Home » Modeling » Papyrus » Unable to remove diagram
Unable to remove diagram [message #1143772] Fri, 18 October 2013 12:12 Go to next message
Logan M is currently offline Logan MFriend
I have made some tests with Papyrus and I have two diagrams (CompositeDiagram and ClassDiagram) but I can't remove them from my model.
When I select one from the model explorer and then pressing "Del" key or by using "Delete" from contextual menu, nothing happens.
The diagrams are both empty.
There's any way to known why I can't remove them and to remove them (eg manually editing a file) ?
Thank you !
Re: Unable to remove diagram [message #1143829 is a reply to message #1143772] Fri, 18 October 2013 12:59 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
On older versions of Papyrus (Indigo, and maybe early versions of Juno), there were issues related to diagram deletion. But in Kepler, I haven't had any such issue.
What version of Papyrus are you using?
If you're using Kepler, is there any error in your error log?
Camille Letavernier
Re: Unable to remove diagram [message #1143950 is a reply to message #1143829] Fri, 18 October 2013 14:40 Go to previous messageGo to next message
Sorry, I haven't mentioned used versions:
  • Eclipse: Juno SR2
  • Papyrus: 0.9.2.v201302131112
I will try to move to Kepler/last Papyrus.
I have manually fix the problem by editing the ".notation" file with XML editor and cleaning removed reference from ".di" file (still with XML editor).
The error logs contain (All messages coming at the same time):
Failed to update action org.eclipse.mylyn.resources.ui.ui.interest.remove.element
(No stacktrace available)
	at org.eclipse.papyrus.infra.core.sasheditor.internal.eclipsecopy.MultiPageEditorSite4x.getPage(MultiPageEditorSite4x.java:442)
	at org.eclipse.ui.internal.ObjectPluginAction.setActivePart(ObjectPluginAction.java:123)
	at org.eclipse.ui.internal.ObjectActionContributor$1.run(ObjectActionContributor.java:156)
	at org.eclipse.ui.internal.ObjectActionContributor.contributeObjectActions(ObjectActionContributor.java:160)
	at org.eclipse.ui.internal.ObjectActionContributorManager.contributeObjectActions(ObjectActionContributorManager.java:97)
	at org.eclipse.ui.internal.PopupMenuExtender.addEditorActions(PopupMenuExtender.java:314)
	at org.eclipse.ui.internal.PopupMenuExtender.menuAboutToShow(PopupMenuExtender.java:398)
	at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuManager.java:343)
	at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:475)
	at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:470)
	at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:500)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:255)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
	at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:4881)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4557)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
	at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
	at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:257)
	at org.eclipse.swt.widgets.Display.runPopups(Display.java:4210)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
Failed to update action org.eclipse.papyrus.uml.compare.file
An exception stack trace is not available.
Failed to update action ValidationAction
Failed to update action nonbound.org.eclipse.team.ui.ConfigureProject
Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".java.lang.NullPointerException
Failed to update action org.eclipse.team.ui.applyPatch
Re: Unable to remove diagram [message #1143956 is a reply to message #1143950] Fri, 18 October 2013 14:44 Go to previous messageGo to next message
All these errors have been fixed in Kepler (0.10.1), and there is no maintenance anymore for Juno.
So you should definitely update.
Camille
Camille Letavernier
Re: Unable to remove diagram [message #1143987 is a reply to message #1143956] Fri, 18 October 2013 15:08 Go to previous message
I have updated and from my deployment diagram all execution environment doesn't display their content (artifacts and all dependancies between artifacts) Sad I tried "Show/Hide contents" (F4) but they are all checked...
Previous Topic:Problem with multiple stereotype icon and expression
Next Topic:How to display ExecutionEnvironment content from Deployment Diagrams ?
Current Time: Thu Apr 25 21:32:45 GMT 2024
Powered by FUDForum. Page generated in 0.03149 seconds
