Home » Newcomers » Newcomers » Error on eclipse startup
Error on eclipse startup [message #1177021] Fri, 08 November 2013 13:12 Go to next message
I downloaded eclipse, worked fine, but after the next reboot of my computer I can't start eclipse anymore:
!SESSION 2013-11-08 18:58:01.886 -----------------------------------------------
eclipse.buildId=4.3.0.M20130911-1000
java.version=1.7.0_45
Framework arguments: -product org.eclipse.epp.package.standard.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.standard.product
!ENTRY org.eclipse.osgi 4 0 2013-11-08 18:58:04.574
!MESSAGE Application error
!STACK 1
java.lang.LinkageError: Error reading class bytes: org.eclipse.swt.widgets.Tray
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:558)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:501)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:465)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:675)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:162)
at org.eclipse.ui.internal.ide.application.IDEApplication.createDisplay(IDEApplication.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:96)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Caused by: java.util.zip.ZipException: invalid LOC header (bad signature)
at java.util.zip.ZipFile.read(Native Method)
at java.util.zip.ZipFile.access$1400(Unknown Source)
at java.util.zip.ZipFile$ZipFileInputStream.read(Unknown Source)
at java.util.zip.ZipFile$ZipFileInflaterInputStream.fill(Unknown Source)
at java.util.zip.InflaterInputStream.read(Unknown Source)
at org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleEntry$ZipBundleEntryInputStream.read(ZipBundleEntry.java:157)
at org.eclipse.osgi.internal.baseadaptor.AdaptorUtil.getBytes(AdaptorUtil.java:247)
at org.eclipse.osgi.baseadaptor.bundlefile.BundleEntry.getBytes(BundleEntry.java:96)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:554)
... 25 more
Re: Error on eclipse startup [message #1238551 is a reply to message #1177021] Sat, 01 February 2014 13:13 Go to previous messageGo to next message
I have the same problem.
How did you resolve this?
David
Re: Error on eclipse startup [message #1242851 is a reply to message #1238551] Mon, 10 February 2014 02:12 Go to previous message
The relevant part seems to be java.util.zip.ZipException: invalid LOC header (bad signature) at java.util.zip.ZipFile.read(Native Method). Looks like a jar file is corrupt. Try re-installing Eclipse. Perhaps you should check your disk too.
Previous Topic:Eclipse Plugin Install Locations on Mac
Next Topic:Source Code
Current Time: Wed Jul 09 06:33:22 EDT 2025
Powered by FUDForum. Page generated in 0.08714 seconds
