Home » Archived » Buckminster » Does buckminster support jgit based Version Qualifiers?
Does buckminster support jgit based Version Qualifiers? [message #1159547] Mon, 28 October 2013 16:08 Go to next message
Lothar Werzinger is currently offline Lothar WerzingerFriend
Tycho supports Reproducible Version Qualifiers with jgit by calculating based on timestamp of the most recent commit that touches any file under project base directory.
Does buckminster support this, too?
Re: Does buckminster support jgit based Version Qualifiers? [message #1159994 is a reply to message #1159547] Mon, 28 October 2013 22:55 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
On 2013-10-28 17:08, Lothar Werzinger wrote:
> Tycho supports http://wiki.eclipse.org/Tycho/Reproducible_Version_Qualifiers with jgit by calculating based on timestamp
Yes. That's the default behavior for Git based projects.
- thomas
Re: Does buckminster support jgit based Version Qualifiers? [message #1160050 is a reply to message #1159994] Mon, 28 October 2013 23:55 Go to previous messageGo to next message
Thomas Hallgren wrote on Mon, 28 October 2013 15:55
- thomas
We currently use generator.buildTimestamp.format to customize the generated qualifier
qualifier.replacement.*=generator:buildTimestamp
generator.buildTimestamp.format='D-${user.name}-'yyyyMMdd'-'HHmm
But that always uses the build time as the timestamp for every plugin and not the git timestamps for the individual plugins.
How can we instruct Buckminster to use the git timestamps?
Re: Does buckminster support jgit based Version Qualifiers? [message #1160316 is a reply to message #1160050] Tue, 29 October 2013 04:06 Go to previous messageGo to next message
>> timestamp
>> - thomas
> plugins.
Try this:
qualifier.replacement.*=generator:lastModified
generator.lastModified.format='D-${user.name}-'yyyyMMdd'-'HHmm
- thomas
Re: Does buckminster support jgit based Version Qualifiers? [message #1161191 is a reply to message #1160316] Tue, 29 October 2013 16:41 Go to previous messageGo to next message
Matthew Webber is currently offline Matthew WebberFriend
That works for us. Specifically, we use
generator.lastModified.format='v'yyyyMMdd-HHmm
The main thing to remember is that you need the .qualifier on the end of the version number in all bundles, features and products - we got caught once by that, when the version did not change because one component had a fixed version number.
Re: Does buckminster support jgit based Version Qualifiers? [message #1161234 is a reply to message #1160316] Tue, 29 October 2013 17:20 Go to previous messageGo to next message
Thomas Hallgren wrote on Mon, 28 October 2013 21:06
Try this:
- thomas
Thanks that works.
Re: Does buckminster support jgit based Version Qualifiers? [message #1165776 is a reply to message #1161191] Fri, 01 November 2013 14:33 Go to previous message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
The other thing to remember, if you run the build locally on your
machine, is that the changes to the bundles and features must be
committed, since the timestamp corresponds to the last git commit (If I
remember correctly).
I also experienced another problem when building on Jenkins triggered by
Gerrit: remember to set the refspec to $GERRIT_REFSPEC, otherwise the
timestamp will not correspond to the last patchset...
hope this helps :)
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Previous Topic:Strategy for locale fragments
Next Topic:Cannot build p2.site containing xtext
Current Time: Sat Jun 10 22:19:06 GMT 2023
Powered by FUDForum. Page generated in 0.02316 seconds
