Home » Modeling » Papyrus » Cannot display icons for specialized stereotype
Cannot display icons for specialized stereotype [message #1162297] Wed, 30 October 2013 09:28 Go to next message
Tomas Sandkvist is currently offline Tomas SandkvistFriend
I've tried to specialize the «Block» element in my own profile and giving the new stereotype an icon.
I have followed the guidelines in the tutorial for creating profiles, but no matter what I try I cannot get the icon to show.
It does however work with Package elements, so there must be a difference between extending a metaclass and specializing a stereotype, but it this a bug or what I should expect?
Tomas Sandkvist
Re: Cannot display icons for specialized stereotype [message #1163904 is a reply to message #1162297] Thu, 31 October 2013 09:50 Go to previous message
Klaas Gadeyne is currently offline Klaas GadeyneFriend
Tomas Sandkvist wrote on Wed, 30 October 2013 05:28
Hi Tomas,
In my experience, there are currently quite some "visualisation" problems when profiling SysML elements, for instance
https://bugs.eclipse.org/bugs/show_bug.cgi?id=417813
https://bugs.eclipse.org/bugs/show_bug.cgi?id=417347
My suggestion is that you try to make it work for a UML::class, if that works also perfectly fine, please submit it as a bug.
HTH,
Klaas
Previous Topic:Read-Only attributes persisted in model.uml and caused into error
Next Topic:Create papyrus model programmatically
Current Time: Fri Jan 15 15:46:04 GMT 2021
Powered by FUDForum. Page generated in 0.02236 seconds
