Home » Eclipse Projects » EGit / JGit » Way to use local masterBranch
Way to use local masterBranch [message #1163941] Thu, 31 October 2013 10:17 Go to next message
Samuel Suther is currently offline Samuel SutherFriend
i'd like to create a Folder with my Files of the Project.(say /home/projects/p1)
And than, i'd like to create a new Eclipse-Project (say /home/projects/dev/p1), wich use this p1 as orgin master.
So i want to work on the "dev" path, and push my changes to /projects/p1.
How can i configure this at best?
Re: Way to use local masterBranch [message #1176666 is a reply to message #1163941] Fri, 08 November 2013 13:27 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
I don't understand your question. Push is an operation transfering commits between different repository
instances but not different folders in the same directory.
Re: Way to use local masterBranch [message #1192008 is a reply to message #1163941] Sun, 17 November 2013 10:19 Go to previous message
Robin Rosenberg is currently offline Robin RosenbergFriend
Samuel Suther skrev 2013-10-31 11.17:> Hi,
Clone /home/projects/dev/p1 from /home/projects/p1 or edit .git/config in /home/projects/dev/p1 to point origin to /home/projects/p1.
Also it's a good idea to make /home/projects/p1 a bare repo since pushing to it will not update any checked out files anyway.
-- robin
Previous Topic:How to change "Location" for "User Settings"
Next Topic:Error pushing to remote
Current Time: Tue Jan 28 13:19:38 GMT 2020
Powered by FUDForum. Page generated in 0.02338 seconds
