Home » Eclipse Projects » GEF » Header for a GEF editor
Header for a GEF editor [message #178711] Thu, 21 April 2005 16:00 Go to next message
Originally posted by: rodrigo.tekchile.cl
I would like to know if there is any example on how to show a simple header
for a GEF editor.
I'm using today a ScrollingGraphicalViewer but i need to show a simple label
text showing some status and text of the currently edited figures.
I saw a sample with the GEF rulers but it looks much more complicated that
what i need.
Rodrigo.
Re: Header for a GEF editor [message #178751 is a reply to message #178711] Thu, 21 April 2005 20:53 Go to previous messageGo to next message
Pratik Shah is currently offline Pratik ShahFriend
You can use the status bar or the editor's description bar
(EditorPart#setDescription() or something like that). Otherwise, you can do
one of the following:
1) subclass the root editpart and create this header of yours outside of the
layered pane (if you want the header to be inside the editor and want it to
scroll) OR
2) put it in a separate lightweight system that is in another composite
inside the editor, but not in the composite that has the graphical viewer.
"Rodrigo Varas" <rodrigo@tekchile.cl> wrote in message
news:d48ime$jvg$1@news.eclipse.org...
header
> for a GEF editor.
label
> what i need.
> Rodrigo.
Re: Header for a GEF editor [message #178877 is a reply to message #178751] Sat, 23 April 2005 01:54 Go to previous message
Originally posted by: ya_xiang.hotmail.com
You can check out jbpm grapheditor implements.
The guys don't use GraphicalEditor but a normal editorpart, you can get what
you wanted.
Regards.
xiangya
"Pratik Shah" <ppshah@us.ibm.com> ะด
Previous Topic:Focus display and traversing
Next Topic:Infinite Loop using ShortestPathConnectionRouter
Current Time: Tue Mar 21 02:34:08 GMT 2023
Powered by FUDForum. Page generated in 0.01901 seconds
