Preventing external loading of xsd [message #186708] |
Mon, 22 January 2007 08:15  |
Originally posted by: mllist.mvdb.net
Hi everyone,
I tried to figure out an easy wat to programatically prevent the xml editor from loading my xsd from
an external location, but without any success.
If anyone has any pointers (or preferrably examples), that would be highly appreciated.
Just an FYI : I will have to write a custom xml editor eventually, so a solution/example in that
direction is also acceptable.
TIA :)
Mvgr,
Martin
Re: Preventing external loading of xsd [message #187122 is a reply to message #187047] |
Fri, 26 January 2007 12:22   |
Originally posted by: valentinbaciu.hotmail.com
Martin, the XML core plug-in org.eclipse.wst.xml.core provides an API
(provisional, it's true) and an extension point mechanism that allow you to
programmatically or declaratively contribute content to the catalog. The
extension point mechanism is used - for example - by the org.wsdl4j plug-in
to contribute the WSDL schemas to the catalog. Use it as an example.I'm sure
you'll find examples of the API usage in our unit tests.
I hope this helps.
Regards, Valentin
"Martin van den Bemt" <mllist@mvdb.net> wrote in message
news:epcfl1$13o$1@utils.eclipse.org...
> Thanx for the reply craig.
> The problem is that that is not an API.. I need to automatically register
> my xsd's so the xsd's are
> loaded from my plugin. I prefer that the user doesn't have to any manual
> configuration for this.
> Mvgr,
> Martin
> craig wrote:
>> Have you tried using the XML Catalog? See the tutorial here :
>> http://www.eclipse.org/webtools/community/tutorials/XMLCatal og/XMLCatalogTutorial.html
>> Martin van den Bemt wrote:
>>> Does no one have an idea about this ?
>>> Mvgr,
>>> Martin
>>>> Hi everyone,
>>>> editor
>>>> highly
>> appreciated.
>>>> TIA :)
>>>> Mvgr,
>>>> Martin
Re: Preventing external loading of xsd [message #187130 is a reply to message #187122] |
Fri, 26 January 2007 12:29  |
Thanx Valentin, I'll have a look at the wsdl4j plugin..
Mvgr,
Martin
> I hope this helps.
> Regards, Valentin
>> Mvgr,
>> Martin
>>>> Mvgr,
>>>> Martin
>>>>> Hi everyone,
>>>>> editor
>>>>> highly
>>> appreciated.
>>>>> TIA :)
>>>>> Mvgr,
>>>>> Martin
FUDForum. Page generated in 0.04359 seconds
