Home » Archived » Sapphire » Label on 'With'
Label on 'With' [message #1177084] Fri, 08 November 2013 19:14 Go to next message
Paul Kolonay is currently offline Paul KolonayFriend
On the 'With' definition page, there is a Label entry text box, but I never see the label text appear next to the 'With' contents when the def is rendered.
What is the expected behavior?
Re: Label on 'With' [message #1177220 is a reply to message #1177084] Fri, 08 November 2013 21:23 Go to previous messageGo to next message
Konstantin Komissarchik is currently offline Konstantin KomissarchikFriend
The label is currently only used for the checkbox presentation of with. This presentation is activated when the element property has one possible type.
Re: Label on 'With' [message #1181178 is a reply to message #1177220] Mon, 11 November 2013 12:28 Go to previous messageGo to next message
Does it seem reasonable to also activate this on the drop down presentation?
Re: Label on 'With' [message #1181402 is a reply to message #1181178] Mon, 11 November 2013 15:30 Go to previous messageGo to next message
It should probably function like the property editor where default label is property label, but you can override it in sdef; and there is a show label flag. Could you open a bug?
Re: Label on 'With' [message #1181505 is a reply to message #1181402] Mon, 11 November 2013 16:46 Go to previous message
Sounds good to me.
Bug 421468
Previous Topic:Update on Sapphire 0.7
Next Topic:Include Params behavior/useage
Current Time: Mon May 20 12:46:57 GMT 2024
Powered by FUDForum. Page generated in 0.03961 seconds
