XML Editor use in WTP 1.5.2 - [message #186967] |
Thu, 25 January 2007 13:59 |
Originally posted by: durchgedreht.gmx.de
I just migrated my development from 1.5.1 to 1.5.2
Now I cannot create the editor as eclipse tells me "Unsupported Content =
Type in editor". I have to register it by hand to XML. I did not have to=
do this in 1.5.1 !?
1) How should I register my own extension to eclipse programmatically?
Here is my Code. I followed the tutorial at
http://www.eclipse.org/webtools/wst/components/sse/tutorials /multipage-e=
ditor-tutorial.html
expect I'm using .jdx instead of .xml as extzension.
2) How can I instantiate the design page?
Please help!
Dennis
Code for the Editor page creation:
protected IEditorSite createSite(IEditorPart page) {
IEditorSite site =3D null;
if (page =3D=3D editor) {
site =3D new MultiPageEditorSite(this, page) {
@SuppressWarnings("restriction")
public String getId() {
// Sets this ID so nested editor is configured for XML source
return ContentTypeIdForXML.ContentTypeID_XML + ".source"; =
//$NON-NLS-1$;
else {
site =3D super.createSite(page);
return site;
Complete code:
(Note that I changed the page order - comments may be irritating :-)
package org.jdeluxe.editors;
import java.io.File;
import java.io.FileOutputStream;
import java.io.PrintStream;
import java.io.StringWriter;
import java.text.Collator;
import java.util.ArrayList;
import java.util.Collections;
import java.util.StringTokenizer;
import org.eclipse.core.resources.IMarker;
import org.eclipse.core.resources.IResourceChangeEvent;
import org.eclipse.core.resources.IResourceChangeListener;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.jface.dialogs.ErrorDialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.StyledText;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.graphics.FontData;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.FontDialog;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IEditorSite;
import org.eclipse.ui.IFileEditorInput;
import org.eclipse.ui.IWorkbenchPage;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.ide.IDE;
import org.eclipse.ui.part.FileEditorInput;
import org.eclipse.ui.part.MultiPageEditorPart;
import org.eclipse.ui.part.MultiPageEditorSite;
import org.eclipse.wst.sse.ui.StructuredTextEditor;
import =
org.eclipse.wst.xml.core.internal.provisional.contenttype.Co ntentTypeIdF=
orXML;
public class JdeluxeMultiPageEditor extends MultiPageEditorPart implemen=
ts =
IResourceChangeListener{
/** The text editor used in XML source editor */
private StructuredTextEditor editor;
/** The font chosen in page 1. */
private Font font;
/** The text widget used in page 2. */
private StyledText text;
* Creates a multi-page editor example.
public JdeluxeMultiPageEditor() {
super();
System.out.println("Start test");
getXmlDb();
System.out.println("end test");
ResourcesPlugin.getWorkspace().addResourceChangeListener(thi s);
* Creates page 0 of the multi-page editor,
* which shows the sorted text.
void createPage0() {
Composite composite =3D new Composite(getContainer(), SWT.NONE);
FillLayout layout =3D new FillLayout();
composite.setLayout(layout);
text =3D new StyledText(composite, SWT.H_SCROLL | SWT.V_SCROLL);
text.setEditable(false);
int index =3D addPage(composite);
setPageText(index, "Preview");
* Creates the xml source editor
void createXMLEditorPage() {
try {
editor =3D new StructuredTextEditor();
int index =3D addPage(editor, getEditorInput());
setPageText(index, editor.getTitle());
} catch (PartInitException e) {
ErrorDialog.openError(
getSite().getShell(),
"Error creating nested text editor",
null,
e.getStatus());
* Creates page 1 of the multi-page editor,
* which allows you to change the font used in page 2.
void createPage2() {
GridLayout layout =3D new GridLayout();
layout.numColumns =3D 2;
Button fontButton =3D new Button(composite, SWT.NONE);
GridData gd =3D new GridData(GridData.BEGINNING);
gd.horizontalSpan =3D 2;
fontButton.setLayoutData(gd);
fontButton.setText("Change Font...");
fontButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent event) {
setFont();
setPageText(index, "Properties");
* Creates the pages of the multi-page editor.
protected void createPages() {
createPage0();
createXMLEditorPage();
createPage2();
* The <code>MultiPageEditorPart</code> implementation of this
* <code>IWorkbenchPart</code> method disposes all nested editors.
* Subclasses may extend.
public void dispose() {
ResourcesPlugin.getWorkspace().removeResourceChangeListener( this);
super.dispose();
* Saves the multi-page editor's document.
public void doSave(IProgressMonitor monitor) {
getEditor(1).doSave(monitor);
* Saves the multi-page editor's document as another file.
* Also updates the text for page 0's tab, and updates this multi-page =
editor's input
* to correspond to the nested editor's.
public void doSaveAs() {
IEditorPart editor =3D getEditor(1);
editor.doSaveAs();
setPageText(1, editor.getTitle());
setInput(editor.getEditorInput());
/* (non-Javadoc)
* Method declared on IEditorPart
public void gotoMarker(IMarker marker) {
setActivePage(1);
IDE.gotoMarker(getEditor(1), marker);
* The <code>MultiPageEditorExample</code> implementation of this metho=
d
* checks that the input is an instance of <code>IFileEditorInput</code=
public void init(IEditorSite site, IEditorInput editorInput)
throws PartInitException {
if (!(editorInput instanceof IFileEditorInput))
throw new PartInitException("Invalid Input: Must be IFileEditorInput"=
super.init(site, editorInput);
/* (non-Javadoc)
* Method declared on IEditorPart.
public boolean isSaveAsAllowed() {
return true;
* Calculates the contents of page 2 when the it is activated.
protected void pageChange(int newPageIndex) {
super.pageChange(newPageIndex);
if (newPageIndex =3D=3D 2) {
sortWords();
* Closes all project files on project close.
public void resourceChanged(final IResourceChangeEvent event){
if(event.getType() =3D=3D IResourceChangeEvent.PRE_CLOSE){
Display.getDefault().asyncExec(new Runnable(){
public void run(){
IWorkbenchPage[] pages =3D getSite().getWorkbenchWindow().getPages(=
for (int i =3D 0; i<pages.length; i++){
if(((FileEditorInput)editor.getEditorInput()).getFile().getP roject=
().equals(event.getResource())){
IEditorPart editorPart =3D =
pages[i].findEditor(editor.getEditorInput());
pages[i].closeEditor(editorPart,true);
* Sets the font related data to be applied to the text in page 2.
void setFont() {
FontDialog fontDialog =3D new FontDialog(getSite().getShell());
fontDialog.setFontList(text.getFont().getFontData());
FontData fontData =3D fontDialog.open();
if (fontData !=3D null) {
if (font !=3D null)
font.dispose();
font =3D new Font(text.getDisplay(), fontData);
text.setFont(font);
* Sorts the words in page 0, and shows them in page 2.
void sortWords() {
String editorText =3D
editor.getDocumentProvider().getDocument(editor.getEditorInp ut()).get=
StringTokenizer tokenizer =3D
new StringTokenizer(editorText, " =
\t\n\r\f!@#\u0024%^&*()-_=3D+`~[]{};:'\",.<>/?|\\");
ArrayList editorWords =3D new ArrayList();
while (tokenizer.hasMoreTokens()) {
editorWords.add(tokenizer.nextToken());
Collections.sort(editorWords, Collator.getInstance());
StringWriter displayText =3D new StringWriter();
for (int i =3D 0; i < editorWords.size(); i++) {
displayText.write(((String) editorWords.get(i)));
displayText.write(System.getProperty("line.separator"));
text.setText(displayText.toString());
* @see =
org.eclipse.ui.part.MultiPageEditorPart#createSite(org.eclip se.ui.IEdito=
rPart)
//$NON-NLS-1$;
else {
return site;
private void getXmlDb(){
Re: XML Editor use in WTP 1.5.2 - [message #187114 is a reply to message #187085] |
Fri, 26 January 2007 15:25 |
Thanks for your answer.
1) This was a good idea! I did configure it, but it seems I did somethin=
g =
wrong. When I delete the contenttype setting in the runtime Eclipse that=
I =
added myself, it will throw an error "contenttype not supported". So I'm=
doing something wrong!
<extension
id=3D"org.eclipse.core.contenttype.contentTypes"
name=3D"Jdeluxe"
point=3D"org.eclipse.core.contenttype.contentTypes">
<file-association
content-type=3D"org.eclipse.core.runtime.xml"
file-extensions=3D"jdx"
</extension>
2) Does this mean, I will see it every time I use the XML Editor or does=
this mean I cannot see the design page inside my Multipage Editor at all=
Thanks for your help!
Dennis
Am 26.01.2007, 14:23 Uhr, schrieb Nitin Dahyabhai <nitind@us.ibm.com>:
>> Now I cannot create the editor as eclipse tells me "Unsupported Conte=
nt =
>> Type in editor". I have to register it by hand to XML. I did not have=
>> to do this in 1.5.1 !?
>> 1) How should I register my own extension to eclipse programmaticall=
y?
>> http://www.eclipse.org/webtools/wst/components/sse/tutorials /multipag=
e-editor-tutorial.html =
> In both versions, you would have had to tell the platform to treat *.j=
dx =
> like XML (you're certain you didn't do something similar under 1.5.1?)=
> The org.eclipse.core.runtime.contentTypes extension point is how you =
> would do so, either by using a file-association element to associate =
> .jdx with the XML content type or by using the content-type element to=
> make a new subtype of the XML content type.
> http://help.eclipse.org/help32/topic/org.eclipse.platform.do c.isv/refe=
rence/extension-points/org_eclipse_core_contenttype_contentT ypes.html
> The design page is internal and not meant to be instantiated outside o=
f =
> the XML Editor itself.
> Nitin Dahyabhai
> Structured Source Editor
Erstellt mit Operas revolution=C3=A4rem E-Mail-Modul: http://www.opera.c=
om/mail/
FUDForum. Page generated in 0.02547 seconds
