Home » Eclipse Projects » GEF » Path Problem!!!!
Path Problem!!!! [message #186019] Fri, 01 July 2005 04:17 Go to next message
Originally posted by: gautamn.iitk.ac.in
regarding my path problem I post the message last week...but the
solution doen't work....
IFile file = ((IFileEditorInput)input).getFile();
String fullPath = file.getLocation( ).toOSString( )
if you through the FileDialog ,code example
FileDialog fileChooser = new FileDialog( getShell( ), SWT.OPEN );
String fullPath = fileChooser.open( );
Actually I want to read a xml file that may be anywhere along with source
code... I am exporting this project in the workspace...Suppose src file
are in "C:/kuda/myproject/src/myxml.xml" and I have eclipse installed in
D:/ drive.
How can I read this xml file in my code (How can I get the path???)
Nitin.
Re: Path Problem!!!! [message #186035 is a reply to message #186019] Fri, 01 July 2005 05:27 Go to previous messageGo to next message
Dazhen Gao is currently offline Dazhen GaoFriend
Can't you open a dialog?
FileInputStream stream = new FileInputStream(filename)
//read the file.
"Nitin Gautam" <gautamn@iitk.ac.in> wrote in message
news:d2baf21edf52ada1183e3ed473080cc6$1@www.eclipse.org...
> regarding my path problem I post the message last week...but the solution
> doen't work....
> D:/ drive.
> Regards,
> Nitin.
Re: Path Problem!!!! [message #186059 is a reply to message #186035] Fri, 01 July 2005 08:57 Go to previous message
//read the file.
no i can't use a dialog...i have to read in one of code files using File
Class.
I need to find the path becuase just providing filename is not working and
inorder to make it work i have to put it in eclipse folder.
Nitin.
Previous Topic:Parent-Child relationship!!!
Next Topic:Refreshing the Properties view
Current Time: Sun Jan 19 04:28:07 GMT 2025
Powered by FUDForum. Page generated in 0.02766 seconds
