Home » Language IDEs » ServerTools (WTP) » How to deploy in tomcat webapps dir
How to deploy in tomcat webapps dir [message #186637] Sun, 21 January 2007 13:00 Go to next message
Originally posted by: markusin.yahoo.de
Hi to everyone,
I am trying to change the deploy directory to the tomcat webapps
directory, but I wasn't able to do that.
The problem is, that eclipse wtp deploy always internally in
..metadata/.plugins/org.eclipse.wst.server.core/
is there a way to change that?
Thanks for any helpful answer.
Markus
Re: How to deploy in tomcat webapps dir [message #186646 is a reply to message #186637] Sun, 21 January 2007 12:01 Go to previous messageGo to next message
Originally posted by: hicham.dev.menara.ma
exquisitus wrote:
> Hi to everyone,
> Markus
Hello
all you need to do is "export your web application as a .war file to the
tomcat webapps dir
cheers
Hicham
Re: How to deploy in tomcat webapps dir [message #186654 is a reply to message #186646] Sun, 21 January 2007 14:02 Go to previous messageGo to next message
hi hicham,
ok, this is something I know, but I would like to use the integrated
deploy tools of wtp, where you can publish, etc... via button click.
To create a jar every time is not so confortable.
Probably there should be another way. I was used it from myeclipse to
have such a deploy tool, and it's really useful, mainly when you
republish a lot.
Markus
Re: How to deploy in tomcat webapps dir [message #186662 is a reply to message #186654] Sun, 21 January 2007 14:53 Go to previous messageGo to next message
Now I was able to solve that problem.
By doubleclicking on the server you can edit that configuration. There
you need only to disable the option "Run modules directly from the
workspace" and than my webapplications where deployed to the
tomcat-webapps directory.
Markus
Re: How to deploy in tomcat webapps dir [message #186734 is a reply to message #186637] Mon, 22 January 2007 10:02 Go to previous message
In the works for the Tomcat support in WTP 2.0 is the ability to specify
the deployment directory where web applications are published, relative
to catalina.base or absolute, and the ability to specify the
catalina.base. To track these changes, you can follow bugs [1] and [2],
respectively. As you mentioned in a different e-mail, the only thing
that has any impact at the moment is the "Run modules directly..." option.
Larry
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=145834
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=107722
exquisitus wrote:
> Hi to everyone,
> Markus
Previous Topic:Problem Deleting Web App Jars
Next Topic:Strange classloading problem when using 2.0
Current Time: Mon Mar 17 18:44:00 EDT 2025
Powered by FUDForum. Page generated in 0.04383 seconds
