Export TableViewer data to a file [message #1146328] |
Sun, 20 October 2013 04:39 |
Hi all,
I'm trying to iterate through the data in my TableViewer in order to write it to a CSV file (code below). The problem is that some of my TableViewerColumns use a StyledCellLabelProvider. Those columns don't return any text from their TableItems. I know I must be missing something simple but am just not seeing it. Thanks in advance for the help.
-Ken
final int[] columnOrder = table.getColumnOrder();
String[] line = new String[columnOrder.length];
for(int columnOrderIndex = 0; columnOrderIndex < columnOrder.length;
columnOrderIndex++) {
int columnIndex = columnOrder[columnOrderIndex];
TableColumn tableColumn = table.getColumn(columnIndex);
line[columnOrderIndex] = tableColumn.getText();
csvWriter.writeNext(line);
final int itemCount = table.getItemCount();
for(int itemIndex = 0; itemIndex < itemCount; itemIndex++) {
TableItem item = table.getItem(itemIndex);
line[columnOrderIndex] = item.getText(columnIndex);
Re: Export TableViewer data to a file [message #1148841 is a reply to message #1147399] |
Mon, 21 October 2013 19:37 |
Thorsten,
Thank you for you time considering this issue! I've posted a complete reproducer below. I probably should have just taken the time to do this the first time. The file created contains none of the text from the table.
Ken
package forumexamples;
* Copyright (c) 2006 Tom Schindl and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Tom Schindl - initial API and implementation
import java.io.BufferedWriter;
import java.io.File;
import java.io.FileWriter;
import java.io.IOException;
import org.eclipse.jface.viewers.ILabelProvider;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.StyledCellLabelProvider;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.TableViewerColumn;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
* A simple TableViewer to demonstrate usage
* @author Tom Schindl <tom.schindl@bestsolution.at>
public class Snippet001TableViewer {
private class MyContentProvider implements IStructuredContentProvider {
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.IStructuredContentProvider#getElements(java.lang.Object)
public Object[] getElements(Object inputElement) {
return (MyModel[])inputElement;
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.IContentProvider#dispose()
public void dispose() {
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.IContentProvider#inputChanged(org.eclipse.jface.viewers.Viewer, java.lang.Object, java.lang.Object)
public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
public class MyModel {
public int counter;
public MyModel(int counter) {
this.counter = counter;
public String toString() {
return "Item " + this.counter;
public Snippet001TableViewer(Shell shell) {
final TableViewer v = new TableViewer(shell);
TableViewerColumn column = new TableViewerColumn(v, SWT.LEFT);
column.getColumn().setText("Name");
column.getColumn().setResizable(true);
column.getColumn().setWidth(150);
column.setLabelProvider(new HyperlinkLabelProvider(v.getTable(),
new LabelProvider()));
v.setContentProvider(new MyContentProvider());
MyModel[] model = createModel();
v.setInput(model);
v.getTable().setHeaderVisible(true);
v.getTable().setLinesVisible(true);
shell.getDisplay().asyncExec(new Runnable() {
public void run() {
exportTable(v);
private MyModel[] createModel() {
MyModel[] elements = new MyModel[10];
for( int i = 0; i < 10; i++ ) {
elements[i] = new MyModel(i);
return elements;
private class HyperlinkLabelProvider extends StyledCellLabelProvider
implements ILabelProvider {
private final Color linkColor;
private final LabelProvider labelProvider;
public HyperlinkLabelProvider(Composite parent,
LabelProvider labelProvider) {
this.labelProvider = labelProvider;
linkColor = new Color(parent.getDisplay(), 0, 0, 255);
super.dispose();
if (linkColor != null) {
linkColor.dispose();
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.StyledCellLabelProvider#paint(org.eclipse.swt.widgets.Event, java.lang.Object)
protected void paint(Event event, Object element) {
GC gc = event.gc;
// remember colors to restore the GC later
Color oldFg = gc.getForeground();
gc.setForeground(linkColor);
gc.drawText(getText(element), event.x, event.y);
gc.setForeground(oldFg);
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.ILabelProvider#getImage(java.lang.Object)
public Image getImage(Object element) {
return labelProvider.getImage(element);
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.ILabelProvider#getText(java.lang.Object)
public String getText(Object element) {
return labelProvider.getText(element);
public void exportTable(TableViewer tableViewer) {
// TODO: add logic to ask user for the file location
File file = new File("exportedTable.txt");
try (BufferedWriter writer = new BufferedWriter(new FileWriter(file))) {
final Table table = tableViewer.getTable();
writer.write(tableColumn.getText());
writer.write(",");
writer.write("\n");
writer.write(item.getText(columnIndex));
writer.write(",");
writer.write("\n");
} catch(IOException ioe) {
// TODO: add logic to inform the user of the problem
System.err.println("trouble exporting table data to file");
ioe.printStackTrace();
* @param args
Display display = new Display ();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
new Snippet001TableViewer(shell);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: Export TableViewer data to a file [message #1149713 is a reply to message #1148841] |
Tue, 22 October 2013 08:54 |
Thorsten Schlathölter Messages: 312 Registered: February 2012 Location: Düsseldorf |
Hi Ken,
I am sorry for giving wrong advice. Contrary to my assumption the table item must not be properly configured when it displays the data. And also the labelprovider plays an important role in your case, since it actually does the painting of the table cell. So the problem in your case is really the custom label provider which you provide.
Please look at StyledCellLabelProvider.update(). It says there
public void update(ViewerCell cell) {
// clients must override and configure the cell and call super
super.update(cell); // calls 'repaint' to trigger the paint listener
Since you did not override this method to set the cell text and image, it is not there when you are trying to export. Please look at
org.eclipse.jface.viewers.ColumnLabelProvider
for a default implementation of that method.
In the end, the solution to your problem is to add the following method to your HyperlingLabelProvider:
super.update(cell);
Object element = cell.getElement();
cell.setText(getText(element));
Image image = getImage(element);
cell.setImage(image);
Note: Instead of using StyledCellLabelProvider you could also use an ITableColorProvider.
public class MyLabelProvider extends LabelProvider implements
ITableLabelProvider, ITableColorProvider {
public Color getForeground(Object element, int columnIndex) {
return Display.getCurrent().getSystemColor(SWT.COLOR_BLUE);
public Color getBackground(Object element, int columnIndex) {
return null;
public Image getColumnImage(Object element, int columnIndex) {
return super.getImage(element);
public String getColumnText(Object element, int columnIndex) {
return super.getText(element);
final TableViewer v = new TableViewer(shell, SWT.MULTI | SWT.H_SCROLL
| SWT.V_SCROLL | SWT.BORDER);
TableColumn tc = new TableColumn(v.getTable(), SWT.NONE);
tc.setWidth(100);
tc.setText("Name");
v.setLabelProvider(new MyLabelProvider());
v.getTable().setLayoutData(new GridData(GridData.FILL_BOTH));
v.setInput(model);
public void run() {
exportTable(v);
HTH
Thorsten
Re: Export TableViewer data to a file [message #1150473 is a reply to message #1149713] |
Tue, 22 October 2013 20:07 |
Thorsten, ahhhh, most excellent advice! It's working great now!
Thank you so much for the help, I'm quite new to the JFace world and am still figuring things out (as you can tell).
Note that I would have used the simpler ITableColorProvider but I also underline the hyperlinks in the cells. I just didn't want to add further complication to the reproducer as well as require extra bundles. If there's an easier way to do that as well, I'd love to hear about it!
FUDForum. Page generated in 0.02296 seconds
