Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMFStore] Problem sharing project
[EMFStore] Problem sharing project [message #1158642] |
Mon, 28 October 2013 02:55 |
Scott Dybiec Messages: 148 Registered: July 2009 |
I ran into another snag using EMFStore. Here's my scenario:
First, I create a new project.
Second, I load my model instance from local disk using the standard EMF
XMI Resource.
Next, I add the contents of this Resource (a single root EObject) to the
EMFStore project modelElements list.
Finally, when I attempt to share my local project on the EMFStore server
I get the following error on the server console. What are possible
causes of this?
Oct 27, 2013 9:49:27 PM org.apache.xmlrpc.server.XmlRpcErrorLogger log
SEVERE: Failed to invoke method createEmptyProject in class
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl:
org.apache.xmlrpc.common.XmlRpcInvocationException: Failed to invoke
at
org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.invoke(ReflectiveXmlRpcHandler.java:129)
at
org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.execute(ReflectiveXmlRpcHandler.java:106)
at
org.apache.xmlrpc.server.XmlRpcServerWorker.execute(XmlRpcServerWorker.java:46)
at org.apache.xmlrpc.server.XmlRpcServer.execute(XmlRpcServer.java:86)
at
org.apache.xmlrpc.server.XmlRpcStreamServer.execute(XmlRpcStreamServer.java:200)
at org.apache.xmlrpc.webserver.Connection.run(Connection.java:208)
at org.apache.xmlrpc.util.ThreadPool$Poolable$1.run(ThreadPool.java:68)
Caused by:
org.eclipse.emf.emfstore.internal.server.exceptions.InvalidInputException:
at
org.eclipse.emf.emfstore.internal.server.core.AbstractSubEmfstoreInterface.sanityCheckObject(AbstractSubEmfstoreInterface.java:189)
at
org.eclipse.emf.emfstore.internal.server.core.AbstractSubEmfstoreInterface.sanityCheckObjects(AbstractSubEmfstoreInterface.java:176)
at
org.eclipse.emf.emfstore.internal.server.core.subinterfaces.ProjectSubInterfaceImpl.createProject(ProjectSubInterfaceImpl.java:173)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at
org.eclipse.emf.emfstore.internal.server.core.AbstractSubEmfstoreInterface.execute(AbstractSubEmfstoreInterface.java:149)
at
org.eclipse.emf.emfstore.internal.server.core.EMFStoreImpl.invoke(EMFStoreImpl.java:129)
at com.sun.proxy.$Proxy4.createEmptyProject(Unknown Source)
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl.createEmptyProject(XmlRpcEmfStoreImpl.java:89)
at
at
at
org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.invoke(ReflectiveXmlRpcHandler.java:115)
... 6 more
Caused by:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Oct 27, 2013 10:25:57 PM org.apache.xmlrpc.server.XmlRpcErrorLogger log
SEVERE: Couldn't parse EObject: Failed to retrieve ID for EObject
contained in project:
com.humanfactor.rw.model.regatta.impl.RegattaImpl@b6c31dc
(abbreviatedName: Catch the Cooper Masters R...[truncated lots of
serialized object text]....xswainEntryCost: 75.0,
fourWithoutCoxswainEntryCost: 75.0, quadEntryCost: 75.0, eightEntryCost:
100.0, octupleEntryCost: 100.0, raceDesignType: sprint,
missingBowNumbers: null, regattaId: 1490)
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResult(EObjectTypeParser.java:67)
at
org.apache.xmlrpc.parser.RecursiveTypeParserImpl.endValueTag(RecursiveTypeParserImpl.java:78)
at
org.apache.xmlrpc.parser.XmlRpcRequestParser.endElement(XmlRpcRequestParser.java:162)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:601)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.java:1782)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2939)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:647)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:140)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at
org.apache.xmlrpc.server.XmlRpcStreamServer.getRequest(XmlRpcStreamServer.java:65)
at
org.apache.xmlrpc.server.XmlRpcStreamServer.execute(XmlRpcStreamServer.java:199)
Caused by:
org.eclipse.emf.emfstore.internal.server.exceptions.SerializationException:
Failed to retrieve ID for EObject contained in project:
com.humanfactor.rw.model.regatta.impl.RegattaImpl@5152a09f
(abbreviatedName: Stotesbury Cup Regatta, duration: 2, regattaHomePage:
null, registeredUsRowing: false, resultsUrl: , lifeCycleS...[truncated
lots of serialized object text]....raceDesignType: sprint,
missingBowNumbers: null, regattaId: 1460)
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResultfromResource(EObjectTypeParser.java:108)
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResult(EObjectTypeParser.java:61)
... 17 more
Re: [EMFStore] Problem sharing project [message #1159263 is a reply to message #1158642] |
Mon, 28 October 2013 12:02 |
Maximilian Koegel Messages: 253 Registered: July 2009 |
Hi Scott,
thank you for your report! Is it possible that you changed one of the
generated getters or setters or the generated factory? This could be the
reason for a new object being created during deserialization (and hence
this object has no ID).
If this is not the case:
Is it possible to share the model plugin and/or the Ecore with us?
Could you share the code snippet that loads the resource and puts its
contents into the project?
Hope this helps!
Maximilian
Am 28.10.2013 03:55, schrieb scott@xxxxxxxx:
> XMI Resource.
> causes of this?
> at
> at
> at
> at
> Caused by:
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> ... 6 more
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> at
> at
> ... 17 more
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMFStore] Problem sharing project [message #1159386 is a reply to message #1159263] |
Mon, 28 October 2013 13:47 |
Maximilian,
I made no changes to the ID generation --- I'm using the out of the box
ID generator.
I made some progress debugging this problem using a simpler test case
outside of my application. It turns out that ordering of the operations
in my scenario matters. If the model instance is added to EMFStore's
model element list *before* the local project is shared, the exception
occurs.
On the other hand, if my model instance is added *after* sharing the
local project, no problem. I haven't tested beyond this, but wanted to
give you this update and get your thoughts.
Is this expected behavior for EMFStore?
I'll look into creating a standalone test case.
Scott
On 10/28/2013 8:02 AM, Maximilian Koegel wrote:
> Hi Scott,
> Hope this helps!
> Cheers,
> Maximilian
>> XMI Resource.
>> causes of this?
>> at
>> at
>> at
>> at
>> Caused by:
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 6 more
>> Caused by:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> at
>> at
>> ... 17 more
Re: [EMFStore] Problem sharing project [message #1159473 is a reply to message #1159386] |
Mon, 28 October 2013 15:06 |
Maximilian,
Here's a test case that replicates the issue. It's based on your
HelloWorld example code as a base. If a model element is added to the
local project before it is shared AND that model element is part of an
EMF Resource, then problem occurs.
Hope this helps. Is there a workaround I can use?
Scott
package org.eclipse.emf.emfstore.example.helloworld;
import java.io.File;
import java.io.IOException;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.XMIResource;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl;
import org.eclipse.emf.emfstore.bowling.BowlingFactory;
import org.eclipse.emf.emfstore.bowling.League;
import org.eclipse.emf.emfstore.bowling.Player;
import org.eclipse.emf.emfstore.client.ESLocalProject;
import org.eclipse.emf.emfstore.client.ESRemoteProject;
import org.eclipse.emf.emfstore.client.ESServer;
import org.eclipse.emf.emfstore.client.ESUsersession;
import org.eclipse.emf.emfstore.client.ESWorkspace;
import org.eclipse.emf.emfstore.client.ESWorkspaceProvider;
import org.eclipse.emf.emfstore.client.exceptions.ESServerNotFoundException;
import
org.eclipse.emf.emfstore.client.exceptions.ESServerStartFailedException;
import org.eclipse.emf.emfstore.common.ESSystemOutProgressMonitor;
import org.eclipse.emf.emfstore.server.exceptions.ESException;
import org.eclipse.equinox.app.IApplication;
import org.eclipse.equinox.app.IApplicationContext;
* An application that runs the demo.<br>
* Run a client and local server that demo the basic features of EMFStore.
public class TestCaseApplication implements IApplication {
* {@inheritDoc}
public Object start(IApplicationContext context) {
try {
// Create a client representation for a local server and start a
local server.
ESServer localServer = ESServer.FACTORY.createAndStartLocalServer();
// Run a client on the local server that shows the basic features of
the EMFstore
runClient(localServer);
} catch (ESServerStartFailedException e) {
System.out.println("Server start failed!");
e.printStackTrace();
} catch (ESException e) {
// If there is a problem with the connection to the server,
// e.g., a network, a specific EMFStoreException will be thrown.
System.out.println("Connection to Server failed!");
return IApplication.EXIT_OK;
* Run an EMFStore Client connecting to the given server.
* @param server the server
* @throws ESException if the server connection fails
public static void runClient(ESServer server) throws ESException {
System.out.println("Client starting...");
// The workspace is the core controller to access local and remote
projects.
// A project is a container for models and their elements (EObjects).
// To get started, we obtain the current workspace of the client.
ESWorkspace workspace = ESWorkspaceProvider.INSTANCE.getWorkspace();
// The workspace stores all available servers that have been
configured. We add the local server that has
// already
// been started on the workspace.
workspace.addServer(server);
// Next, we remove all other existing servers
for (ESServer existingServer : workspace.getServers()) {
if (existingServer != server) {
try {
workspace.removeServer(existingServer);
} catch (ESServerNotFoundException e) {
// The workspace also contains a list of local projects that have
either been created locally or checked out
// from a server.
// We create a new local project. The project new created is not yet
shared with the server.
ESLocalProject demoProject = workspace.createLocalProject("DemoProject");
* When the model elements are added here before the project is shared
AND the model element (league in this
* case) is contained in a resource, then this exception is thrown.
The loadModelOrig() works fine, while
* loadModel2(), loadModel3() and loadModel4() all throw exceptions.
* SEVERE: Couldn't parse EObject: Failed to retrieve ID for EObject
* org.eclipse.emf.emfstore.bowling.impl.LeagueImpl@20ec6bb1
League league = loadModel2();
demoProject.getModelElements().add(league);
demoProject.save();
// We delete all projects from the local workspace other than the one
just created.
for (ESLocalProject existingLocalProject : workspace.getLocalProjects()) {
if (existingLocalProject != demoProject) {
try {
existingLocalProject.delete(new ESSystemOutProgressMonitor());
} catch (IOException e) {
// Next, we create a user session by logging in to the local EMFStore
server with default super user
// credentials.
ESUsersession usersession = server.login("super", "super");
// Now we can share the created local project to our server.
ESRemoteProject remoteDemoProject =
demoProject.shareProject(usersession, new ESSystemOutProgressMonitor());
// We also retrieve a list of existing (and accessible) remote
projects on the server.
// Remote projects represent a project that is currently available on
the server.
// We delete all remote projects to clean up remaining projects from
previous launches.
for (ESRemoteProject existingRemoteProject :
server.getRemoteProjects(usersession)) {
if
(!existingRemoteProject.getGlobalProjectId().equals(remoteDemoProject.getGlobalProjectId()))
existingRemoteProject.delete(usersession, new NullProgressMonitor());
// Now we are all set: we have a client workspace with one server
configured and exactly one project shared to a
// server with only this one project.
// We check out a second, independent copy of the project (simulating
a second client).
ESLocalProject demoProjectCopy =
demoProject.getRemoteProject().checkout("DemoProject Copy",
// We start working now with the local project and later we will
synchronize it with the copy of the project we
// just checked out.
// We create some EObjects and add them to the project, that is, to
project�s containment tree. Everything
// that
// is
// in the project�s containment tree (spanning tree on containment
references) is considered part of the
// project. We will use an example model about bowling.
// First we add a league and set the league name.
// League league = loadModel();
// Next we add the league to the root of the project. The project has
a containment feature called model
// element that holds all root elements of a project. This list is
comparable to the content list in EMF
// Resources that
// you can retrieve with getContents(). Adding something to the list
will add it to the project.
// demoProject.getModelElements().add(league);
// Then we create two players.
Player player1 = BowlingFactory.eINSTANCE.createPlayer();
player1.setName("Maximilian");
Player player2 = BowlingFactory.eINSTANCE.createPlayer();
player2.setName("Ottgar");
// Finally, we add the players to the league. Since the league is
already part of the project and League.players
// is a containment feature, the players also become part of the project.
league.getPlayers().add(player1);
league.getPlayers().add(player2);
// To synchronize the local changes of the client with the server, we
will commit the project.
demoProject.commit("My message", null,
// The server is now up-to-date, but we still need to synchronize the
copy of the project we checked out
// earlier.
demoProjectCopy.update(new ESSystemOutProgressMonitor());
// We will now retrieve the copy of the league from the copy of the
project and assert its name and player count
// are equal with the name of the project�s league.
League leagueCopy = (League) demoProjectCopy.getModelElements().get(0);
if (league.getName().equals(leagueCopy.getName()) &&
league.getPlayers().size() == leagueCopy.getPlayers().size()) {
System.out.println("Leagues names and player count are equal.");
// Of course, we can also change something in the project copy and
synchronize it back to the project.
// We change the league name to correct the type and then commit and
update accordingly.
// This time, we use the IDs assigned to every EObject of a project to
identify the copy of league in the
// project�s copy.
demoProjectCopy.getModelElement(demoProject.getModelElementId(league));
league.setName("Superbowling League");
demoProject.commit(new ESSystemOutProgressMonitor());
System.out.println("Leagues names and player count are still equal.");
* {@inheritDoc}
public void stop() {
public static League loadModelOrig() {
// This works fine
League league = BowlingFactory.eINSTANCE.createLeague();
league.setName("Suprbowling League");
return league;
public static League loadModel2() {
// This fails
URI uri = createURI();
Resource resource = new XMIResourceImpl(uri);
resource.getContents().add(league);
return league;
public static League loadModel3() {
// This fails
ResourceSet resourceSet = createResourceSet();
Resource resource = resourceSet.createResource(uri);
return league;
public static League loadModel4() {
// This fails
League league;
createModel();
try {
resource.load(null);
league = (League) resource.getContents().get(0);
league = null;
return league;
public static void createModel() {
try {
resource.save(null);
System.out.println("Saved league to " + uri);
public static URI createURI() {
return URI.createFileURI(new File("MyLeague.league").getAbsolutePath());
public static ResourceSet createResourceSet() {
// For testing to see whether UUIDs caused the problem
ResourceSet resourceSet = new ResourceSetImpl() {
public Resource createResource(URI uri) {
XMIResource resource = new XMIResourceImpl(uri) {
protected boolean useUUIDs() {
return false;
return resource;
return resourceSet;
On 10/28/2013 9:47 AM, scott@xxxxxxxx wrote:
> Maximilian,
> ID generator.
> occurs.
> Scott
>> Hi Scott,
>> Hope this helps!
>> Cheers,
>> Maximilian
>>> XMI Resource.
>>> causes of this?
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 6 more
>>> Caused by:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> at
>>> ... 17 more
Re: [EMFStore] Problem sharing project [message #1163098 is a reply to message #1159473] |
Wed, 30 October 2013 20:56 |
Edgar Mueller Messages: 89 Registered: March 2011 |
Member |
Hi Scott,
thanks for the test case and sorry for the delay (we're are currently
attending EclipseCon). We'll integrate a test case like this in our test
suite, since apparently it was missing. We also do have a fix ready and
will look at the other issues you reported as soon as possible.
We're planning to do a hotfix release addressing the reported issues at
the end of next week.
Edgar
Am 28.10.2013 16:06, schrieb scott@xxxxxxxx:
> Maximilian,
> Scott
> import
> import
> * {@inheritDoc}
> try {
> start a local server.
> features of the EMFstore
> thrown.
> remote projects.
> (EObjects).
> // already
> try {
> have either been created locally or checked out
> // from a server.
> not yet shared with the server.
> shared AND the model element (league in this
> thrown. The loadModelOrig() works fine, while
> exceptions.
> demoProject.save();
> the one just created.
> try {
> EMFStore server with default super user
> // credentials.
> available on the server.
> from previous launches.
> if
> server configured and exactly one project shared to a
> (simulating a second client).
> will synchronize it with the copy of the project we
> is, to project�s containment tree. Everything
> // that
> // is
> containment references) is considered part of the
> project has a containment feature called model
> is comparable to the content list in EMF
> // Resources that
> list will add it to the project.
> is already part of the project and League.players
> the project.
> server, we will commit the project.
> synchronize the copy of the project we checked out
> // earlier.
> the project and assert its name and player count
> equal.");
> and synchronize it back to the project.
> commit and update accordingly.
> project to identify the copy of league in the
> // project�s copy.
> still equal.");
> * {@inheritDoc}
> // This works fine
> return league;
> // This fails
> return league;
> // This fails
> return league;
> // This fails
> League league;
> createModel();
> try {
> league = null;
> return league;
> try {
> @Override
> @Override
> return false;
> return resource;
> return resourceSet;
>> Maximilian,
>> ID generator.
>> occurs.
>> Scott
>>> Hi Scott,
>>> Hope this helps!
>>> Cheers,
>>> Maximilian
>>>> XMI Resource.
>>>> the
>>>> server
>>>> causes of this?
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 6 more
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> eightEntryCost:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> ... 17 more
Edgar Mueller
Re: [EMFStore] Problem sharing project [message #1164320 is a reply to message #1159473] |
Thu, 31 October 2013 15:45 |
Scott,
thank you very much for the test case. A work around would be to remove
the object you add to the project from the resource prior to adding it
to the project. You can do this with resource.getContents().remove().
Maximilian
> Maximilian,
> Scott
> import
> import
> * {@inheritDoc}
> try {
> thrown.
> remote projects.
> (EObjects).
> // already
> try {
> // from a server.
> exceptions.
> demoProject.save();
> try {
> // credentials.
> if
> // that
> // is
> // Resources that
> project.
> // earlier.
> equal.");
> // project�s copy.
> equal.");
> * {@inheritDoc}
> // This works fine
> return league;
> // This fails
> return league;
> // This fails
> return league;
> // This fails
> League league;
> createModel();
> try {
> league = null;
> return league;
> try {
> @Override
> @Override
> return false;
> return resource;
> return resourceSet;
>> Maximilian,
>> ID generator.
>> occurs.
>> Scott
>>> Hi Scott,
>>> Hope this helps!
>>> Cheers,
>>> Maximilian
>>>> XMI Resource.
>>>> the
>>>> server
>>>> causes of this?
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 6 more
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> eightEntryCost:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> ... 17 more
Maximilian Kögel
Current Time: Tue Apr 23 07:19:27 GMT 2024
Powered by FUDForum. Page generated in 0.04017 seconds
