Re: EclipseLink seems to ignore columnDefinition and nullable [message #1155137 is a reply to message #1152367] |
Fri, 25 October 2013 18:18 |
nuno pinto Messages: 5 Registered: October 2013 |
Thanks for the replies. I've seen both the stackoverflow link and the mentioned bug report. I really wanted to use serial types because the database is going to be used by more applications. This bug made me rethink my approach and I decided to code the database first (as it is the core component of the system) and let eclipselink generate entities from it. So far I am happy with this approach.
I do believe it is a bug though. It generates serial columns to foreign keys, which can never be, and doesn't allow to override. However as I changed my code and won't be able to keep an eye on it I'm not sure if I should start a bug report which I won't be following.
[Updated on: Fri, 25 October 2013 18:19] Report message to a moderator
FUDForum. Page generated in 0.03149 seconds
