newbie can't get tutorial to work from eclipse [message #181079] |
Sat, 07 October 2006 01:13 |
Originally posted by: rschumeyer.ieee.org
I tried the WTP tutorial
WTP Tutorials – Building and Running a Web Application
at
http://www.eclipse.org/webtools/community/tutorials/BuildJ2E EWebApp/BuildJ2EEWebApp.html
Everything seems ok until the end when I try to navigate to
http://localhost:8080/tutorial/snoop
according to the instructions.
I always get a 404 error, both from the internal web browser and an
external one.
I'm pretty sure I made the project correctly, because I can close
eclipse, deploy it with ant, and it works. (I just added a build.xml
and a build.properties file)
Now the tutorial is almost two years old, and I am using the latest
versions of eclipse (3.2.1) and wtp (I believe 1.1.1 ?). Perhaps some
of the information is out of date?
I think my problem is that I have no idea how to deploy and run the
application from within eclipse.
Can someone point me to a recent tutorial that works?
Re: newbie can't get tutorial to work from eclipse [message #181086 is a reply to message #181079] |
Sat, 07 October 2006 01:25 |
Aha! I did not realize you have to select the servelt first, and then
attempt "run as." That worked much better.
> at
> external one.
FUDForum. Page generated in 0.03398 seconds
