Re: getGlobalVariable() problem in Chart script [message #186801 is a reply to message #186624] |
Thu, 24 August 2006 16:19 |
Try,
context.getExternalContext().getScriptable().getGlobalVariab le
Jason
"Tomomi" <tomoino@netzero.net> wrote in message
news:ecg56a$fot$1@utils.eclipse.org...
>> gTest is set in report.initialize area and I attempted to get this
>> variable.
> mistake. not gTest. "gVar" is set in ....
> news:ecg423$5pb$1@utils.eclipse.org...
>> Inside the chart script, I would like to use the global variable which
>> is set in the report.
>> I used getGlobalVariable() or getPersistentGlobalVariable() but this
>> function does not return anything
>> while getParameterValue() works well.
>> Here are my code;
>> variable. It does not work.
>> repCtx = context.getExternalContext();
>> objRef = repCtx.getObject();
>> param = objRef.getGlobalVariable("gVar");
>> If I obtain a report parameter, it works.
>> param = objRef.getParameterValue("param");
>> Is this bug???
>> By the way, I tested on BIRT 2.0 and 2.1.
Re: getGlobalVariable() problem in Chart script [message #187888 is a reply to message #187640] |
Tue, 29 August 2006 16:29 |
You need to do this in the beforegeneration script like:
function beforeGeneration( chart, context ){
importPackage(Packages.org.eclipse.birt.chart.model.attribut e);
importPackage(Packages.org.eclipse.birt.chart.model.data.imp l);
chrmax =
context.getExternalContext().getScriptable().getGlobalVariab le( "cmax");
xaxis = chart.getPrimaryBaseAxes( )[0];
yaxis = chart.getPrimaryOrthogonalAxis( xaxis );
yaxis.getScale().setStep(200000);
yaxis.getScale().setMax( NumberDataElementImpl.create( chrmax ));
Attached is an example report. Look in the initialize method to set how
cmax is set.
Jason
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.2"
id="1">
<property name="author">Mark Coggins</property>
<property name="createdBy">Eclipse BIRT Designer Version 1.0.0 Build
<20050601-0809></property>
<property name="units">in</property>
<text-property name="title">Top Classic Models Inc. Customers by
Revenue</text-property>
<method name="initialize"><![CDATA[reportContext.setGlobalVariable( "cmax",
1000000);]]></method>
<list-property name="configVars">
<structure>
<property name="name">Top Count</property>
<property name="value">5</property>
</structure>
<structure>
<property name="name">Top Percentage</property>
<property name="value">25</property>
</structure>
</list-property>
<parameters>
<scalar-parameter name="Top Count" id="87">
<text-property name="helpText">Enter the number of customers you wish
included in the top "N" graph of the report</text-property>
<property name="valueType">static</property>
<property name="dataType">decimal</property>
<text-property name="promptText">Number of Customers for Top "N"
Chart</text-property>
<property name="allowBlank">false</property>
<property name="allowNull">false</property>
<property name="controlType">text-box</property>
<property name="defaultValue">5</property>
<structure name="format">
<property name="category">Unformatted</property>
<property name="pattern">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="Top Percentage" id="88">
<text-property name="helpText">Enter the percentage of customers you wish
included in the top N% listing of the report</text-property>
<text-property name="promptText">Percentage of Customers for Top N%
Listing</text-property>
<property name="defaultValue">25</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
name="Classic Models" id="59">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Customer Sales" id="60">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CUSTOMERTOTAL</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Classic Models</property>
<property name="queryText">select CUSTOMERS.CUSTOMERNAME,
CUSTOMERS.CUSTOMERNUMBER,
sum(ORDERDETAILS.QUANTITYORDERED *
ORDERDETAILS.PRICEEACH) as CUSTOMERTOTAL
from CUSTOMERS, ORDERS, ORDERDETAILS
where CUSTOMERS.CUSTOMERNUMBER = ORDERS.CUSTOMERNUMBER
and ORDERS.ORDERNUMBER = ORDERDETAILS.ORDERNUMBER
group by CUSTOMERS.CUSTOMERNAME, CUSTOMERS.CUSTOMERNUMBER
order by CUSTOMERTOTAL</property>
</oda-data-set>
</data-sets>
<styles>
<style name="BackgroundLightGray" id="2">
<property name="backgroundColor">#EAEAEA</property>
</style>
<style name="BackgroundBlue" id="3">
<property name="backgroundColor">#4B6987</property>
</style>
<style name="BackgroundYellow" id="4">
<property name="backgroundColor">#FAD764</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="8">
<page-footer>
<grid id="141">
<property name="width">100%</property>
<column id="143">
<property name="width">80%</property>
</column>
<column id="144">
<property name="width">20%</property>
<property name="textAlign">right</property>
</column>
<row id="152">
<property name="height">0.2in</property>
<cell id="153"/>
<cell id="154"/>
</row>
<row id="145">
<cell id="148">
<text id="149">
<property name="fontSize">10pt</property>
<property name="fontStyle">italic</property>
<property name="paddingLeft">5pt</property>
<property name="contentType">html</property>
<text-property name="content"><![CDATA[Top <VALUE-OF>params["Top
Count"]</VALUE-OF> / Top <VALUE-OF>params["Top Percentage"]</VALUE-OF>%
Customers by Revenue]]></text-property>
</text>
</cell>
<cell id="150">
<text id="151">
<property name="paddingRight">5pt</property>
<text-property name="content"><![CDATA[Page:
<value-of>pageNumber</value-of>]]></text-property>
</text>
</cell>
</row>
</grid>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="10">
<column id="11">
<property name="width">2.8in</property>
</column>
<column id="12">
<property name="width">3.2in</property>
</column>
<row id="13">
<property name="style">BackgroundLightGray</property>
<cell id="14">
<property name="paddingRight">10pt</property>
<image id="15">
<property name="borderBottomColor">#808080</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">thin</property>
<property name="borderLeftColor">#808080</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">thin</property>
<property name="borderRightColor">#808080</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">thin</property>
<property name="borderTopColor">#808080</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">thin</property>
<property name="imageName">C:\Documents and Settings\pclenahan\My
Documents\ClassicModels\logos\Classic-Models-Full-M.jpg</property >
</image>
</cell>
<cell id="16">
<property name="verticalAlign">middle</property>
<label id="17">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">20pt</property>
<property name="fontWeight">bold</property>
<property name="color">#000080</property>
<text-property name="text">Classic Models, Inc.</text-property>
</label>
<text id="18">
<property name="fontSize">12pt</property>
<property name="paddingTop">5pt</property>
<property name="paddingBottom">5pt</property>
<text-property name="content"><![CDATA[701 Gateway Boulevard, San Francisco,
CA 94107]]></text-property>
</text>
<text id="90">
<property name="fontSize">16pt</property>
</text>
</cell>
</row>
<row id="20">
<property name="height">0.25in</property>
<cell id="21"/>
<cell id="22"/>
</row>
</grid>
<grid id="23">
<column id="24"/>
<row id="25">
<property name="height">0.1in</property>
<property name="style">BackgroundBlue</property>
<cell id="26"/>
</row>
<row id="27">
<cell id="28">
<text id="91">
Count"]</VALUE-OF> Customers]]></text-property>
</text>
</cell>
</row>
<row id="30">
<cell id="31">
<extended-item extensionName="Chart" id="32">
<property name="height">250pt</property>
<property name="width">400pt</property>
<property name="dataSet">Customer Sales</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["CUSTOMERTOTAL"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
</list-property>
<xml-property name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Side-by-side</SubType>
<Description>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Description>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Name>SansSerif</Name>
<Size>24.0</Size>
<Bold>false</Bold>
<Italic>false</Italic>
<Strikethrough>false</Strikethrough>
<Underline>false</Underline>
<Alignment>
<horizontalAlignment>Left</horizontalAlignment>
<verticalAlignment>Top</verticalAlignment>
</Alignment>
<Rotation>0.0</Rotation>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
<Visible>true</Visible>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value><undefined></Value>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Series</ItemType>
<Title>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<ShowValue>false</ShowValue>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>399.75</Width>
<Height>249.75</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Script>
chrmax =
context.getExternalContext().getScriptable().getGlobalVariab le("cmax");
</Script>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<GridColumnCount>1</GridColumnCount>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>'6.0','7.0','8.0'</DataSetRepresentation >
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5.0,4.0,12.0</DataSetRepresentation >
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
<AncillarySampleData>
<DataSetRepresentation>Series 1</DataSetRepresentation>
</AncillarySampleData>
</SampleData>
<Interactivity>
<Enable>true</Enable>
<LegendBehavior>None</LegendBehavior>
</Interactivity>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>75</Red>
<Green>105</Green>
<Blue>135</Blue>
</Entries>
</SeriesPalette>
<FormatSpecifier xsi:type="attribute:NumberFormatSpecifier">
<Prefix></Prefix>
<Suffix></Suffix>
<FractionDigits>0</FractionDigits>
</FormatSpecifier>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["CUSTOMERTOTAL"]</Definition >
</DataDefinition>
<SeriesIdentifier><undefined></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
<Riser>Rectangle</Riser>
<RiserOutline>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</RiserOutline>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<Max xsi:type="data:NumberDataElement">
<Value>860000.0</Value>
</Max>
<Step>100000.0</Step>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<AncillaryAxes>
<Type>Text</Type>
<Title>
<Caption>
<Value>Z-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<Orientation>Horizontal</Orientation>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Below</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
</AncillaryAxes>
<SeriesDefinitions>
<Query>
<Definition>Base Series</Definition>
</Query>
<SeriesPalette>
<Red>128</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>254</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>254</Red>
<Green>204</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>254</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>254</Red>
<Green>102</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>204</Green>
<Blue>254</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["CUSTOMERNAME"]</Definition >
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
Re: getGlobalVariable() problem in Chart script [message #188022 is a reply to message #187888] |
Tue, 29 August 2006 19:47 |
Tomomi Messages: 28 Registered: July 2009 |
Junior Member |
Jason,
It worked after I corrected the way of setting the global variable.
Thank you for your help!!!!
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:ed1q0c$dut$1@utils.eclipse.org...
> chrmax =
> cmax is set.
> Jason
> id="1">
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <parameters>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <grid id="141">
> <column id="143">
> </column>
> <column id="144">
> </column>
> <row id="152">
> <cell id="153"/>
> <cell id="154"/>
> </row>
> <row id="145">
> <cell id="148">
> <text id="149">
> </text>
> </cell>
> <cell id="150">
> <text id="151">
> </text>
> </cell>
> </row>
> </grid>
> </page-footer>
> </page-setup>
> <body>
> <grid id="10">
> <column id="11">
> </column>
> <column id="12">
> </column>
> <row id="13">
> <cell id="14">
> <image id="15">
> </image>
> </cell>
> <cell id="16">
> <label id="17">
> </label>
> <text id="18">
> Francisco, CA 94107]]></text-property>
> </text>
> <text id="90">
> </text>
> </cell>
> </row>
> <row id="20">
> <cell id="21"/>
> <cell id="22"/>
> </row>
> </grid>
> <grid id="23">
> <column id="24"/>
> <row id="25">
> <cell id="26"/>
> </row>
> <row id="27">
> <cell id="28">
> <text id="91">
> </text>
> </cell>
> </row>
> <row id="30">
> <cell id="31">
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <Description>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Description>
> <Block>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Label>
> <Caption>
> <Font>
> <Size>24.0</Size>
> <Bold>false</Bold>
> <Alignment>
> </Alignment>
> </Font>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>0.0</Left>
> <Right>0.0</Right>
> </Insets>
> </ClientArea>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>2.0</Top>
> <Left>2.0</Left>
> <Right>2.0</Right>
> </Insets>
> </ClientArea>
> <Text>
> <Font>
> <Size>12.0</Size>
> <Bold>false</Bold>
> <Alignment>
> </Alignment>
> </Font>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Text>
> <Separator>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Separator>
> <Title>
> <Caption>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> </Block>
> <Script>
> chrmax =
> </Script>
> <SampleData>
> <BaseSampleData>
> </BaseSampleData>
> </SampleData>
> <Interactivity>
> </Interactivity>
> <Axes>
> <Type>Text</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <AssociatedAxes>
> <Type>Linear</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>75</Red>
> <Green>105</Green>
> <Blue>135</Blue>
> </Entries>
> </SeriesPalette>
> <Prefix></Prefix>
> <Suffix></Suffix>
> </FormatSpecifier>
> <Label>
> <Caption>
> <Font>
> <Size>12.0</Size>
> <Bold>false</Bold>
> <Alignment>
> </Alignment>
> </Font>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataDefinition>
> </DataDefinition>
> <DataPoint>
> <Components>
> </Components>
> </DataPoint>
> <RiserOutline>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </RiserOutline>
> </Series>
> <Grouping>
> </Grouping>
> <LineAttributes>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </LineAttributes>
> <Label>
> <Caption>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <MajorGrid>
> <LineAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </TickAttributes>
> </MajorGrid>
> <MinorGrid>
> <LineAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </TickAttributes>
> </MinorGrid>
> <Scale>
> </Max>
> </Scale>
> <Origin>
> <Type>Min</Type>
> <Value>0.0</Value>
> </Value>
> </Origin>
> </AssociatedAxes>
> <AncillaryAxes>
> <Type>Text</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> </SeriesPalette>
> <Series>
> <Label>
> <Caption>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataPoint>
> <Components>
> </Components>
> </DataPoint>
> </Series>
> <Grouping>
> </Grouping>
> <LineAttributes>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </LineAttributes>
> <Label>
> <Caption>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <MajorGrid>
> <LineAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </TickAttributes>
> </MajorGrid>
> <MinorGrid>
> <LineAttributes>
FUDForum. Page generated in 0.03632 seconds
