Home » Modeling » TMF (Xtext) » Default value of String(Xtext grammar default values)
Default value of String [message #1176412] Fri, 08 November 2013 10:13 Go to next message
Gunnar Boström is currently offline Gunnar BoströmFriend
Is it possible in the xtext grammar to define the default value of a String?
I don't want it to be null.
Actually I would like to add "structural" nodes to the outline.
One of the nodes is defines as
Accounts:
{Accounts}
name=STRING?
accounts+=Account*;
To set the name now I've overridden the _createChildren method in the OutlineTreeProvider as
if (childElement instanceof Accounts) {
val accs = childElement as Accounts
accs.name = "Accounts";
It would be much better and cleaner if I could provide the default value in the grammar.
/Gunnar
Re: Default value of String [message #1176424 is a reply to message #1176412] Fri, 08 November 2013 10:24 Go to previous messageGo to next message
Uli Merkel is currently offline Uli MerkelFriend
AFAIK, if you use an enumeration, the default is always the first option.
Perhaps you can use this in your grammar.
Re: Default value of String [message #1176431 is a reply to message #1176424] Fri, 08 November 2013 10:27 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
cant you simply adopt the IQualifiedNameProvider??
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Default value of String [message #1176525 is a reply to message #1176424] Fri, 08 November 2013 11:40 Go to previous messageGo to next message
Uli Merkel wrote on Fri, 08 November 2013 05:24
I tried that but the outline view but the name must be a string for the outline to work.
/Gunnar
Re: Default value of String [message #1176532 is a reply to message #1176431] Fri, 08 November 2013 11:45 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 08 November 2013 05:27
How can I use that?
Would it be simpler than the way I handle it now in the outline provider?
/Gunnar
Re: Default value of String [message #1176544 is a reply to message #1176532] Fri, 08 November 2013 11:54 Go to previous messageGo to next message
sorry it is actually not used have a look at
org.eclipse.xtext.ui.label.DefaultEObjectLabelProvider.doGetText(Object)
Re: Default value of String [message #1176545 is a reply to message #1176532] Fri, 08 November 2013 11:53 Go to previous messageGo to next message
Hi isn't that used by default? Please debug
DefaultDeclarativeNameProvider
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Default value of String [message #1176573 is a reply to message #1176545] Fri, 08 November 2013 12:16 Go to previous messageGo to next message
Sorry but I'm to new with xtext to understand what I should do!
/Gunnar
Re: Default value of String [message #1176581 is a reply to message #1176573] Fri, 08 November 2013 12:22 Go to previous messageGo to next message
Have a look at org.eclipse.xtext.ui.label.DefaultEObjectLabelProvider.doGetText(Object) ,
debug it, customize it (you should already have a sublass pregrenerated
Re: Default value of String [message #1176631 is a reply to message #1176581] Fri, 08 November 2013 13:03 Go to previous message
I've got it. Much easier than to change the outline.
Thanks!
/Gunnar
Previous Topic:Customizable formatting
Next Topic:What is generated by fornax-oaw-m2-plugin?
Current Time: Thu Jan 28 00:41:15 GMT 2021
Powered by FUDForum. Page generated in 0.01645 seconds
