Home » Modeling » TMF (Xtext) » How to accessing resources on the classpath
How to accessing resources on the classpath [message #1175331] Thu, 07 November 2013 17:40 Go to next message
Dieter Bogdoll is currently offline Dieter BogdollFriend
I have written a grammar with xtext and imported this as a plugin into a eclipse installation. A java project inside eclipse uses this plugin to edit a file
(using the generated grammar editor).
I would like to access the classpath of this Java project for validating the grammar (not the classpath of the grammar plugin). I need to resources which might be files or classes.
How would this work from inside of xtext?
Dieter
Re: How to accessing resources on the classpath [message #1175365 is a reply to message #1175331] Thu, 07 November 2013 18:08 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi you can ask a xtextresource for its classpathuricontext
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: How to accessing resources on the classpath [message #1175414 is a reply to message #1175365] Thu, 07 November 2013 18:54 Go to previous messageGo to next message
Hi Christian,
I'm fairly new to xtext, could you be a bit more specific. Smile
E.g. here is my validation method:
@Check
def checkIfBuildersExists(BuilderName aBuilderName) {
    println("Does '"+aBuilderName.name+"' exists, please check ...")
Whereas 'BuilderName' extends (indirectly) org.eclipse.emf.ecore.EObject and the class in which the check-method extends org.eclipse.xtext.validation.AbstractDeclarativeValidator.
So how do I access the xtextresource?
Re: How to accessing resources on the classpath [message #1175436 is a reply to message #1175414] Thu, 07 November 2013 19:12 Go to previous messageGo to next message
you can ask an eObject for its eResource. this may be an XtextResource.
Btw is there a specific thing you want to do (you did not go into detail on that)
Re: How to accessing resources on the classpath [message #1175450 is a reply to message #1175436] Thu, 07 November 2013 19:24 Go to previous messageGo to next message
The 'BuilderName' contains a string. This is either a full qualified name for a java class. In this case I want to check if this class exists on the classpath of the java project. Or it is a key of a property file which contains again a java full qualified name. This property file (or several) are somewhere on the classpath, they have a specific location but could reside within several jars.
Re: How to accessing resources on the classpath [message #1176432 is a reply to message #1175450] Fri, 08 November 2013 10:28 Go to previous messageGo to next message
Here is some pseudo-code describing what I want to do. In the end, I think,
I need to know how to access the classLoader which is used my the java project
using my grammar ui.
private def getClassLoader() {
	// get magically the classpathloader <- thats what I need how to do it
private def Properties loadProps(URL urlToProperties) {
private def verifyClassExists(String className) {
	classLoader.loadClass(className)!=null
private def String findClassNameFor(String aName) {
	classLoader.getResources("builderNames.properties").mapFirst[
		// find the first element where I can apply the map and return the result
		val props = loadProps(it)
		props.getProperty(aName);
@Check
	val className = findClassNameFor(aBuilderName.name) ?:  aBuilderName.name
	if(!verifyClassExists(className)) {
		error("Builder '"+aBuilderName.name+"' does not exist", aBuilderName, OmniPropertiesPackage.Literals.BUILDER__NAME)
Re: How to accessing resources on the classpath [message #1178551 is a reply to message #1176432] Sat, 09 November 2013 18:46 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven EfftingeFriend
I haven't tested but you should be able to use the classpath URI scheme here.
Here's some Java code, that should help get you started:
ResourceSet rs = someEObject.eResource().getResourceSet();
URI classPathURI = URI.createURI("classpath:/"+path);
if (rs.getURIConverter().exists(classPathURI, null)) {
InputStream contents = rs.getURIConverter().createInputStream(classPathURI);
Re: How to accessing resources on the classpath [message #1179517 is a reply to message #1178551] Sun, 10 November 2013 10:28 Go to previous message
Sven Efftinge wrote on Sat, 09 November 2013 13:46
Thanks, for this code fragment. I was able to load a non java resource with it.
I were not able to get a java resource, I then always get an exception.
But even the non java resource is not fully what I want. E.g. you could have
several jars on your classpath and each jar can contain the same named resource.
With getClass().getClassloader().getResources("resourcename") you get back
an Enumeration of all files in the jars. And that is what I would need here.
Also the loading of a java class would be relevant for me.
Is there no other xtext Project which needs to access the classpath to verify
the correctness of the text to translate?
Previous Topic:Editor cannot be initialized/Unresolved proxy
Next Topic:Error when trying to Export to Eclipse product
Current Time: Tue Jan 19 13:26:36 GMT 2021
Powered by FUDForum. Page generated in 0.01711 seconds
