Home » Eclipse Projects » EclipseLink » EclipseLink + JPA + Generic Entity + SINGLE_TABLE Inheritance(EclipseLink + JPA + Generic Entity + SINGLE_TABLE Inheritance)
EclipseLink + JPA + Generic Entity + SINGLE_TABLE Inheritance [message #1151287] Wed, 23 October 2013 08:43
Steffen Rose is currently offline Steffen RoseFriend
I was wondering if it's possible in JPA to define a generic entity like in my case PropertyBase<T> and derive concrete entity classes like ShortProperty and StringProperty and use them with the SINGLE_TABLE inheritance mode? If I try to commit newly created ElementModel instances (see ElementModelTest) over the EntityManager I always get an NumberFormatException that "value" can't be properly converted to a Short. Strangely enough if I define all classes below as inner static classes of my test case class "ElementModelTest" this seems to work. Any ideas what I need to change to make this work?
I'm using EclipseLink eclipselink-2.6.0.v20131019-ef98e5d.
public abstract class PersistableObject  implements Serializable {
    private static final long serialVersionUID = 1L;
    private String id = UUID.randomUUID().toString();
    private Long version;
    public PersistableObject() {
           this(serialVersionUID);
    public PersistableObject(final Long paramVersion) {
          version = paramVersion;
   public String getId() {
          return id;
    public void setId(final String paramId) {
          id = paramId;
    public Long getVersion() {
         return version;
    public void setVersion(final Long paramVersion) {
    public String toString() {
        return this.getClass().getName() + "[id=" + id + "]";
public abstract class PropertyBase<T> extends PersistableObject {
    private String name;
    private T value;
    public PropertyBase() {
    public PropertyBase(final Long paramVersion) {
         this(paramVersion, null);
    public PropertyBase(final Long paramVersion, final String paramName) {
         this(paramVersion, paramName, null);
    public PropertyBase(final Long paramVersion, final String paramName, final T paramValue) {
        super(paramVersion);
        name = paramName;
        value = paramValue;
    public String getName() {
        return name;
    public void setName(final String paramName) {
        name = paramName;
    public T getValue() {
        return value;
    public void setValue(final T paramValue) {
         value = paramValue;
public class ShortProperty extends PropertyBase<Short> {
    public ShortProperty() {
        this(null, null);
    public ShortProperty(final String paramName) {
        this(paramName, null);
    public ShortProperty(final String paramName, final Short paramValue) {
        super(serialVersionUID, paramName, paramValue);
public class StringProperty extends PropertyBase<String> {
    protected StringProperty() {
        this(null, null);
    public StringProperty(final String paramName) {
    public StringProperty(final String paramName, final String paramValue) {
public class ElementModel extends PersistableObject {
    private StringProperty name = new StringProperty("name");
    private ShortProperty number = new ShortProperty("number");
    public ElementModel() {
    public ElementModel(final Long paramVersion) {
       return name.getValue();
        name.setValue(paramName);
    public Short getNumber() {
        return number.getValue();
    public void setNumber(final Short paramNumber) {
       number.setValue(paramNumber);
<?xml version="1.0" encoding="UTF-8" ?>
<entity-mappings version="2.1">
 <mapped-superclass class="PersistableObject">
  <attributes>
        <id name="id">
            <column name="id" />
        </id>
        <version name="version" access="PROPERTY">
           <column name="version" />
        </version>
  </attributes>
 </mapped-superclass>
 <entity class="PropertyBase">
     <table name="PropertyBase" />
     <inheritance />
     <discriminator-column name="type"/>
     <attributes>
           <basic name="name">
              <column name="name" />
           </basic>
           <basic name="value">
              <column name="value" />
           </basic>
      </attributes>
 </entity>
 <entity class="StringProperty">
    <discriminator-value>StringProperty</discriminator-value>
 </entity>
 <entity class="ShortProperty">
    <discriminator-value>ShortProperty</discriminator-value>
 </entity>
 <entity class="ElementModel">
      <table name="ElementModel" />
      <inheritance />
      <attributes>
           <one-to-one name="name">
               <join-column name="name" referenced-column-name="id" />
               <cascade>
                     <cascade-all />
               </cascade>
           </one-to-one>
           <one-to-one name="number">
               <join-column name="number" referenced-column-name="id" />
               <cascade>
                  <cascade-all />
               </cascade>
           </one-to-one>
      </attributes>
 </entity>
</entity-mappings>
public class ElementModelTest extends ModelTest<ElementModel> {
    public ElementModelTest() {
         super(ElementModel.class);
    @Test
    @SuppressWarnings("unchecked")
    public void testSQLPersistence() {
         final String PERSISTENCE_UNIT_NAME = getClass().getPackage().getName();
         new File("res/db/test/" + PERSISTENCE_UNIT_NAME + ".sqlite").delete();
         EntityManagerFactory factory = Persistence.createEntityManagerFactory(PERSISTENCE_UNIT_NAME);
         EntityManager em = factory.createEntityManager();
         Query q = em.createQuery("select m from ElementModel m");
         List<ElementModel> modelList = q.getResultList();
         int originalSize = modelList.size();
         for (ElementModel model : modelList) {
             System.out.println("name: " + model.getName());
         System.out.println("size before insert: " + modelList.size());
         em.getTransaction().begin();
         for (int i = 0; i < 10; ++i) {
             ElementModel device = new ElementModel();
             device.setName("ElementModel: " + i);
             device.setNumber((short) i);
             em.persist(device);
         em.getTransaction().commit();
        System.out.println("size after insert: " + modelList.size());
        assertTrue(modelList.size() == (originalSize + 10));
        em.close();
Previous Topic:Where are my EclipseLink JPA Facets?
Next Topic:DB2 Stored Proc Call - Query is wrong
Current Time: Wed May 27 01:04:54 GMT 2020
Powered by FUDForum. Page generated in 0.02003 seconds
