
!ENTRY org.eclipse.osgi 2 0 2013-11-11 10:56:59.745
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-11-11 10:56:59.745
!MESSAGE Bundle org.eclipse.core.runtime.compatibility.registry_3.5.200.v20130514-1256 [202] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime.compatibility.registry 2 0 2013-11-11 10:56:59.745
!ENTRY org.eclipse.osgi 4 0 2013-11-11 10:56:59.747
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.equinox.app.error, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.jdt.core.JavaIndexer, org.eclipse.emf.mwe.core.WorkflowRunner.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
!ENTRY org.eclipse.e4.ui.css.swt.theme 4 0 2013-11-11 10:56:59.772
!MESSAGE [SCR] Error while attempting to deactivate instance of component Component[
name = org.eclipse.e4.ui.css.swt.theme
activate = activate
deactivate = deactivate
modified =
configuration-policy = optional
factory = null
autoenable = true
immediate = true
implementation = org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager
state = Disabled
properties =
serviceFactory = false
serviceInterface = [org.eclipse.e4.ui.css.swt.theme.IThemeManager]
references = null
located in bundle = org.eclipse.e4.ui.css.swt.theme_0.9.100.v20130515-1857 [182]
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Display
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Unknown Source)
at java.lang.Class.getDeclaredMethods(Unknown Source)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.getMethod(ServiceComponent.java:126)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.deactivate(ServiceComponent.java:337)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.deactivate(ServiceComponentProp.java:161)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.dispose(ServiceComponentProp.java:387)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.dispose(ServiceComponentProp.java:102)
at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:366)
at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:306)
at org.eclipse.equinox.internal.ds.Resolver.disposeComponentConfigs(Resolver.java:724)
at org.eclipse.equinox.internal.ds.Resolver.disableComponents(Resolver.java:700)
at org.eclipse.equinox.internal.ds.SCRManager.stoppingBundle(SCRManager.java:554)
at org.eclipse.equinox.internal.ds.SCRManager.bundleChanged(SCRManager.java:233)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1568)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1504)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1499)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:506)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:566)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1206)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:592)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:284)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:692)
at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:600)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:200)
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.widgets.Display cannot be found by org.eclipse.e4.ui.css.swt.theme_0.9.100.v20130515-1857
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
... 39 more
!ENTRY org.eclipse.e4.ui.css.swt.theme 4 0 2013-11-11 10:56:59.775
activate = activate
modified =
factory = null
autoenable = true
immediate = true
state = Disabled
properties =
references = null
!STACK 0
... 39 more
Re: Create an Eclipse product [message #1181536 is a reply to message #1180990] Mon, 11 November 2013 17:15 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
did you have a look at the product file i added to http://www.eclipse.org/forums/index.php/t/582592/
Twitter : @chrdietrich
Previous Topic:[Xbase] getting the result type of an expression during inferring
Next Topic:How to make the default value of "Literals Interface" to be "true"
Current Time: Tue Apr 16 23:18:17 GMT 2024
Powered by FUDForum. Page generated in 4.21473 seconds
