Home » Modeling » TMF (Xtext) » Editor cannot be initialized/Unresolved proxy(Noob)
Editor cannot be initialized/Unresolved proxy [message #1179177] |
Sun, 10 November 2013 05:00 |
Gary Worsham Messages: 176 Registered: September 2013 |
I am getting inconsistent behavior in my DSL editor in the second instance of Eclipse Kepler.
Sometimes when I open a DSL source file, it works fine. Other times, it won't open and I get an "Editor cannot be initialized" error. The issue follows specific files (it may be related to a specific instruction). If I restart the Eclipse session it might work OK or be a different set of files. So, some will open and other's won't within the same session.
At the same time, in the console of the first Eclipse instance, I see:
Caused by: java.lang.IllegalStateException: Unresolved proxy http://www.holycityaudio.com/spincad/SpinCAD#//Clr. Make sure the EPackage has been registered.
"Clr" is one of the parser rules. Sometimes it is one of the other parser rules, e.g. "absa". If I quit and restart the second instance of Eclipse, it might work on a file which had been problematic, or it might have a problem with one of the other parser rules.
Here are those rules in my Xtext grammar:
// zero argument instructions
Clr: {Clr} 'clr';
Not: {Not} 'not';
Absa: {Absa} 'absa';
Using Windows 7, 32 bit, 4 GB of RAM (3 GB that is).
So far, all I can tell you is that the rules which seem to be causing problems are the DSL instructions which take zero arguments, such as "clr" and "absa".
I restarted the second Eclipse again and it worked OK. However I get this exception in the console of the first Eclipse:
!MESSAGE com.holycityaudio.spincad.spinCAD.impl.SpinCADFactoryImpl cannot be cast to com.holycityaudio.spincad.spinCADMenu.SpinCADMenuFactory
Note that I have two DSLs in the same project (I ran "Create Xtext project" wizard twice). One is called "SpinCAD" and the other is called "SpinCADMenu". The above message implies to me that there is some confusion having the 2 DSLs side by side.
[Updated on: Sun, 10 November 2013 16:30] Report message to a moderator
Re: Editor cannot be initialized/Unresolved proxy [message #1179220 is a reply to message #1179177] |
Sun, 10 November 2013 05:41 |
Xtend code generator:
* generated by Xtext
package com.holycityaudio.spincad.generator
//import com.google.inject.Inject
import com.holycityaudio.spincad.spinCAD.And
import com.holycityaudio.spincad.spinCAD.ChorusReadDelay
import com.holycityaudio.spincad.spinCAD.ChorusReadValue
import com.holycityaudio.spincad.spinCAD.ReadDelayPointer
import com.holycityaudio.spincad.spinCAD.Element
import com.holycityaudio.spincad.spinCAD.Equate
import com.holycityaudio.spincad.spinCAD.Exp
import com.holycityaudio.spincad.spinCAD.Instruction
import com.holycityaudio.spincad.spinCAD.Jam
import com.holycityaudio.spincad.spinCAD.Label
import com.holycityaudio.spincad.spinCAD.Ldax
import com.holycityaudio.spincad.spinCAD.LoadRampLFO
import com.holycityaudio.spincad.spinCAD.LoadSinLFO
import com.holycityaudio.spincad.spinCAD.Log
import com.holycityaudio.spincad.spinCAD.Mem
import com.holycityaudio.spincad.spinCAD.Mulx
import com.holycityaudio.spincad.spinCAD.Or
import com.holycityaudio.spincad.spinCAD.Program
import com.holycityaudio.spincad.spinCAD.ReadRegister
import com.holycityaudio.spincad.spinCAD.ReadRegisterFilter
import com.holycityaudio.spincad.spinCAD.ScaleOffset
import com.holycityaudio.spincad.spinCAD.Skip
import com.holycityaudio.spincad.spinCAD.WriteAllpass
import com.holycityaudio.spincad.spinCAD.WriteDelay
import com.holycityaudio.spincad.spinCAD.WriteRegister
import com.holycityaudio.spincad.spinCAD.WriteRegisterHighshelf
import com.holycityaudio.spincad.spinCAD.WriteRegisterLowshelf
import com.holycityaudio.spincad.spinCAD.Xor
import org.eclipse.emf.ecore.resource.Resource
import org.eclipse.xtext.generator.IFileSystemAccess
import org.eclipse.xtext.generator.IGenerator
//import org.eclipse.xtext.naming.IQualifiedNameProvider
import com.holycityaudio.spincad.spinCAD.Absa
import com.holycityaudio.spincad.spinCAD.Not
import com.holycityaudio.spincad.spinCAD.Clr
import com.holycityaudio.spincad.spinCAD.Pin
import com.holycityaudio.spincad.spinCAD.AudioInput
import com.holycityaudio.spincad.spinCAD.AudioOutput
import com.holycityaudio.spincad.spinCAD.ControlOutput
import com.holycityaudio.spincad.spinCAD.ControlInput
import com.holycityaudio.spincad.spinCAD.InputPin
import com.holycityaudio.spincad.spinCAD.OutputPin
class SpinCADGenerator implements IGenerator {
// @Inject extension IQualifiedNameProvider
override void doGenerate(Resource resource, IFileSystemAccess fsa) {
var pkage = "\\com\\holycityaudio\\SpinCAD\\CADBlocks\\"
fsa.generateFile(pkage + resource.className+"CADBlock"+".java", toCADBlockCode(resource.contents.head as Program))
def className(Resource res) {
var name = res.URI.lastSegment
println(name)
return name.substring(0, name.indexOf('.'))
def toCADBlockCode(Program pr) '''
package com.holycityaudio.SpinCAD.CADBlocks;
import com.holycityaudio.SpinCAD.SpinCADBlock;
import com.holycityaudio.SpinCAD.SpinCADPin;
import com.holycityaudio.SpinCAD.fxblocks.basic.SpinFXBlock;
public class «pr.eResource.className+"CADBlock"» extends SpinCADBlock {
private static final long serialVersionUID = 1L;
public «pr.eResource.className+"CADBlock"»(int x, int y) {
super(x, y);
setName("«pr.name»");
// Iterate through pin definitions and allocate or assign as needed
«FOR Pin p : pr.pins»
«switch p {
AudioInput:{genAudioInput(p)}
AudioOutput:{genAudioOutput(p)}
ControlOutput:{genControlOutput(p)}
ControlInput:{genControlInput(p)}
«ENDFOR»
// In the event there are parameters editable by control panel
public void editBlock(){
// new «pr.eResource.className+"ControlPanel"»(this);
public void generateCode(SpinFXBlock sfxb) {
// Iterate through mem and equ statements, allocate accordingly
«FOR Element e : pr.elements»
«switch e {
Mem:{genMem(e)}
Equate:{genEquate(e)}
«ENDFOR»
sfxb.comment(getName());
SpinCADPin sp = null;
// Iterate through pin definitions and connect or assign as needed
«switch p {
InputPin: {connect(p)}
OutputPin: {setOutput(p)}
«ENDFOR»
// finally, generate the instructions
«switch e {
Instruction:{genInstruction(e)}
«ENDFOR»
// Say 'bye-bye'
System.out.println("«pr.getName»" + " code gen!");
def genAudioInput(Pin p) '''
addInputPin(this, "«p.name»");
def genAudioOutput(Pin p) '''
addOutputPin(this, "«p.name»");
def genControlInput(Pin p) '''
addControlInputPin(this, "«p.name»");
def genControlOutput(Pin p) '''
addControlOutputPin(this, "«p.name»");
// now connect them pins
def connect(Pin p) '''
sp = this.getPin("«p.name»").getPinConnection();
int «p.varName» = -1;
if(sp != null) {
«p.varName» = sp.getRegister();
def setOutput(Pin p) '''
this.getPin("«p.name»").setRegister(«p.varName»);
// try to figure out a way to distinguish REGx equates from INT or DOUBLE
def genEquate(Equate e) '''
«IF e.getValue.toUpperCase.startsWith("REG",0)»
int «e.getEname» = sfxb.allocateReg();
«ELSE»
double «e.getEname» = «e.getValue»;
«ENDIF»
def genMem(Mem m) '''
sfxb.FXallocDelayMem("«m.getBuffer»", «m.getLength»);
def genLabel(Label l) '''
«l.name»
def genInstruction(Instruction inst) '''
«switch inst {
Jam: genJam(inst)
ReadRegister: genReadRegister(inst)
ReadRegisterFilter: genReadRegisterFilter(inst)
WriteRegister: genWriteRegister(inst)
WriteRegisterLowshelf: genWriteRegisterLowshelf(inst)
WriteRegisterHighshelf: genWriteRegisterHighshelf(inst)
ScaleOffset: genScaleOffset(inst)
Mulx: genMulx(inst)
Ldax: genLdax(inst)
Not: genNot(inst)
Absa: genAbsa(inst)
Clr: genClr(inst)
Or: genOr(inst)
Log: genLog(inst)
Exp: genExp(inst)
Skip: genSkip(inst)
Xor: genXor(inst)
And: genAnd(inst)
LoadRampLFO: genWldr(inst)
LoadSinLFO: genWlds(inst)
WriteDelay: genWriteDelay(inst)
ReadDelay: genReadDelay(inst)
WriteAllpass: genWriteAllpass(inst)
ChorusReadDelay: genChorusReadDelay(inst)
ChorusReadValue: genChorusReadValue(inst)
ReadDelayPointer: genReadDelayPointer(inst)
def genAbsa(Absa inst) '''
sfxb.absa();
def genNot(Not inst) '''
sfxb.not();
def genClr(Clr inst) '''
sfxb.clear();
def genLog(Log inst) '''
sfxb.log(«inst.getArg1», «inst.getArg2»);
def genExp(Exp inst) '''
sfxb.exp(«inst.getArg1», «inst.getArg2»);
def genSkip(Skip inst) {
sfxb.skip(«inst.getFlags().toUpperCase()», «UtilSC::getDiff(inst)»);
def genJam(Jam inst) '''
sfxb.jam(«inst.getArg1»);
def genScaleOffset(ScaleOffset inst) '''
sfxb.scaleOffset(«inst.getArg1», «inst.getArg2»);
def genOr(Or inst) '''
sfxb.or(«inst.getArg1.toJavaBinary»);
def genAnd(And inst) '''
sfxb.and(«inst.getArg1.toJavaBinary»);
def genXor(Xor inst) '''
sfxb.xor(«inst.getArg1.toJavaBinary»);
def genWldr(LoadRampLFO inst) '''
sfxb.loadRampLFO(«inst.getArg1.spinRegs», «inst.getArg2», «inst.getArg3»);
def genWlds(LoadSinLFO inst) '''
sfxb.loadSinLFO(«inst.getArg1.spinRegs», «inst.getArg2», «inst.getArg3»);
def genReadDelay(ReadDelay inst) '''
sfxb.FXreadDelay("«inst.getArg1»", «inst.getArg2»);
def genReadDelayPointer(ReadDelayPointer inst) '''
sfxb.readDelayPointer(«inst.getArg1.spinRegs»);
def genWriteDelay(WriteDelay inst) '''
sfxb.FXwriteDelay("«inst.getArg1»", «inst.getArg2»);
def genWriteAllpass(WriteAllpass inst) '''
sfxb.FXwriteAllpass("«inst.getArg1»", «inst.getArg2»);
def genReadRegisterFilter(ReadRegisterFilter inst) '''
sfxb.readRegisterFilter(«inst.getArg1», «inst.getArg2»);
def genReadRegister(ReadRegister inst) '''
sfxb.readRegister(«inst.getArg1.spinRegs», «inst.getArg2»);
def genWriteRegister(WriteRegister inst) '''
sfxb.writeRegister(«inst.getArg1.spinRegs», «inst.getArg2»);
def genWriteRegisterHighshelf(WriteRegisterHighshelf inst) '''
sfxb.writeRegisterHighshelf(«inst.getArg1», «inst.getArg2»);
def genWriteRegisterLowshelf(WriteRegisterLowshelf inst) '''
sfxb.writeRegisterLowshelf(«inst.getArg1», «inst.getArg2»);
def genMulx(Mulx inst) '''
sfxb.mulx(«inst.getArg1.spinRegs»);
def genLdax(Ldax inst) '''
sfxb.loadAccumulator(«inst.getArg1»);
def genChorusReadDelay(ChorusReadDelay inst) '''
sfxb.FXchorusReadDelay(«inst.getArg1.toUpperCase()», «inst.getArg2.toUpperCase()», "«inst.getArg3»");
def genChorusReadValue(ChorusReadValue inst) '''
sfxb.chorusReadValue(«inst.getArg1.spinRegs»);
def toJavaBinary(String spinBinary) {
if (spinBinary.startsWith('%')) {
spinBinary.replace("%", "0b")
else if (spinBinary.startsWith('$')) {
spinBinary.replace("$", "0x")
else {
spinBinary;
def spinRegs(String reg) {
if (reg == "pot0") return "input0";
if (reg == "pot1") return "input1";
if (reg == "pot2") return "input2";
if (reg == "sin0") return "SIN0";
if (reg == "sin1") return "SIN1";
if (reg == "rmp0") return "RMP0";
if (reg == "rmp1") return "RMP1";
if (reg == "sin0_rate") return "SIN0_RATE";
if (reg == "sin1_rate") return "SIN1_RATE";
if (reg == "rmp0_rate") return "RMP0_RATE";
if (reg == "rmp1_rate") return "RMP1_RATE";
if (reg == "sin0_range") return "SIN0_RANGE";
if (reg == "sin1_range") return "SIN1_RANGE";
if (reg == "cos0") return "COS0";
if (reg == "cos1") return "COS1";
if (reg == "neg") return "NEG";
if (reg == "zrc") return "ZRC";
if (reg == "run") return "RUN";
if (reg == "gez") return "GEZ";
if (reg == "addr_ptr") return "ADDR_PTR";
return reg;
Re: Editor cannot be initialized/Unresolved proxy [message #1179231 is a reply to message #1179177] |
Sun, 10 November 2013 05:49 |
Xtext grammar:
grammar com.holycityaudio.spincad.SpinCAD with org.eclipse.xtext.common.Terminals
generate spinCAD "http://www.holycityaudio.com/spincad/SpinCAD"
Program:
'@name' name = ID
(pins += Pin)+
(elements += Element)+
Element:
Equate | Mem | Instruction | Label | Comment;
Pin:
InputPin | OutputPin
InputPin:
AudioInput | ControlInput
OutputPin:
AudioOutput | ControlOutput
AudioInput:
'@audioInput' varName = ID name = ID
AudioOutput:
'@audioOutput' varName = ID name = ID
ControlInput:
'@controlInput' varName = ID name = ID
ControlOutput:
'@controlOutput' varName = ID name = ID
Equate:
'equ' ename = ID value = SPINDOUBLE
Mem:
'mem' buffer = ID length = INT
Comment:
remark = SC_COMMENT
Label:
name = ID ':'
Instruction:
Inst_B15_S1_9 |
Inst_B6_S1_14 |
Inst_S1_14_S1_10 |
Inst_B6 |
Inst_B24 |
Skip |
Jam |
Inst_X0 |
LoadSinLFO |
LoadRampLFO |
ChorusReadDelay |
ChorusReadValue |
ChorusScaleOffset |
Log |
ReadDelayPointer
Inst_B6_S1_14:
ReadRegister |
WriteRegister |
ReadRegisterFilter |
Maxx |
WriteRegisterHighshelf |
Inst_B15_S1_9:
ReadDelay |
WriteDelay |
WriteAllpass
Inst_B6:
Mulx |
Ldax
Inst_B24:
And |
Or |
Xor
Inst_X0: Clr | Not | Absa
Inst_S1_14_S1_10:
Exp | ScaleOffset
ReadRegister: 'rdax' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE;
WriteRegisterLowshelf: 'wrlx' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE;
WriteRegisterHighshelf: 'wrhx' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE ;
WriteRegister: 'wrax' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE ;
Maxx: 'maxx' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE ;
ReadRegisterFilter: 'rdfx' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE ;
Mulx: 'mulx' arg1 = ID ;
Ldax: 'ldax' arg1 = ID ;
Exp: 'exp' arg1 = SPINDOUBLE ',' arg2 = SPINDOUBLE ;
Log: 'log' arg1 = SPINDOUBLE ',' arg2 = SPINDOUBLE ;
ScaleOffset: 'sof' arg1 = SPINDOUBLE ',' arg2 = SPINDOUBLE ;
WriteDelay: 'wra' arg1 = SPINMEM ',' arg2 = SPINDOUBLE;
WriteAllpass: 'wrap' arg1 = SPINMEM ',' arg2 = SPINDOUBLE;
ReadDelay: 'rda' arg1 = SPINMEM ',' arg2 = SPINDOUBLE;
LoadSinLFO: 'wlds' arg1 = SPINREGISTER ',' arg2 = INT ',' arg3 = INT;
LoadRampLFO: 'wldr' arg1 = SPINREGISTER ',' arg2 = INT ',' arg3 = INT;
// Chorus instructions
ChorusReadDelay: 'cho rda' ',' arg1 = SPINREGISTER ',' arg2 = SPINCHOREGFLAGS ',' arg3 = SPINMEM;
ChorusReadValue: 'cho rdal' ',' arg1 = SPINREGISTER;
ChorusScaleOffset: 'cho sof' ',' arg1 = ID ',' arg2 = SPINCHOREGFLAGS ',' arg3 = SPINDOUBLE;
ReadDelayPointer: 'rmpa' arg1 = SPINDOUBLE;
// single argument instructions
And: 'and' arg1 = BINARY24;
Or: 'or' arg1 = BINARY24;
Xor: 'xor' arg1 = BINARY24;
Jam: 'jam' arg1=ID;
Clr: {Clr} 'clr';
Not: {Not} 'not';
//Then there's Skip
Skip: 'skp' flags = ID ',' label = [Label];
terminal SC_COMMENT: ';' !('\n'|'\r')* ('\r'? '\n');
// data type rules
SPINDOUBLE:
'-'? (ID | (INT ( '.' INT)?))
SPINREGISTER:
(ID | INT )
SPINCHOREGFLAGS:
(INT | (ID ('|' ID)*)?)
SPINMEM:
ID ('#' | '^')? (('+' | '-') (INT | ID))?
BINARY24:
((('%' INT) (ID) * ) | ('$' (INT)* (ID)*))
QualifiedName :
ID ('.' ID)*
Current Time: Thu Apr 25 20:04:14 GMT 2024
Powered by FUDForum. Page generated in 0.03442 seconds
