Home » Modeling » UML2 » Binary serialization broken with UML2 Kepler ?
icon4.gif  Binary serialization broken with UML2 Kepler ? [message #1165949] Fri, 01 November 2013 17:11 Go to next message
Alexis Muller is currently offline Alexis MullerFriend
UML2 binary serialization seems broken with the last version of Kepler.
The follow simple Junit test shows the issue:
import static org.junit.Assert.assertEquals;
import static org.junit.Assert.assertNotNull;
import java.io.ByteArrayInputStream;
import java.io.ByteArrayOutputStream;
import java.io.IOException;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl;
import org.eclipse.emf.ecore.resource.impl.ResourceFactoryImpl;
import org.eclipse.emf.ecore.resource.impl.ResourceImpl;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.uml2.uml.Enumeration;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.UMLFactory;
import org.junit.Assert;
import org.junit.Test;
public class BinarySaveLoadTests
	private byte[] data;
	@Test
	public void saveAnLoad() throws IOException
		final ResourceSet resourceSet = new ResourceSetImpl();
		resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap()
			.put(Resource.Factory.Registry.DEFAULT_EXTENSION, new ResourceFactoryImpl() {
				public Resource createResource(URI uri)
					return new BinaryResourceImpl(uri);
		Resource resource = resourceSet.createResource(URI.createURI("binresource"));
		Model model = UMLFactory.eINSTANCE.createModel();
		model.setName("model");
		Enumeration en = model.createOwnedEnumeration("enum");
		en.createOwnedLiteral("lit1");
		resource.getContents().add(model);
		ByteArrayOutputStream out = new ByteArrayOutputStream();
		resource.save(out, null);
		data = out.toByteArray();
		ResourceImpl resource2 = (ResourceImpl) resourceSet.createResource(URI.createURI("binresource2"));
		resource2.load(new ByteArrayInputStream(data), null);
		Model model2 = (Model) resource2.getContents().get(0);
		assertNotNull(model2);
		assertEquals(model2.getName(), "model");
		Assert.assertFalse(model.getOwnedElements().isEmpty());
Its execution raises the following exception:
java.lang.UnsupportedOperationException
	at org.eclipse.emf.common.util.BasicEList$UnmodifiableEList.grow(BasicEList.java:1029)
	at org.eclipse.emf.common.util.BasicEList.addAllUnique(BasicEList.java:495)
	at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadEObjects(BinaryResourceImpl.java:2232)
	at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadFeatureValue(BinaryResourceImpl.java:2555)
	at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadEObject(BinaryResourceImpl.java:2522)
	at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadEObjects(BinaryResourceImpl.java:2222)
	at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadResource(BinaryResourceImpl.java:2205)
	at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl.doLoad(BinaryResourceImpl.java:264)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
	at testumlbinary.BinarySaveLoadTests.saveAnLoad(BinarySaveLoadTests.java:55)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:47)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:44)
	at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
	at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:271)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Maybe I am doing something wrong, if so, please let me know. But the same code is working perfectly with previous UML2 Juno implementations.
Could you help me to fix this issue?
Thank you.
Re: Binary serialization broken with UML2 Kepler ? [message #1166974 is a reply to message #1165949] Sat, 02 November 2013 09:54 Go to previous messageGo to next message
Please raise a Bugzilla attaching the example as a zipped project rather
than a file to avoid misunderstandings over classpaths etc.
Ed Willink
On 01/11/2013 21:11, Alexis Muller wrote:
> @Test
> @Override
> Resource resource =
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thank you.
Re: Binary serialization broken with UML2 Kepler ? [message #1167242 is a reply to message #1166974] Sat, 02 November 2013 14:06 Go to previous messageGo to next message
Hi Ed,
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=420938
Thank you,
Alexis
Re: Binary serialization broken with UML2 Kepler ? [message #1188246 is a reply to message #1167242] Fri, 15 November 2013 14:30 Go to previous message
Kenn Hussey is currently offline Kenn HusseyFriend
On 13-11-02 10:06 AM, Alexis Muller wrote:
> Hi Ed,
> Thank you,
> Alexis
.... and fixed. This will be released in Kepler SR2 (February) and Luna
(June).
Kenn
Previous Topic:inheritance of stereotypes in subclasses
Next Topic:OCL expression
Current Time: Mon Jan 25 18:21:05 GMT 2021
Powered by FUDForum. Page generated in 0.05918 seconds
