Home » Modeling » Papyrus » Checking OCL contraints in Papyrus
Checking OCL contraints in Papyrus [message #1175283] Thu, 07 November 2013 16:53 Go to next message
Alexander W is currently offline Alexander WFriend
I created an simple UML Model in Papyrus with an simple constraint. How can I check the constraints which I defined (on an instance of the UML Model)?
I didn't found a tutorial which shows the definition of a class constraint and the checking of this constraint from scratch. So maybe someone has further links/examples. Until now only the model.uml and model.di file exist.
Thanks in advance. Alex
Re: Checking OCL contraints in Papyrus [message #1175393 is a reply to message #1175283] Thu, 07 November 2013 18:32 Go to previous messageGo to next message
Have you looked at the "OCL in UML (using Papyrus)" section in the OCL
documentation?
Ed Willink
On 07/11/2013 17:57, Alexander W wrote:
> UML Model)?
Re: Checking OCL contraints in Papyrus [message #1175442 is a reply to message #1175283] Thu, 07 November 2013 19:16 Go to previous message
Klaas Gadeyne is currently offline Klaas GadeyneFriend
Alexander W wrote on Thu, 07 November 2013 11:53
Regarding the definition, see Ed's answer above.
Regarding the execution: simple answer: it ain't possible, see <https://bugs.eclipse.org/bugs/show_bug.cgi?id=417062>
Less simple answer: Depending on your goals, you might transform your model into an ecore model, and validate ecore instances instead.
HTH
k
[Updated on: Fri, 08 November 2013 09:51]
Report message to a moderator
Previous Topic:Palette customization
Next Topic:Activities in block definition diagrams
Current Time: Sat Feb 27 22:53:06 GMT 2021
Powered by FUDForum. Page generated in 0.02254 seconds
