Home » Language IDEs » ServerTools (WTP) » WSDL Generation
Re: WSDL Generation [message #177341 is a reply to message #177333] |
Fri, 18 August 2006 12:06 |
Bala,
EMF can generate an XML Schema from an Ecore model. I.e., given a
..genmodel, you can right click and invoke "Export Model..." to export a
schema. Its implemented by org.eclipse.xsd.ecore.EcoreSchemaBuilder.
Balamurugan Easwaran wrote:
> Is there any way to Generate WSDL from XMI ?
> Does EMF Helps generate WSDL ?
> Regards
> Bala
Re: WSDL Generation [message #177390 is a reply to message #177341] |
Fri, 18 August 2006 14:31 |
Originally posted by: user.domain.invalid
Hi Merks,
Thanks a lot for the reply.
I think I have not clearly stated my problem.
I want to generate WSDL(not XSD) file from XMI.
Bala
Ed Merks wrote:
> Bala,
>> Hi,
>> Regards
>> Bala
Re: WSDL Generation [message #177397 is a reply to message #177390] |
Fri, 18 August 2006 14:41 |
Bala,
Definitely you've not clearly stated what you want. Since XMI can be
used to serialize anything, you've basically asked, given an XML file
that's an XMI serialzation of mystery model x, how do I create a WSDL
for it? I'd suggest providing more detail.
user@domain.invalid wrote:
> Hi Merks,
> Regards
> Bala
> Ed Merks wrote:
>> Bala,
>> a schema. Its implemented by org.eclipse.xsd.ecore.EcoreSchemaBuilder.
>>> Hi,
>>> Regards
>>> Bala
Re: WSDL Generation [message #177413 is a reply to message #177397] |
Fri, 18 August 2006 15:28 |
Ed,
your suggestion :-
EMF can generate an XML Schema from an Ecore model.I.e., given a
*.genmodel, you can right click and invoke "Export Model..." to export
my question :-
An Ecore model can represent a DataStructure and a set of Operations
where the DataStructure can be serialized as an w3c Schema.In that way
can an Ecore model also be serialized as WSDL Document ?.
Iam attaching the source EMF model serialized as an .xmi and target
WSDL which i want.
******************source xmi ************************************
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="model"
nsURI="http://www.orangescape.com"
nsPrefix="com.orangescape.model.PurchaseOrder">
<eClassifiers xsi:type="ecore:EClass" name="StatelessService">
<eOperations name="New">
<eAnnotations source="operationInfo">
<details key="Name" value="New"/>
<details key="Size" value="10"/>
<details key="Visible" value="true"/>
<details key="Image" value="c:\sample.gif"/>
</eAnnotations>
</eOperations>
<eClassifiers xsi:type="ecore:EClass" name="PurchaseOrder">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="po_date">
<eType xsi:type="ecore:EDataType"
href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eStructuralFeatures>
name="ordering_customer_name">
name="order_customer_address">
</eClassifiers>
</ecore:EPackage>
******************End of source xmi *****************************
*******************target WSDL************************************
<wsdl:definitions name="StetefullPurchaseOrderService"
targetNamespace=" http://dimension.PO.Service.StatefulService/StatefulPurchase OrderService/"
xmlns:tns=" http://dimension.PO.Service.StatefulService/StatefulPurchase OrderService/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/">
<types>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:com.orangescape.model.PurchaseOrder="http://www.orangescape.com"
xmlns:xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
xmlns:xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/"
targetNamespace="http://www.orangescape.com">
<xsd:complexType name="PurchaseOrder">
<xsd:sequence>
<xsd:element minOccurs="0" type="xsd:string" name="po_date"
maxOccurs="1" />
name="ordering_customer_name" maxOccurs="1" />
name="order_customer_address" maxOccurs="1" />
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
</types>
<wsdl:message name="NewOperationResponse">
<wsdl:part name="NewOperationResponse"
type="tns:PurchaseOrder"></wsdl:part>
</wsdl:message>
<wsdl:message name="NewOperationRequest">
<wsdl:part name="NewOperationRequest" type="xsd:string"></wsdl:part>
</wsdl:message>
<wsdl:portType name="StetefullPurchaseOrderService">
<wsdl:operation name="NewOperation">
<wsdl:input message="tns:NewOperationRequest"/>
<wsdl:output message="tns:NewOperationResponse"/>
</wsdl:operation>
</wsdl:portType
<wsdl:binding name="StetefullPurchaseOrderServiceSOAP"
type="tns:StatefullPurchaseOrderService">
<soap:binding style="document"
transport="http://schemas.xmlsoap.org/soap/http"/>
<wsdl:input></wsdl:input>
<wsdl:output></wsdl:output>
</wsdl:operation>
</wsdl:binding>
<wsdl:service name="StetefullPurchaseOrderService">
<wsdl:port name="StetefullPurchaseOrderServiceSOAP"
binding="tns:StatefullPurchaseOrderServiceSOAP">
<soap:address
location=" http://localhost:6666/dimension/StetefullPurchaseOrderServic e"/>
</wsdl:port>
</wsdl:service>
</wsdl:definitions>
*******************End of target WSDL***********************************
thanks for your feedback
regards,
Bala
Ed Merks wrote:
> Bala,
>> Hi Merks,
>> Regards
>> Bala
>> Ed Merks wrote:
>>> Bala,
>>>> Hi,
>>>> Regards
>>>> Bala
Re: WSDL Generation [message #177421 is a reply to message #177413] |
Fri, 18 August 2006 15:31 |
Bala,
No, EMF only has support for generating the <xsd:schema> part of what
you show below. With EMF 2.2, the operations will be encoded as
annotations within that schema. It would be a very interesting thing to
generate a WSDL from the operations; I know very little about WSDL.
Looking at how the EcoreSchemaBuilder works and using the WSDL model, it
definitely should be possible to do something like what you are
suggesting. It would make a very interesting project. Probably folks
would want to do the inverse as well...
> Ed,
> your suggestion :-
> my question :-
> WSDL which i want.
> </eAnnotations>
> </eOperations>
> name="po_date">
> </eClassifiers>
> </ecore:EPackage>
> <types>
> <xsd:sequence>
> name="po_date" maxOccurs="1" />
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> </types>
> </wsdl:message>
> </wsdl:message>
> </wsdl:operation>
> </wsdl:portType
> </wsdl:operation>
> </wsdl:binding>
> <soap:address
> </wsdl:port>
> </wsdl:service>
> </wsdl:definitions>
> regards,
> Bala
> Ed Merks wrote:
>> Bala,
>>> Hi Merks,
>>> Regards
>>> Bala
>>> Ed Merks wrote:
>>>> Bala,
>>>> export a schema. Its implemented by
>>>>> Hi,
>>>>> Regards
>>>>> Bala
Current Time: Thu Apr 25 23:24:47 GMT 2024
Powered by FUDForum. Page generated in 0.03488 seconds
