ant builder problem [message #1180627] |
Mon, 11 November 2013 04:06 |
Zhg Mising name Messages: 81 Registered: March 2011 |
Member |
try to use ant builder, I check all path and classpath out, but still get the warining,
[taskdef] Could not load definitions from resource anttasks.properties. It could not be found.
[taskdef] Could not load definitions from resource emma_ant.properties. It could not be found.
-set-mode-check:....
those two jar, anttaskes.jar and emmaant.jar are all in the folder.
what's matter?
how to resolve that?
Re: ant builder problem [message #1181395 is a reply to message #1180627] |
Mon, 11 November 2013 15:22 |
> get the warining,
> what's matter?
You might not get an answer in this forum. This isn't an ant community
forum. You should look around for one of those or try stackoverflow.com
where, I'm betting, you'll get an answer within minutes or hours.
FUDForum. Page generated in 0.08822 seconds
