Project Facet problem [message #182170] |
Fri, 03 November 2006 21:06 |
Originally posted by: topher1120.gmail.com
I'm having a problem I hope you can help with. I have Eclipse set up and
using Java 5 as the base implementation. I have some projects that are
using Java 5, but one that is using Java 1.4. If I set this project up as
a "Dynamic Web Project" in the system, it automatically adds the "Java"
facet with version "5.0". This is fine and dandy, until I change my
compiler compliance level (Project->Properties->Java Compiler). Now the
Project has the Big Red X and the Errors view shows: "Java compiler level
does not match the version of the installed Java project facet."
How can I fix this?
I have searched through many logical areas of the Preferences and all the
online documentation I could find was about how to create a new facet.
Thanks in advance,
topher
Re: Project Facet problem [message #182179 is a reply to message #182170] |
Fri, 03 November 2006 21:19 |
Originally posted by: kosta.bea.com
Try Project Properties -> Project Facets. Hit Add/Remove Facets and you
will be able to change the version of the java facet in that screen.
Alternatively, the problem marker that you are seeing has quick fixes
available...
- Konstantin
Re: Project Facet problem [message #182201 is a reply to message #182179] |
Fri, 03 November 2006 22:47 |
Hi Konstantin,
Apologies for not seeing your point about the quick fixes before my last
post. Looking back at your answer allowed me to fix the problem.
Thanks a lot!
topher
Re: Project Facet problem [message #182230 is a reply to message #182201] |
Sun, 05 November 2006 06:01 |
No problem. While you cannot remove the java facet, you can change it's
version by clicking on the version field. I know it's kinda hard to know
that that field is editable. We are working on that.
- Konstantin
FUDForum. Page generated in 0.03457 seconds
