Warnings on SWTBot tests [message #1142397] |
Thu, 17 October 2013 15:47 |
imad sabaany Messages: 17 Registered: August 2013 |
I get these warnings when I run my tests.Do you have an ideas How to fix these warnings.
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:21.398
!MESSAGE org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Next >' and with style 'SWT.PUSH')
16 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Next >' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:21.400
17 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Next >' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:21.401
18 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Next >' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:21.402
19 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Next >' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:21.403
1081 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:22.465
!MESSAGE org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
1082 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:22.466
1083 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:22.467
1084 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
1085 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:22.468
3150 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:24.534
3152 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:24.535
3153 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:24.536
3154 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:24.537
3155 [main] WARN org.eclipse.swtbot.swt.finder.widgets.SWTBotButton - Widget is not enabled: (of type 'Button' and with mnemonic 'Finish' and with style 'SWT.PUSH')
!ENTRY org.apache.log4j 2 0 2013-10-17 15:42:24.538
FUDForum. Page generated in 0.02746 seconds
