Home » Language IDEs » ServerTools (WTP) » chaniging the contract
Re: chaniging the contract [message #184415 is a reply to message #184373] |
Mon, 11 December 2006 19:22 |
Kathy Chan Messages: 93 Registered: July 2009 |
Member |
Hi Zohar,
Once you enable the "Merge generated skeleton file" preference, when a
skeleton file is generated (going through a top-down scenario with WSDL),
the generated skeleton stub code will be merged with the original skeleton
file if it exist. The merge is being done in a method by method basis using
the original skeleton file as the master. Comments in the original file
will be preserved. Here's some detail:
- If a method exist in either the original file or the newly generated
file, it's going to be in the resulting merged file.
- If the same method exist in both the orginal file and the newly generated
file,
- the method body of the original file is going to replace the newly
generated file (which is just a stub implementation)
- the return type of the newly generated file will be used
- the exception of the newly generated file will be used
If skeleton merge is not enabled, the skeleton file will just be replaced
with the newly generated file. That is, the original skeleton file (which
might have business logic already implemented) will be overwritten. If you
have not implemented the business logic in the skeleton file (or don't mind
re-implementing the code) after you have first ran through Web service
creation with the original WSDL file, then you don't have to worry about
turning skeleton merge on before going through the wizard with the updated
WSDL file.
Hope this clarifies the Web service skeleton merge function.
Kathy Chan
"Zohar" <david_fire4@hotmail.com> wrote in message
news:eljto7$cqi$1@utils.eclipse.org...
> Thanks, seems like what I'm looking for, but how is the merge done?
> "Andrew Mak" <makandre@ca.ibm.com> wrote in message
> news:145553032f983c93965909f3ac8350af$1@www.eclipse.org...
>> Hi Zohar,
>> If you chage the wsdl document, you will have to run through the Web
>> Service wizard again to generate a new skeleton. Keep in mind that this
>> action will overwrite your code unless you turn on the "Skeleton Merge"
>> option.
>> The Skeleton Merge option can be found in the preferences dialog box,
>> under Web Services > Resource Management (last checkbox: Merge generated
>> skeleton file).
>> Hope this helps.
>> Andrew
Re: chaniging the contract [message #184459 is a reply to message #184415] |
Tue, 12 December 2006 07:17 |
Zohar Amir Messages: 419 Registered: July 2009 |
Hi Kathy,
Thanks for the explanation. I may be missing something here - after I
generate my code from the WSDL, where do I place the business logic? I
though I should put it in ServiceSoapImpl.
Zohar.
"Kathy Chan" <kathy@ca.ibm.com> wrote in message
news:elkb64$frk$1@utils.eclipse.org...
> Hi Zohar,
> using the original skeleton file as the master. Comments in the original
> file will be preserved. Here's some detail:
> generated file,
> you have not implemented the business logic in the skeleton file (or don't
> mind re-implementing the code) after you have first ran through Web
> service creation with the original WSDL file, then you don't have to worry
> about turning skeleton merge on before going through the wizard with the
> updated WSDL file.
> Regards,
> Kathy Chan
>>> Hi Zohar,
>>> option.
>>> skeleton file).
>>> Hope this helps.
>>> Andrew
Re: chaniging the contract [message #184498 is a reply to message #184459] |
Tue, 12 December 2006 17:28 |
Andrew Mak Messages: 41 Registered: July 2009 |
Member |
Hi Zohar,
Yes, that is correct, your business logic goes into the ...Impl.java file.
This file should be already opened in the editor after the wizard
finishes. This is the newly generated skeleton file that Kathy was
referring to. Usually it only contain method stubs and you'll have to
fill in the business logic. However if merge skeleton is turned on then
it will contain your previously implement business logic plus new methods
stubs for operations you've added to the wsdl.
Andrew
Zohar wrote:
> Hi Kathy,
> Zohar.
>> Hi Zohar,
>> generated file,
>> updated WSDL file.
>> Regards,
>> Kathy Chan
>>>> Hi Zohar,
>>>> option.
>>>> skeleton file).
>>>> Hope this helps.
>>>> Andrew
Re: chaniging the contract [message #185170 is a reply to message #184498] |
Mon, 18 December 2006 07:55 |
Thanks.
Just a clarification: why is the "merge" option global and per creation of a
service?
news:f1d5e1adf064ca35dda63b25b527b3eb$1@www.eclipse.org...
> Hi Zohar,
> Andrew
> Zohar wrote:
>> Hi Kathy,
>> Thanks,
>> Zohar.
>>> Hi Zohar,
>>> WSDL), the generated skeleton stub code will be merged with the original
>>> skeleton file if it exist. The merge is being done in a method by
>>> method basis using the original skeleton file as the master. Comments
>>> in the original file will be preserved. Here's some detail:
>>> generated file,
>>> replaced with the newly generated file. That is, the original skeleton
>>> file (which might have business logic already implemented) will be
>>> overwritten. If you have not implemented the business logic in the
>>> skeleton file (or don't mind re-implementing the code) after you have
>>> first ran through Web service creation with the original WSDL file, then
>>> you don't have to worry about turning skeleton merge on before going
>>> through the wizard with the updated WSDL file.
>>> Regards,
>>> Kathy Chan
>>>>> Hi Zohar,
>>>>> this action will overwrite your code unless you turn on the "Skeleton
>>>>> Merge" option.
>>>>> generated skeleton file).
>>>>> Hope this helps.
>>>>> Andrew
Current Time: Thu Apr 25 22:45:08 GMT 2024
Powered by FUDForum. Page generated in 0.03235 seconds
