Home » Eclipse Projects » GEF » Why GEF uses its own GEFMessages, not the WorkbenchMessage?
Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #176685] |
Mon, 11 April 2005 18:40  |
Originally posted by: kevinlouisnospam.hotmail.com
WorkbenchMessages and GEFMessages have some common message, e.g.
"Workbench.copyToolTip" and "GEFMessages.CopyAction_Tooltip".
I want to see if there is any special reason why GEF does not use the
Workbench on and create its own set. I am going to use the
WorkbenchMessages only as GEF does not have cut action.
Kevin.
Re: Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #176794 is a reply to message #176762] |
Tue, 12 April 2005 00:44   |
GEFMessages is in the org.eclipse.gef.internal too. I don't see it is a
good reason why GEFMessage is used, instead of the
org.eclipse.ui.internal.WorkbenchMessages.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:d3eqr2$6a2$1@news.eclipse.org...
> Because WorkbenchMessages is internal.
> "Kevin" <kevinlouisnospam@hotmail.com> wrote in message
> news:d3eglt$mm3$1@news.eclipse.org...
> > Hi,
> > Thanks,
> > Kevin.
Re: Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #177096 is a reply to message #176794] |
Tue, 12 April 2005 19:28   |
That's our internal package vs. someone else's over which we have no
control.
news:d3f60d$ihi$1@news.eclipse.org...
>> > Hi,
>> > Thanks,
>> > Kevin.
Re: Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #177187 is a reply to message #177096] |
Tue, 12 April 2005 22:28   |
Hi Randy,
In that case, why don't you provide a complete set of actions strings then?
For example, I need to implement the Cut Action, but GEFMessages only has
copy and paste. I need to use the WorkbenchMessages one.
Actually, why is the WorkbenchMessages from someone else? Is it from
Eclipse too?
Kevin
"Randy Hudson" <none@us.ibm.com> wrote in message
news:d3h7rs$d6v$1@news.eclipse.org...
> control.
> >> > Hi,
> >> > Thanks,
> >> > Kevin.
Current Time: Fri Mar 31 01:19:39 GMT 2023
Powered by FUDForum. Page generated in 0.02207 seconds
