Home » Language IDEs » ServerTools (WTP) » errors: can't resolve java.lang.Object and errors in xsd
errors: can't resolve java.lang.Object and errors in xsd [message #187138] Fri, 26 January 2007 13:16 Go to next message
A new developer downloaded Eclipse 3.2.1 and then used the update manager
to do a complete download and install of Callisto. He started with a new
workspace. He is using jdk 1.5.0_10. He is having two serious problems:
1. If he creates a new dynamic web application, eclipse gives the
following error for the automatically created web.xml:
Referenced file contains errors
( http://www.ibm.com/webservices/xsd/j2ee_web_services_client_ 1_1.xsd).
For more information, right click on the message and select "Show
Details..." acua/WebContent/WEB-INF web.xml line 1 1169833955001 44
2. In an existing Web Services application that has no errors using older
an older version of wtp 1.5 a java files shows the following errors:
The project was not built since its build path is incomplete. Cannot find
the class file for java.lang.Object. Fix the build path then try building
this project acua Unknown 1169833953649 43
The type java.lang.Object cannot be resolved. It is indirectly referenced
from required .class
files acua/src/com/embarq/acua StatusWBmpClrs.java line 1 1169833953649 42
Another developer duplicated this problem by downloading eclipse 3.2.1,
creating a fresh workspace, and installing the Callisto plugins.
Re: errors: can't resolve java.lang.Object and errors in xsd [message #187190 is a reply to message #187138] Sat, 27 January 2007 15:05 Go to previous messageGo to next message
It is quite possibly that your project doesn't contain JRE libraries or
it contains incorrect JRE libraries.
Check the project's Build Path.
Snjeza
> manager to do a complete download and install of Callisto. He started
> with a new workspace. He is using jdk 1.5.0_10. He is having two serious
> problems:
> 1169833955001 44
> older an older version of wtp 1.5 a java files shows the following errors:
> find the class file for java.lang.Object. Fix the build path then try
> building this project acua Unknown 1169833953649 43
> referenced from required .class files acua/src/com/embarq/acua
Re: errors in xsd [message #187281 is a reply to message #187190] Mon, 29 January 2007 11:04 Go to previous messageGo to next message
There was an invalid entry apparently in the .classpath file. After
correcting this, java.lang.Object related problem is resolved.
However, the following problem still remains. It seems fairly certain that
this is a WTP related problem since it occurs with a pristine
Eclipse3.2/WTP1.5 environment, a new workspace, and any newly created
Dynamic Web Project.
>> with a new workspace. He is using jdk 1.5.0_10. He is having the following
>> problem:
>> 1169833955001 44
Re: errors in xsd [message #187290 is a reply to message #187281] Mon, 29 January 2007 12:06 Go to previous message
I think your remaining problem is covered by Bug 152355 [1], starting at
Comment #11. See [2] and its follow up for what you might do to work
around it for the time being.
Larry
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=152355
[2] http://dev.eclipse.org/newslists/news.eclipse.webtools/msg13 036.html
>> or it contains incorrect JRE libraries.
> that this is a WTP related problem since it occurs with a pristine
>>> following problem:
>>> 1169833955001 44
Previous Topic:Adding a menu contribution to XML Editor
Next Topic:Unable to create new servlet
Current Time: Thu Mar 20 22:00:36 EDT 2025
Powered by FUDForum. Page generated in 0.03401 seconds
