Home » Modeling » UML2 » UMLPackage.eINSTANCE.eClass() is ecore.EPackage?
UMLPackage.eINSTANCE.eClass() is ecore.EPackage? [message #1171686] |
Tue, 05 November 2013 12:06  |
Hi!
I am confused about the UMLPackage implementation because the UMLPackage
instance returns ecore.EPackage as EClass, not uml.Package.
I would have expected that the UMLPackage implementation is a UML
package, not an Ecore package. Easily testable with the following code:
@Test
public void checkUmlPackageEClass() {
final EClass umlPackageClass = UMLPackage.eINSTANCE.eClass();
assertEquals(UMLPackage.Literals.PACKAGE, umlPackageClass);
We want to use Sphinx to load UML models, and when checking the model
type for the UMLPackage, it determines Ecore instead of UML because of
the eClass() result.
Can the UMLPackage's EClass be changed to uml.Package?
Cheers
Patrick
Re: UMLPackage.eINSTANCE.eClass() is ecore.EPackage? [message #1171949 is a reply to message #1171686] |
Tue, 05 November 2013 15:45   |
Hi, Patrick,
Yes, every EMF package is an Ecore EPackage. The UML metamodel is not
an extension of the Ecore metamodel: it is transformed to Ecore in
order to provide a Java implementation.
Does Sphinx need to treat models that are generated from UML (by the
UML2 SDK, using UML2's extended GenModel) differently from those
generated from Ecore (by the EMF SDK)? You might be able to make this
distinction by looking up the EPackage's genmodel and seeing whether
its "foreign model" is an Ecore or a UML model. You may also see
gen-annotations in the genmodel that indicate a UML source.
HTH,
Christian
On 2013-11-05 12:06:01 +0000, Patrick Könemann said:
> Hi!
> @Test
> Cheers
> Patrick
Re: UMLPackage.eINSTANCE.eClass() is ecore.EPackage? [message #1172086 is a reply to message #1171949] |
Tue, 05 November 2013 17:41   |
Hi Christian,
thanks for the quick response!
During proxy resolution, Sphinx identifies the meta model type at some
point via a model element's eClass(). For the UMLPackage instance, this
results in the Ecore meta model, not the UML meta model. Consequently, a
different MetaModelDescriptor is determined.
I would expect every resource in the resource set of a UML model to be
an instance of the UML meta model, i.e. profiles, type libraries, and
the UML meta model itself. Otherwise we would have multiple
MetaModelDescriptors for a resource set that contains only UML models,
which seems weird in my eyes ;-)
Patrick
Am 05.11.2013 16:45, schrieb Christian W. Damus:
> Hi, Patrick,
> distinction by looking up the EPackage's genmodel and seeing whether its
> HTH,
> Christian
>> Hi!
>> @Test
>> Cheers
>> Patrick
Re: UMLPackage.eINSTANCE.eClass() is ecore.EPackage? [message #1172211 is a reply to message #1172086] |
Tue, 05 November 2013 19:39   |
Hi, Patrick,
I'm starting to get dizzy with these "meta"s spinning around. :-)
You will never find the UMLPackage in a resource ... it lives in the
EPackage.Registry. And the only EClass that Sphinx will ever see when
asking packages for their eClass() is Ecore::EPackage, because all
packages are EPackages in EMF. It is simply required by the framework.
Probably most resources in a resource set containing UML models will
have UML Packages or other Elements of some kind, but they could also
have stereotype applications described by profiles, and these profiles
are manifest as EPackages that are all distinct from UML (though
generated by the UML2 tooling). Profiles are instances of the UML
metamodel, but the instances of their Stereotypes are not UML elements
and have no relation to UML except at the meta-level.
Perhaps the determination of a MetaModelDescriptor should look not at
the EPackage's eClass() but its namespace URI to identify it (although,
for UML, this doesn't work well because it changes in most annual
releases). Although, I'm still unsure of the purpose of the
MetaModelDescriptor. Is it meant to identify the particular EPackage
(ecore, uml, library, ocl, diffmodel, etc.) or the metamodel from which
it was generated (Ecore, UML)?
I don't know that I'm helping any ...
cW
On 2013-11-05 17:41:21 +0000, Patrick Könemann said:
> Hi Christian,
> Patrick
>> Hi, Patrick,
>> HTH,
>> Christian
>>> Hi!
>>> @Test
>>> Cheers
>>> Patrick
Re: UMLPackage.eINSTANCE.eClass() is ecore.EPackage? [message #1173594 is a reply to message #1172211] |
Wed, 06 November 2013 16:26  |
Hi Christian,
I agree, thanks for your clarifications!
In the meantime, Sphinx is changed to decide via a resource scope
whether or not an element and its resource belongs to a model's scope
(for proxy resolution, amongst others) or not. So it is up to the
implementation to decide that, e.g. by URI or file extension.
So the EClass is not evaluated anymore :-)
Patrick
Am 05.11.2013 20:39, schrieb Christian W. Damus:
> Hi, Patrick,
> cW
>> Hi Christian,
>> Patrick
>>> Hi, Patrick,
>>> HTH,
>>> Christian
>>>> Hi!
>>>> UMLPackage
>>>> @Test
>>>> Cheers
>>>> Patrick
Current Time: Sun Aug 14 09:58:49 GMT 2022
Powered by FUDForum. Page generated in 0.02303 seconds
