Re: maven 2 parent pom and eclipse project structure [message #184717 is a reply to message #184689] |
Thu, 14 December 2006 14:35 |
Originally posted by: kosta.bea.com
Leif,
Unfortunately, Eclipse does not support nested project structure. You
can certainly import the projectManagement directory as a separate
project, but the trick is what to do with the top-level pom.xml file.
The only solution that I am aware of is to move it into a sub-directory
that can then be imported as a project.
Hope this helps.
- Konstantin
Re: maven 2 parent pom and eclipse project structure [message #184824 is a reply to message #184741] |
Thu, 14 December 2006 16:49 |
Leif,
I don't believe "flexible project" structure will help in this case. You
may want to consider posting a request on the Eclipse Platform news
group and/or opening an enhancement request against the platform as this
goes beyond WTP and needs to be implemented at the platform level.
We have been requesting support for this from the platform for quite a
while now. Hasn't happened yet. But the more people that ask for it, the
more likely that it will eventually be supported.
- Konstantin
FUDForum. Page generated in 0.03628 seconds
