Home » Modeling » GMF (Graphical Modeling Framework) » How to duplicate a GMF diagram (Duplicate a GMF diagram preserving the source layout)
How to duplicate a GMF diagram [message #1142247] Thu, 17 October 2013 13:43 Go to next message
peugene Mising name is currently offline peugene Mising nameFriend
Member
I have an EMF/GMF application.
One feature is: Duplicate a model and it's associated diagram.
Well, it's work fine simply using the code in the DiagramEditorUtil.
public static Resource createDiagram(final MyModel model, URI diagramURI,
URI modelURI, IProgressMonitor progressMonitor)
The newly created diagram use a default layout to display node and connector.
My need is to preserve the original layout of the GMF diagram.
There is lot of auto-generated xmi:id in the GMF model.
All this id are used by connector to set source and target.
Then, i'm a little confused. What is the best way to duplicate a GMF diagram and preserve the original layout ?
Philippe
Re: How to duplicate a GMF diagram [message #1143724 is a reply to message #1142247] Fri, 18 October 2013 11:35 Go to previous messageGo to next message
Christian Smietana is currently offline Christian SmietanaFriend
Recently I've come across this class in the api doc (btw., where can I find a reliable version of the GMF API doc e.g. for eclipse 3.7 ? This IBM stuff is the only version of the API doc I've ever found anywhere)
http://publib.boulder.ibm.com/infocenter/rsmhelp/v7r0m0/topic/org.eclipse.gmf.doc/reference/api/runtime/org/eclipse/gmf/runtime/diagram/core/util/ViewRefactorHelper.html
I don't know whether it's what you want, at least it seems to target a similar problem.
Christian
[Updated on: Fri, 18 October 2013 11:35]
Report message to a moderator
Re: How to duplicate a GMF diagram [message #1149741 is a reply to message #1142247] Tue, 22 October 2013 09:17 Go to previous message
Member
Hello Christian,
Thanks for the link.
I used an other method to do this. Simply using String replacement, not very nice, but it's work for my need.
/** create the resource Diagram **/
Resource diagram = xxxDiagramEditorUtil.createDiagram(target, diagramURI, modelURI,
new NullProgressMonitor());
/** load the resource of the diagram to duplicate **/
Resource sourceDiagram = // here load the resource;
/** serialize the resource in a String and make the string replacement **/
OutputStream outputStream = new ByteArrayOutputStream();
try {
  sourceDiagram.save(outputStream, null);
  String xml = outputStream.toString();
  xml = xml.replaceAll(".myExtension#" + source.getID(),".myExtension#" +   target.getID());
  xml = xml.replaceAll(source.getName(), target.getName());
save the new diagram resource
Previous Topic:create diagram from .ecore file by GMF
Next Topic:type of created diagram in GMF run-time
Current Time: Sat Sep 19 10:03:47 GMT 2020
Powered by FUDForum. Page generated in 0.02249 seconds
