Wrap Text [message #176309] |
Fri, 08 April 2005 23:16 |
Originally posted by: jsk_lam.hotmail.com
I have a org.eclipse.draw2d.Label and would like to have the text wrapped
around to next line if the box is not wide enough to fit the string.
Would someone please help and show me what do I need to do?
sl
Re: Wrap Text [message #176328 is a reply to message #176309] |
Sat, 09 April 2005 07:58 |
Originally posted by: lorenz.m.gmx.at
see my posting above.
Place the text into TextFlow and it gets wrapped.
SL wrote:
> wrapped around to next line if the box is not wide enough to fit the
> string.
> Thanks
> sl
Re: Wrap Text [message #176347 is a reply to message #176328] |
Sat, 09 April 2005 14:45 |
Hi Larenz,
Which one is that? I couldn't find it.
This is what I did:
Label label = new Label();
TextFlow textFlow = new TextFlow(node.getLabel());
label.add(textFlow);
Panel panel = new Panel(); // My panel contains multiple figures.
panel.add(_label);
This is the errors I got:
Unhandled event loop exception
Reason: Failed to execute runnable (java.lang.NullPointerException)
*** SWT nested exception
Reason: java.lang.NullPointerException
Best Regards,
SL.
"Lorenz Maierhofer" <lorenz.m@gmx.at> wrote in message
news:d381u0$8uk$1@news.eclipse.org...
> SL wrote:
> > Hi,
> > string.
> > Thanks
> > sl
Re: Wrap Text [message #176354 is a reply to message #176347] |
Sat, 09 April 2005 16:03 |
Just don't use Label, but something like:
TextFlow content = new TextFlow("TExt to wrap");
FlowPage fp = new FlowPage();
fp.add(content);
panel.add(fp);
add(panel);
> This is what I did:
> panel.add(_label);
> Best Regards,
> SL.
>>Hi,
>>SL wrote:
>>>Hi,
>>>string.
>>>Thanks
>>>sl
Re: Wrap Text [message #176390 is a reply to message #176354] |
Sun, 10 April 2005 14:48 |
Well, the text does not even show up in the panel with FlowPage.
news:d38uc3$8jt$1@news.eclipse.org...
> fp.add(content);
> panel.add(fp);
> add(panel);
> > This is what I did:
> > panel.add(_label);
> > Best Regards,
> > SL.
> >>Hi,
> >>SL wrote:
> >>>Hi,
> >>>string.
> >>>Thanks
> >>>sl
Re: Wrap Text [message #176431 is a reply to message #176397] |
Sun, 10 April 2005 21:36 |
I do need the panel, it is the container of 3 figures:
| Icon |
| Text |
| Icon |
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:d3bj64$rg$1@news.eclipse.org...
> That would depend on the layout of the panel. But if you just want to
> display that text, you don't need the panel.
> "slam" <jsk_lam@hotmail.com> wrote in message
> news:d3bel5$rm6$1@news.eclipse.org...
> > > Hi,
> > > fp.add(content);
> > > panel.add(fp);
> > > add(panel);
> > > > This is what I did:
> > > > panel.add(_label);
> > > > Best Regards,
> > > > SL.
> > > >>Hi,
> > > >>SL wrote:
> > > >>>Hi,
the
> > > >>>string.
> > > >>>Thanks
> > > >>>sl
Re: Wrap Text [message #176574 is a reply to message #176437] |
Mon, 11 April 2005 00:18 |
Yes, no text appears and no error or exception until all figures are
created,
then the exceptions occured. I am using the ToolbarLayout.
I tried to use FlowLayout, but the layout becomes
| Icon Text Icon |
This is not the way I want.
news:d3c8af$oan$1@news.eclipse.org...
> And you're saying no text appears now that you're using a FlowPage? Are
you
> using a ToolbarLayout for your panel?
> This should be simple to debug yourself. You're doing something basic
> wrong.
> news:d3c6hs$mm4$1@news.eclipse.org...
> > | Icon |
> > | Text |
> > | Icon |
> > > > > Hi,
> > > > > fp.add(content);
figures.
> > > > > panel.add(fp);
> > > > > add(panel);
> > > > > > This is what I did:
> figures.
> > > > > > panel.add(_label);
> > > > > > Best Regards,
> > > > > > SL.
> > > > > >>Hi,
> > > > > >>SL wrote:
> > > > > >>>Hi,
text
fit
> > the
> > > > > >>>string.
> > > > > >>>Thanks
> > > > > >>>sl
Re: Wrap Text [message #176636 is a reply to message #176354] |
Mon, 11 April 2005 15:11 |
It works for me:
Display d = new Display();
Shell shell = new Shell(d);
shell.setLayout(new FillLayout());
FigureCanvas canvas = new FigureCanvas(shell);
canvas.getViewport().setContentsTracksWidth(true);
Figure panel = new Figure();
panel.setLayoutManager(new ToolbarLayout());
TextFlow content = new TextFlow(System.getProperties().toString());
fp.add(content);
panel.add(fp);
panel.add(new Label("A label"));
canvas.setContents(panel);
shell.setText("draw2d");
shell.open();
while (!shell.isDisposed())
while (!d.readAndDispatch())
d.sleep();
Re: Wrap Text [message #176717 is a reply to message #176636] |
Mon, 11 April 2005 21:04 |
It works only if the long string contains spaces in between, then the string
will wrap
at the space boundary. If I have a long continuous string without space in
between,
then it will not wrap.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:d3e4cl$3rq$1@news.eclipse.org...
> It works for me:
> public static void main(String[] args) {
> fp.add(content);
> panel.add(fp);
> shell.open();
> d.sleep();
Re: Wrap Text [message #176731 is a reply to message #176717] |
Mon, 11 April 2005 21:09 |
Looks like it is a bug.
news:d3ep30$3nb$1@news.eclipse.org...
string
> will wrap
in
> between,
> > It works for me:
> > fp.add(content);
> > panel.add(fp);
> > shell.open();
> > d.sleep();
Re: Wrap Text [message #177135 is a reply to message #176754] |
Tue, 12 April 2005 20:38 |
Is there a way to get the size of the displayed text?
Dimension flowPageSize_ = _flowPage.getSize(); // Always return
(w=64, h=36) regardless of how many lines.
This causes exception:
Dimension flowPagePrefSize = _flowPage.getPreferredSize();
I need to know the height of the _flowPage to size the container Panel that
contains the _flowPage.
news:d3epln$4iu$1@news.eclipse.org...
> Aah, that was an important piece of information you didn't mention
earlier.
> Add these lines to your code:
> ParagraphTextLayout layout = new ParagraphTextLayout(textFlow,
> ParagraphTextLayout.WORD_WRAP_SOFT);
> textFlow.setLayoutManager(layout);
> By default, TextFlow uses WORD_WRAP_HARD.
> string
> > will wrap
> in
> > between,
> > > It works for me:
> > > fp.add(content);
> > > panel.add(fp);
> > > shell.open();
> > > d.sleep();
Re: Wrap Text [message #177165 is a reply to message #177135] |
Tue, 12 April 2005 20:55 |
Call getPreferredSize. If you get an exception, it's because you haven't
parented the figure and it doesn't know what font to use.
Re: Wrap Text [message #178317 is a reply to message #177135] |
Tue, 19 April 2005 18:25 |
Hi Pratik,
I have the following code snippet:
_textFlow = new TextFlow(node.getLabel());
_textFlow, ParagraphTextLayout.WORD_WRAP_SOFT);
_textFlow.setLayoutManager(layout);
_flowPage = new FlowPage();
_flowPage.add(_textFlow);
_flowPage.setHorizontalAligment(PositionConstants.CENTER );
// TODO: which one to set?
_textFlow.setFont(_fontLabel);
_flowPage.setFont(_fontLabel);
// Must set the font to use before calling getPreferredSize() or
exception will occur.
displayedTextPrefSize = _flowPage.getPreferredSize(); // width=???,
height=13
_nodePanel.add(_flowPage);
_flowPage.getPreferredSize() does not know how to return the number of lines
wrapped.
I really need to know how many lines wrapped to size the _nodePanel
accordingly.
The question I have is: How can I find the number of lines wrapped?
Also, I notice thta the WORD_WRAP_SOFT also break on the space if needed.
Best Regards
slam
news:d3hbvr$j76$1@news.eclipse.org...
that
> earlier.
> > string
> > > will wrap
space
> > in
> > > between,
> > > > It works for me:
> > > > fp.add(content);
> > > > panel.add(fp);
> > > > shell.open();
> > > > d.sleep();
Re: Wrap Text [message #178355 is a reply to message #178317] |
Tue, 19 April 2005 21:38 |
Pratik Shah Messages: 1077 Registered: July 2009 |
"sl" <jsk_lam@hotmail.com> wrote in message
news:d43iul$rf5$1@news.eclipse.org...
> Hi Pratik,
You should be able to figure this out by looking at Figure#getFont().
width=???,
> height=13
If you debug this, you'll realize that invoking flowPage.getPreferredSize()
means invoking flowPage.getPreferredSize(-1, -1). What that means is that
you're asking the flowpage how big does it want to be if it had infinite
width and infinite height available. Since it has infinite width, it
doesn't need to wrap and hence it will return a size such that all text fits
on one line. If, however, you tell it how much width is available (height
would still be -1), it will return the appropriate size.
Your next question is going to be....how do you know how much width is
available? Use LayoutManagers and don't set the bounds of the figure
yourself. If you don't see why or how that'll fix your problem, set a
breakpoint in getPreferredSize(wHint, hHint) and walk through what's
happening and try to understand.
lines
> wrapped.
> accordingly.
Yes, it wraps in a readable format if it can. This is the intended
behaviour.
> Best Regards
> slam
> that
> > earlier.
the
> > > string
> > > > will wrap
> space
> > > in
> > > > between,
> > > > > It works for me:
> > > > > fp.add(content);
> > > > > panel.add(fp);
> > > > > shell.open();
> > > > > d.sleep();
Re: Wrap Text [message #179028 is a reply to message #178317] |
Mon, 25 April 2005 14:04 |
It's best to avoid calling setFont() unless you are changing from the
inherited one. Instead, you should add the figure to the lightweightsystem
it is going to showup in.
Can you back up a bit and tell us what you are trying to do. there is
probably a much easier way.
FUDForum. Page generated in 0.04333 seconds
