Home » Language IDEs » ServerTools (WTP) » EJB3 in EAR
EJB3 in EAR [message #181921] Wed, 25 October 2006 20:45 Go to next message
Originally posted by: andrey.nechet.gmail.com
I would like to prepare the EAR file with ejb3 module (ejb3.jar for example)
for deploing into the JBoss.
The problem in EJB project - only facets for 2.0/2.1 ejb supported.
I'm trying to remove the META-INF/ejb-jar.xml from EJB project, but then the
final EAR file missing the ejb module (ejb3.jar).
Andrey
Re: EJB3 in EAR [message #181957 is a reply to message #181921] Fri, 27 October 2006 10:28 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Andrey,
you have to modify the deployment descriptors to match JavaEE5. I use a modified
JBoss plugin for EJB3 development
(http://www.informatik.fh-wiesbaden.de/~knauf/public/), and with some tricks I
can use WTP 1.5 quite well.
I create a new project with a 2.1 facet, then change "ejb-jar.xml" to match
EJB3. The necessary changes and a sample project can be found at the above URL.
Hope this helps
Wolfgang
Andrey Nechet schrieb:
> Andrey
Re: EJB3 in EAR [message #181973 is a reply to message #181957] Fri, 27 October 2006 18:05 Go to previous message
Hi Wolfgang,
Your trick is work for me :)
Thank you a lot!
Andrey
"Wolfgang Knauf" <wknauf_NO_@_INSIDE_hg-online.de> wrote in message
news:ehsmvd$8id$1@utils.eclipse.org...
> Hi Andrey,
Previous Topic:2.0M2-Or -1.5.2 ?????
Next Topic:JSP "run on server" acts strangely after adding servlet to project
Current Time: Tue Apr 16 22:42:54 GMT 2024
Powered by FUDForum. Page generated in 0.23035 seconds
