Re: java.library.path [message #182435 is a reply to message #182374] |
Fri, 10 November 2006 03:08 |
Originally posted by: mohsen.siahe.com
WTP creates a new running configuration for Tomcat or other servers you are
using. add -Djava.library.path to VM arguments on run window (arguments
tab).
"Zohar" <david_fire4@hotmail.com> wrote in message
news:eisu9d$lcj$1@utils.eclipse.org...
> Hello,
> In my servlet I need to load a dll. Using WTP, how do I specify the
> java.library.path for the loading?
> Zohar.
Re: java.library.path [message #182561 is a reply to message #182520] |
Mon, 13 November 2006 02:45 |
On a web app, you MUST put your JAR files on web-module/WEB-INF/lib, and the
classes on web-module/WEB-INF/classes. Applications usually put the needed
resources on web-module/WEB-INF/classes (puting it on src folder will
automaically copy it each time I think).
news:ej6gou$pbd$1@utils.eclipse.org...
> thanks.
> Where is the best place to put the dlls and the loading classes?
> "Mohsen Saboorian" <mohsen@siahe.com> wrote in message
> news:ej0qm9$hh0$1@utils.eclipse.org...
>> Hi,
>> are using. add -Djava.library.path to VM arguments on run window
>> (arguments tab).
>>> Hello,
>>> Thanks,
>>> Zohar.
FUDForum. Page generated in 0.03165 seconds
