Many Save Conflicts [message #16684] |
Tue, 11 December 2007 00:14 |
Originally posted by: j.craig.aggiemail.usu.edu
Using RSE to edit remote files, I've been getting "Save Conflict" dialogs
on nearly every save. It is asking if I want to "Replace contents of
editor with remote file", "Overwrite the remote file", or "Save the
contents of the editor to a different remote file". I have been
overwriting because I know no one else is editing these files.
I haven't seen this happen until I recently upgraded to TM 2.0.2.
Is this a bug, or is there some other issue that may be at work here?
thanks,
--Jason
Re: Many Save Conflicts [message #16734 is a reply to message #16684] |
Tue, 11 December 2007 18:25 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hello Jason,
this sounds like a bug - please file a bugzilla entry for it.
Please include information like
- What connection type do you use (ssh, dstore, ...)
- What kind of remote system?
- Do you use RSE directly or through the EFS integration?
It looks like RSE doesn't get the timestamp of the remote file
right. It might help comparing the timestamp in the RSE properties
view against the actual timestamp as seen when doing "ls -l"
in a remote shell against the timestamp of the cached file in
RemoteSystemsTempFiles/...
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> dialogs on nearly every save. It is asking if I want to "Replace
> contents of editor with remote file", "Overwrite the remote file", or
> "Save the contents of the editor to a different remote file". I have
> been overwriting because I know no one else is editing these files.
> thanks,
> --Jason
Re: Many Save Conflicts [message #16744 is a reply to message #16739] |
Tue, 11 December 2007 22:15 |
I'm using the RSE itself to browse a Linux system with FTP for a file, and
then double-clicking it to edit it remotely. This isn't using EFS, right?
The file modification times show up the same in the RSE properties and
with ls -l.
--Jason
Re: Many Save Conflicts [message #571300 is a reply to message #16684] |
Hello Jason,
Martin Oberhuber
> thanks,
> --Jason
FUDForum. Page generated in 0.03093 seconds
