Re: Custom Edatatype with ecore model editor [message #1176714 is a reply to message #1176658] |
Fri, 08 November 2013 14:04 |
Hi, Chrisophe,
In the New Child menu of the EPackage, choose EDataType to create a new
EDataType. This can then be used as the type of any EAttribute. Don't
forget to set the instance class name of your data type.
HTH,
Christian
On 2013-11-08 13:25:12 +0000, Christophe Bouhier said:
> Simpel question, but hard to find an answer.
> How do I create a Custom EDatatype with the ecore editor?
> Should I select an EType => EJavaObject?
> Thank you,
> Christophe
Re: Custom Edatatype with ecore model editor [message #1176780 is a reply to message #1176714] |
Fri, 08 November 2013 14:52 |
Christophe Bouhier Messages: 937 Registered: July 2009 |
Thanks Christian!
On 08-11-13 15:04, Christian W. Damus wrote:
> Hi, Chrisophe,
> HTH,
> Christian
>> Thank you,
>> Christophe
FUDForum. Page generated in 0.03458 seconds
