Trouble with preferences when using XMLMultiPageEditorPart [message #1155267] |
Fri, 25 October 2013 20:24 |
My code includes the use of the XMLMultiPageEditorPart and it's working pretty well. I am having trouble with the preferences editor, however. When viewing the XML > XML Files > Editor panel, it complains:
"org.eclipse.wst.sse.ui.preferences.editor not found"
I have included org.eclipse.wst.sse.ui and all of the dependencies...specifically:
org.eclipse.core.expressions
org.eclipse.core.runtime
org.eclipse.debug.ui
org.eclipse.emf.common
org.eclipse.jface.text
org.eclipse.search
org.eclipse.ui
org.eclipse.ui.editors
org.eclipse.ui.forms
org.eclipse.ui.ide
org.eclipse.ui.views
org.eclipse.ui.workbench.texteditor
org.eclipse.wst.sse.core
org.eclipse.wst.validation
When I validate the plugins in my run configuration, there are no missing bundles. I've tried searching the web but haven't found anything even remotely helpful. Any help would be much appreciated.
Ken
Re: Trouble with preferences when using XMLMultiPageEditorPart [message #1163145 is a reply to message #1161495] |
Wed, 30 October 2013 21:45 |
Nitin,
Thank you for the reply. The launch configuration does not restrict the plugins enabled for the launch. I have a target platform setup which includes all dependencies and when I validate the plugins needed in the launch configuration, there are no issues. I'm at a loss as to what I can even do to track down the root cause of the issue. Any help is much appreciated.
Ken
FUDForum. Page generated in 0.02240 seconds
