Home » Eclipse Projects » NatTable » Pop up menu in Editable cells.
Pop up menu in Editable cells. [message #1176832] Fri, 08 November 2013 15:34 Go to next message
Rajesh Arumugam is currently offline Rajesh ArumugamFriend
Hi all,
In my nattable, I added configuration to make my cells editable. By double clicking the cell, i am able to edit the content as well. But when the cell is editable, if i right click, i am getting a context menu with
  • Undo
  • Copy
  • Paste
  • Select All
  • Delete
  • Cut
  • Open IME
All these menu items are working fine. ie If I select cell and do delete, its removing cell content.
I dont understand from where this pop-up is coming. I tried all options, but i could not figure out the way. I need to get rid of this pop-up menu, also need to implement actions of this menu items in some other manner.
Thanks in advance
Re: Pop up menu in Editable cells. [message #1176955 is a reply to message #1176832] Fri, 08 November 2013 17:18 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
This is the context menu of the SWT Text control. Nothing NatTable specific. If you need to adjust, you need to investigate in SWT possibilities.
Previous Topic:Multi Level Column Grouping
Next Topic:CellPainterDecorator
Current Time: Thu Feb 20 11:29:09 GMT 2020
Powered by FUDForum. Page generated in 0.01781 seconds
