Re: Loading order of model fragments [message #1213511 is a reply to message #1192817] |
Wed, 27 November 2013 09:15 |
Tuan Anh Nguyen Messages: 7 Registered: June 2013 |
Hi, yeah that's the current solution now! Thanks for your help, especially the starting point class
But i still think this solution have some problem. In my situation, we have a plugin,which make contribution via model fragment, that contribute to 2 different fragment and these 2 fragment belong to different application. So with this solution, 2 applications must use each other's plugin.
Ex:
Application A with plugin Hello contribute a model fragment
Applicaton B with plugin Hi contribute a model fragment
Plugin XYX contribute a model fragment to both Hello and Hi's model fragments, so the plugin XYZ must add dependency to both plugin Hello and Hi. It means Application A and B must add dependency to each other's plugin. This will lead to a complex situation if plugin Hello and Hi have many other dependencies .
[Updated on: Wed, 27 November 2013 09:27] Report message to a moderator
FUDForum. Page generated in 0.02950 seconds
