WST 1.5.0 with Maven 2.0 dependencies running on Tomcat [message #178603] |
Wed, 06 September 2006 18:49 |
Originally posted by: dmitry.custommode.com
There is lot of buz on this news group on getting the WTP to work with
maven2 plugin. Non of the answers fit my combination of tools/versions.
Has anyone gotten WST 1.5.0 WEB-INF/lib with maven2 dependencies
deployable to Tomcat?
thanks
D>
Re: WST 1.5.0 with Maven 2.0 dependencies running on Tomcat [message #178671 is a reply to message #178603] |
Thu, 07 September 2006 17:25 |
> thanks
> D>
Actually, how the WST 1.5.0 and WTP related? I was under the impression
that the they are the same thing, the WST is the latest release that
comes as part of calisto distribution model though.
So looks like people had a lot of issues with maven 2 integration in WTP
and most of which were addressed. Am I making a right assumption that
since the WST is newer release (potentially with some incompatible
changes that affect maven 2 integration) the maven 2 integration has not
been raised and addressed yet?
I can't get a good feeling which direction to take from this point,
should I try to analyze the WTP answers and come up with some similar
approach for WST, or someone is actively looking at this issue and
perhaps a bug fix should be expected shortly from the calisto updates?
Thanks.
D>
Re: WST 1.5.0 with Maven 2.0 dependencies running on Tomcat [message #178709 is a reply to message #178671] |
Thu, 07 September 2006 18:17 |
Originally posted by: kosta.bea.com
Dmitry,
WebTools Platform (WTP) is composed of two major components Web Standard
Tools (WST) and Java Standard Tools (JST). Most people will want to
download the complete WTP distribution that includes both as J2EE
development is not possible using only WST. You can only create static
web projects using the WST distribution.
- Konstantin
Re: WST 1.5.0 with Maven 2.0 dependencies running on Tomcat [message #178726 is a reply to message #178709] |
Thu, 07 September 2006 19:12 |
Konstantin Komissarchik wrote:
> Dmitry,
> - Konstantin
Konstantin,
thank you for clarification, it actually makes sense now. Do you also
know if the latest release of WTP known to work properly with maven 2
dependencies? I have maven 2 plugin installed, it does look through the
pom.xml file, adds the dependencies to a classpath and pulls them off
the net to the local cache. At the end the project compiles properly,
but when trying to run on server it does not know to put the maven 2
defined dependencies into WEB-INF/lib folder which results in the
ClassNotFoundException.
Thank you so much,
D>
Re: WST 1.5.0 with Maven 2.0 dependencies running on Tomcat [message #178739 is a reply to message #178732] |
Fri, 08 September 2006 01:31 |
> Dmitry,
> Maven plugins have not yet been integrated to work with WTP. There is
> an ongoing effort to do that by the people who maintain maven plugins
> with some involvement from WTP, but that effort has just started.
> - Konstantin
Thank you Konstantin,
that clears it up alot.
Would you also suggest what is the best way to find out when this
feature going to be released (sorry for being annoying, but this little
feature means a lot for the development team i'm working with), is there
an announcement news group where this sort of messages get posted to?
Appreciate your help,
D>
Re: WST 1.5.0 with Maven 2.0 dependencies running on Tomcat [message #178767 is a reply to message #178761] |
Fri, 08 September 2006 22:10 |
Eugene Kuleshov wrote:
> It is been a week since last comment on that issue... So, are you guys
> going to give us some pointers, or the stuff you've suggested is just
> not doable in the current WTP API? ;-)
> regards,
> Eugene
Hmmm,
looked through the issue on the
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154251 -- looks like it's
got it all (or most of it) covered, i'm not sure if i can (or should)
contribute more to it :) , at this point someone just has to roll up the
sleeves and do it.
Good luck!
And thanks for all the help (can't wait for the release of this issue). :)
D>
FUDForum. Page generated in 0.04701 seconds
